Question about Cables To Go Televison & Video
Hdmi port burn - Cables To Go Televison & Video
  • 27 Answers
Before you buy
Posted on Feb 14, 2013
Replaced board that has hdmi ports and the tv still has high power coming out of cable in put port and has burned out hdmi inport
Fault to the main power supply regulator section. {AC leak} Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Nov 15, 2015 | Televison & Video
Hdmi does not work
Surprised to hear that the HDMI input connector is burnt, however have you tried another HDMI port? If none of the HDMI inputs are working then a software updat could fix it or the HDMI switching IC maybe at fault. If you get a picture from the spare HDMI ports then the faulty HDMI socket can be replaced by an engineer.
Nov 05, 2013 | LG 50PC5D Television
Suddenly lost Laptop to Mitsubishi 60c9 connection using HDMI
never plug in hdmi when comp.is on you may burn your hdmi port
Aug 03, 2012 | Mitsubishi WD-60C9 60" DLP HDTV
My lg 42cs560-ue after a lightining storm started to react weird in one of the hdmi ports that was branched to my pc, while the pc works fine in the second HDMI port, the first one can only shows the bios...
The bios might be ok, but the communication to the processor might have got cut due to lightning. Probably some components would have also got suffered and the TV needs attention by a qualified service technician.
Jul 14, 2012 | Televison & Video
Where is the HDMI port on a Sony Bravia KDF-46E3000
There are two HDMI (High Definition Multimedia Interface) ports on your Television.Please refer the diagram below to know about the HDMI ports of your Sony Bravia KDF-46E3000.In the diagram the labeled ports numbered 6 and 7 are the two HDMI ports on your television.You can connect your TV with other devices which supports HDMI with an HDMI cable to view High Defenition videos.
Hope you are satisfied with my solution.Thanks for choosing Fixya.Your valuable feedback would be appreciated.
Jul 23, 2011 | Sony Televison & Video
How to connect blu ray player hdmi to my laptop
1) Look at your laptop computer to see if you have an HDMI cable port. This port is roughly half an inch wide and provides both the HD audio and video signal. If you don't, you are going to use a DVI port on the laptop. This is the same port you use to connect monitors to your computer.
2) Plug the DVI-to-HDMI adapter into the DVI port on the laptop with the Blu-ray player. If you have an HDMI port on your laptop, you can skip this step.
3) Connect an HDMI cable to the HDMI end of the adapter. If you have an HDMI port, plug the cable directly into the HDMI port.
4) Plug the other end of the HDMI cable into the HDMI port on the HD television. Power on your television, press the "Input" button and select "HDMI." You can now see the contents from your Blu-ray player on the TV.
Thanks for rating
Good luck
Feb 11, 2011 | Televison & Video
Just set up RX-A700 two things seem wrong. 1. HDMI 1 won't show video if HDMI is plugged in, once plug on HDMI is removed from receiver HDMI 1 works perfectly. 2. HDMI output needs to be held tight or else...
sounds to me like a bad HDMI cable. Just replace it.
If HDMI still wont show, move to another HDMI port. But based on having to hold HDMI cable with hand to steady the connection, it is either a bad HDMI cable, or a bad HDMI port on the receiver. Good luck
Jan 23, 2011 | Yamaha RXA700 Receiver
No signal through hdmi ports
Check the hdmi cables be sure their in proper working condition, wiggle the cables around see if picture comes up. If not and the cables are good then the hdmi processor on the main board of your TV is defective. Alot of times hdmi ports tend to burn so see if you smell a burnt smell near or around the hdmi ports. but before you do anything be sure sure your TV settings are correct for hdmi....
Oct 18, 2010 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
HDMI ports stopped working. Only get a blue screen. Can only watch TV through AV.
If you have a cable box, then you have to pick the right source. So on your TV remote you need to pick the source button and then scroll down to HDMI 2 as the source. HDMI 1 is the blueray device. HDMI 2 to watch TV
Apr 11, 2010 | Vizio SV421XVT 42 in. LCD TV
I cannot get the Input 3 HDMI port to work. The Input 3 Componet videoworks, but when I unplug the componet video and put in HDMI port nothing works. I do have something else in the HDMI Input 1 port...
Hi.
To start ensure that each time you connect or disconnect the HDMI ports both TV and connected device are off.
Also ensure that HDMI input is active, as detailed here.
HDMI connectors carry voltage, and connecting the HDMI cable while TV or device is on may easily damage the HDMI port, making it unusable.
The HDMI 3 and Component 3 are separate input. The component input may work, and HDMI port may still be defective.
To test the port do the following:
Disconnect TV power cord, and connected device (eg. Receiver, DVD etc.).
Leave units disconnected for five minutes.
While power is disconnected, test connecting on port three a device that was previously working on HDMI 1. Also use a cable that you know is working.
Connect back power with HDMI cable already connected. If HDMI 3 is still not detected, then the port is defective.
In that case ring Pioneer at the number listed on the owners manual.This model is often advertised as only two HDMI inputs. Call Pioneer to ensure the third port can be enabled.
Dec 26, 2009 | Pioneer PDP-4350HD 43 in. Plasma...
Televison & Video Logo
18 people viewed this question
Top Cables To Go Televison & Video Experts
Electro Med Services...
Are you a Cables To Go Televison and Video Expert? Answer questions, earn points and help others
