Question about HP Laserjet 600 M603dn Laser Printer - Monochrome -
HP M603 ERROR 98.01.01
PERMANENT
2 Suggested Answers
BaronVonNuke
  • 1915 Answers
SOURCE: How do i fix error 98.01.01 on a HP Laser Jet 600 M603
This error is caused by a corruption of the harddisk on the printer. Download the current firmware for the printer from Hewlett Packard. Then restart the printer and watch the display. When you light on the screen comes on press the orange X button. This will open the preboot menu. Use the arrow to go down to Administration, press ok and then select the option to format the disk. You will get a warning that you will need to reinstall firmware. Click ok. Go to the download firmware option, select ok and then select USB Key option. You will be prompted to insert a USB stick, insert the one you copied the new firmware to. You will be prompted if you want to install the firmware. Click ok and then use the back arrow key to exit until printer says continue. Press OK. Printer will restart and firmware will be updated and printer should now come to ready.
Posted on Feb 16, 2015
Hp laserjet 600 m603 memory error was detected
you are using a generic toner -- the chip on the toner is causing the memory error. you should still be able to print. hit the ok button to bypass
Dec 09, 2016 | HP LaserJet Office Equipment & Supplies
I have hp laserjet 600 m603 it is printing black paper so eny help
Sounds like a Defective toner - putting too much on paper. Is there toner inside the machine?
Oct 19, 2016 | HP Office Equipment & Supplies
Reset hp laser m603
HP LaserJet Enterprise 600 M601, M602, and M603 Series Printer - Restore factory settings:
Apr 14, 2014 | HP LaserJet 600 M602DN Laser Printer - M
I-pro 8gb Compact Flash - camera Fine pix M603 comes up on screen"Card not initalized". tried to format it but comes up card error
Hello -- just read your problem - interesting - do you have a multi card reader for the PC ? if so you could check out the card with the PC first. OR -- do you have a printer that can accept 'cards' this would also work from the PC also.
(This is how I download RAW format from my FinePix onto the PC)
I assuming you have entered a Card into the M603 before and other cards worked ? and it's just this 8GB card that won't.
Last resort if you can't get hold of a multi card reader is to take the card in a Photo Shop as if to print some pictures and see what their machine says when you insert your card.
It may ask you - Should I formatt the card -- say YES. Or if it says card error than just suspect the card , it may be faulty. -- Ray
Mar 04, 2011 | Fuji FinePix M603 Digital Camera
`permanent storage full error` what does it mean????
The internal storage system is full. You need to run the HP Web Jetadmin software and delete unnecessary files from the EIO disk device. When done, press the select button on the printer to return it to a ready state. You should be able to print small jobs yet as long as it doesn't require any temporary (or permanent) storage on the EIO disk.
May 27, 2009 | HP LaserJet 4250n Printer
Initialising 5Gb micro disk for Fujifilm M603
There is a limitation with this camera and the size of memory cards it can handle. Larger cards than 1GB, are not recognized properly. You can however use larger cards if you format the card in the camera using the USB cable connected to your PC. Just connect the camera to your PC. In windows explorer select the camera drive, right-click and select "format". I have used this to get a 2GB card working with my 603. Beware that files larger than 1GB can not be stored on the card. I once had been recording a video at concert for about 30 minutes with the 2GB card installed (the camera got really hot during this shooting!). When hitting the record button again to save this giant clip, I got an error message "write error" I was a sad puppy that night.
Feb 16, 2008 | Fuji FinePix M603 Digital Camera
Fuji m603/screen is green with lines at top
This is a sign of age. A loose connector perhaps on the screen. If it still taking good pictures then live with it. You could try a repair shop- but the likely cost will be well on the way to its replacements price I would think.
May 31, 2007 | Fuji FinePix M603 Digital Camera
HP Laserjet 600 M603dn Laser Printer - Monochrome - Logo
337 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
