Door locked but runs for 10 seconds then stops
My washing machine had a fault which i jkind of narrowed it down to the switch .
i ordered a new switch but same problem the switch dosent seem to be locking the door and the door secure light dosent show .
i have switch the cables round and got it to say door secure but the cycle only lasts 10 seconds.
then the top light an the bar and stain vanish light flashes
  • 15,935 Answers
1. Unplug washer.
2. Remove the outer portion of the door bellow. This is the gray rubber boot around the door. Feel around the edge of the door bellow where it attaches to the front of the washer. You will find a wire retaining hoop in the seam between the rubber and the front case. Follow this wire hoop to the bottom of the door bellow and you will find a tension spring. Carefully, stretch this spring apart and remove the wire hoop.
3. Pull the rubber bellow from the door facing on the front of the washer being careful not to rip or tear it. Once removed, fold the rubber backwards inside the drum so you can access behind the front panel. DO NOT remove the rubber bellow from the wash tub.
4. The door latch assembly is located behind the front panel of the washer on the right hand side. Locate and remove the three screws on the washer front that hold the door latch assembly in place. The whole assembly should come free from the washer front and be held by a plastic mounting bracket and several wire connectors.
5. Carefully remove the latch assembly from the plastic mounting bracket BEFORE attempting to unplug any wires. It makes it much easier to access if you do.
6. Unplug the wire connectors using care not to break any of the wires. You may want to write them down, but I believe they will only plug into their respective slots.
7. Remove the old door latch and install the new one in the reverse order of the steps I just presented to you. Plug the wires back in first, then place the whole assembly back into the plastic mounting bracket, and then reattach to the front of the washer.
8. Now, when you get the reinstalling the rubber door boot, you may want to get the assistance of a second pair of hands as it can be difficult sometimes to manipulate the wire retainer back into place. Carefully reattach the rubber bellow to the door facing on the front of the washer first.
9. Starting at the top of the door bellow at the 12 o'clock position begin inserting the wire hoop back into the groove. Work your way around with both hands to the 4 and 8 o'clock positions. (This is where you could use those second pair of hands). While holding a slight downward tension on the wire hoop to keep it in place, pull the tension spring apart enough to snap the remaining part of the hoop into place at the bottom. Once you've completed these steps make sure the door closes and latches properly. NEVER slam a door with an electronic latch. They can break easily.
Now plug the washer back in and test operate. NOTE: You can run diagnostics on these washers by referring to the tech sheet provided by the manufacturer. The tech sheet is located behind the lower panel under the door, or along the interior cabinet walls. Included, are instructions on how to run diagnostics and troubleshooting tips associated with the list of fault codes. It is recommended that this tech sheet remain inside the washer to prevent it from being lost.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 13, 2010
Machine shows E 61 when switch on.
E61 I think this a door lock error code. When you close, the door it activates a switch which will allow the machine to start a wash programme. Conversely the first thing the selected programme does is activate a solenoid, to stop you opening the door before the machine is ready. Think spinning drums, small children and cats, or flooded floors. I digress, if that little switch stops working or the mechanism has moved slightly and isn't activated, the machine assumes the door is open.
Maybe not a great help but we have narrowed things down.
Apr 03, 2016 | Washing Machines
My door lock has stopped working.
I asume this is after the machine has finnished it's wash and all the water has gone.
Door switcheds are a common fault on a washing machine. because they are in circuit all the time. Easy enough to replace. POWER OFF AND PLUG OUT !
With door open, if there is a clip around the front of the door seal then remove it by gently prising it off. Becareful not to damage the door seal. Undo the two screws where the lock is. Where the door lock is located, peel back the door seal enoght to get at the lock and bring it out side of the panel. Make a note of where the wires are and remove them. refit a new lock and replace parts in reverse order.
Oct 03, 2014 | Washing Machines
Getting pe error
Whirlpool Washing Machine Displaying Fault Code PE The part(s) or condition(s) listed below for the symptom PE - PRESSURE SENSOR ERROR // Water level pressure switch error are ordered from most likely to least likely to occur. Check or test each item, starting with the items at the top of the page.
Dec 09, 2017 | Whirlpool Washing Machines
When switched on the door locks and the pump runs for a few seconds then stops and the door opens zwd 16270w
an earth fault on the motor or heater can cause this. try the heater first disconnecting it and seeing if the machine can get past the fill stage .
Jul 31, 2010 | Zanussi Washing Machines
Washing machine says door is open and stops
I would make sure the door latch and door lock are both clean and free of debris as this will cause the machine to fault out from the latch not hitting the switch properly. If cleaning it thourghly doesn't do the trick you may need a new door latch/lock mechanism.
Jan 30, 2010 | Washing Machines
My dryer runs about 10 seconds and then stops
"DO" indicates Door Open
Door monitor switch in door lock mechanism is not able to communicate to the control board is open.Try taking the following action
1.Make door is closed.
2.Check for loose wire connections at switch and/ or machine control board.
3.Check for failed door monitor switch.
4.Check inputs and outputs at machine control board.
5.Replace responsible component.
Good luck.Please do rate my answer if liked.also please post comments for further queries.
Jan 18, 2009 | Maytag MDE9700AYW Neptune 174 Electric...
Will not start
Alright, unplug the machine for 5 or 10 minutes, after plugging the machine in make sure power is off and hold the spin button down for 5 seconds, then off for 5 seconds until all lights light up, if there is serious error a F code will appear, press spin again until it clears, now 88 appears in the display,flashes and starts a diagnostic cycle. Your error will pop if serious in the display stopping the test at which write the F code down and power off the machine, Either the toe panel or at the right side behind the toe panel is a tech manual to decipher the F bomb.
Sep 05, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Door lock light flashing
Rank:guru_s.gif Guru
Rating: 87%, 146 votes
IF you machine is a wma39 not a wmm39a then what has happed is that you control board is blown basically.
TO check this remove the soap draw and you will c three screws remove them... TO make removing the panel easier i would suggest removing the top as well as the front panel is wedged into it.. Then unclip the board from the panel and you will c where the big wiring plug is attached that the tracks on the board are blown.. There is no point replacing the board untill you can work out what has caused it to blow because it will blow again.. Its usually the motor or the doorlock which blows the board.. Trust me i been dealing with this type of machine for years...
Apr 29, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
