Question about Whirlpool LSR6334LQ Top Load Washer
Washer only fills
Water seems to fill to approriate level. machine will not advance to next cycle, nor will it start if i manually move the knob to any other cycle. won't drain either and bailing it out isn't fun. we replaced the motor coupler, but that didn't help either. it seems to just shut of. there will be a slight 'hun' then a click and nothing! help!
  • Beth Schodt Jul 22, 2007
    sounds like a good fix solution, but bought a new washer this evening............will probably put it on craigslist/phoenix if anyone is interested
    thanks washer_tech
  • 164 Answers
It sounds as if its your lid switch. on some top load whirlpool washer it will fill even if the lid is open. if you open the control panel and open the jones plug you can check for continuity on the lid switch
Posted on Jul 22, 2007
Kenmore 70 Series Washer Won't advance in the
Bad timer. Try to find a used one if possible, this item is a little expensive.
Aug 23, 2010 | Kenmore Washing Machines
Washer will not cycle
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Oct 24, 2008 | Kenmore 15864/15862 Top Load Washer
Drum will not spin
I am the new owner of a used Asko Cylinda 10504.
The last owner briefly demonstrated the washer starting a wash cycle and entering the agitation cycle of the wash before stopping and pumping the water out and spinning in a final end cycle. I bought it. I had the machine installed turned it on and cannot get it to go through the wash cycle. After starting at #1 it goes through a perpetual spin cycle of sorts--water and soap soaking the drum and laundry but not enough water to fill up half way or less. It stops at number 4 on the program knob sits on a red dot (next to the #4) and does nothing. I then manually move it to the next cycle and it repeats the spin cycle again until I have advanced the program to the end. No wash cycle no rinse cycle. Nothing. When it advances to the red dot I wait for at least 5 minutes before manually advancing the knob. The instructions say that I should get the water pumped out by turning the program knob to #7 or #9 but in both cases it just spins and does no empty or finish in the end spin cycle of several (9?) minutes. Nothing but banging and spinning. The water seems to get into the drum as well as the detergent but nothing else is happening.
No mater where I start the program it spins and sloshes soapy water, pumping almost nothing out.
Any suggestions short of putting it on the curb or paying a kings ransom to fly a tech out to look at it?
MY GUESS.
It seems that it is repeating the same brief cycle over and over. During the move to my house the electronics re set(??!?!?) and now need to be set to the normal mode after being re connected?
Can you help?
Blessings,
Douglas
May 20, 2009 | Asko Washing Machines
Frigidaire washing machine gets stuck on cycles
Apr 01, 2009 | Frigidaire Washing Machines
Washer fills with water, spins but does not aggetate
LG washing machine, the water continue, not stop
Mar 15, 2009 | Washing Machines
Washer only works by manually advancing the dial.
yes this sounds like a timer it sounds like it is getting stuck in the cycle. replace the timer and this will clear up the problem
Dec 29, 2008 | Maytag SAV3710AWW Washer
GE washer does not agitate. Water does not stop filling.
If it does not agitate at all, then it is either the motor, the clutch/motor control or the agitator.
If the machine start agitating only when you advance manually the control knob, and at the same time is overfilling, that is probably because of the problem with the water inlet valve, or the water level switch, and that is also cusing the cycle to stop.
See:It's overfilling
Nov 20, 2008 | Washing Machines
Won,t drain on rinse cycle
There could be several causes for this, but probably a bad timer. One test for this...when it stops...is to turn it off...and turn the timer slightly clockwise...to the middle of the rinse cycle...and turn it back on. Does it run then?? Try advancing it to the spin cycle after the rinse. If it runs okay after you manually advance the knob...the timer is probably defective.
Jan 13, 2008 | GE WNCD2050AWC Top Load Washer
Whirlpool LSR6334LQ Top Load Washer Logo
252 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
