Question about Sanyo Televison & Video
I need a manual for sanyo LED42XR11F
I need a manual so i can enable the ARC function of my tv. I bought a new receiver yamaha and I have plugged a HDMI cable and nothing is happening! The manual of the receiver says to check the tv has arc enabled and i don't know how to do that! I know it supports ARC as the letters are on the hdmi socket
Agent Aaron
  • 265 Answers
SOURCE: Panasonic 1080p Plasma TH-42PZ80U Home Theater Setup Question
Hey Gamer1827,
While I personally can't provide you with any model-specific home theater system recommendations, there are a couple of common ways that you can generally configure your home theater.
Connecting several devices directly to the HTIB system may typically allow you to minimize the number of remote controls necessary, as long as the HTIB system supports the use of a universal remote. Should you not necessarily care if you have to change back-and-forth between two remotes however, you may have a wider variety of possible configurations available.
In order to use only HDMI cable connections to set up your home theater, you most likely would need an HTIB system with three HDMI ports: one for your TV, one for your PS3 and one for your cable box. Each device would require a separate HDMI cable running between it and the receiver. This option (in theory) would allow you to use one universal remote to control each device, assuming that they are all compatible with the same remote.
Another common configuration you might wish to try requires you to connect your cable box and PS3 directly to your TV. By doing so however, you might limit yourself to using an optical digital audio cable to make the connection between your TV and many HTIB systems. In this configuration, the cable box and PS3 would again have their own separate HDMI cables, while the optical digital audio cable would need to be run from the Digital Audio-Out port on the back of your TV to the Digital Audio-In port on the receiver. This option essentially treats the HTIB system as an expansion device, instead of the center of your home theater configuration.
Should you need any additional information or suggestions, remember that you may always speak with a sales representative at your local Best Buy™ store for further assistance.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Posted on Jun 12, 2008
dsacco86
  • 1077 Answers
SOURCE: HDMI Input only reads Digital TV and not PS3 or AV Receiver
Well, I won't take the credit of others. Many people have the same problem as you do.
In the search box on the top of this page, put in " PS3 HDMI ". The one that has the 10 solutions so far has the best answers for you.
Good Luck
Posted on Feb 16, 2009
opherator
  • 44 Answers
SOURCE: PS3 will not work on new tv using HDMI cable ?
you have to re sync your playstation when you go from HDMI to regular wires.
after you connect ps3 to tv.
hold down the power buttondown on the ps3 for like 5 seconds (1 beep then another ),
after you hear a second beep the ps3 automoatically adjusts itself to whatever it's connected to.
Posted on Feb 27, 2009
SOURCE: How to enable "Bravia Sync" on KDL-40V2500
I also have the same problem and was wondering if you ever found out the answer to this problem Peter?
Posted on Feb 21, 2010
eagle338
  • 4889 Answers
SOURCE: I have a new Panasonic
By digital audio cable do you mean optical cable? Please clarify this so that I can suggest what you can do.
Posted on Nov 26, 2010
Cana Yamaha ATS1050 be connected to a HMDI arc tv?
What brand/model TV do you wish to hook up? The TV will need either an optical audio out or a 3.5 mm stereo audio out to plug into the Yamaha soundbar.
Quick Start Guide: https://usa.yamaha.com/files/download/other_assets/4/422364/ATS-1050_qsg_U.pdf
Owner's Manual:
https://usa.yamaha.com/files/download/other_assets/2/422352/ATS-1050_om_U.pdf
Nov 26, 2017 | Yamaha Televison & Video
Can't get ARC to work with my samsung ue48hu7500
Have you checked the settings on the tv? You may have to enable the ARC functions in the setup menu.
Apr 13, 2015 | Marantz SR6006 Home theater receiver...
No HDMI video using RX-V575 Yamaha Receiver with Panasonic TV C-P60ST30
Michael, I still think it is a connection problem. Try disconnecting the HDMI and see if you get the video. If no, it is a connection problem. Check the connections carefully.
Mar 24, 2014 | Yamaha RX-V575
Connecting tv external speakers
Process of elimination... First and foremost, you didn't tell us what model Bravia TV... the RX-V model has so many plausible connections to that TV, even if there is no optical on the TV.
Would you please verify TV model, and check exact Yamaha Model, I looked for the model you state and couldn't find it.
Generally speaking... red/white is the oldest way to connect to your receiver... are you connected to the correct input? and how is the receiver to send to the tv? What is the input... cable, dvd, etc... then you select "input" then on the receiver you select OUTPUT only is labeled on the receiver. Now... let's say cable box goes into the TV, and you are wondering why no audio.. that is because you are using an INPUT on the tv white/red to the receiver.. cannot do that, won't work, only HDMI can talk both way on some HDMI input/output. The only only only way output from a TV can be done is HDMI arc ...(look up ARC) and then enable it on receiver too.... or a optical from tv to receiver, or lastly output red/white on the tv... and in some you don't have any but may have a headphone jack that you'd buy a headphone jack to red/white ... take the headphone jack plug that in.. that is output, make the input any input on the receiver and you will select that input on the remote and it'll work.
Gimme more infor and I can get you better answers :)
Feb 11, 2018 | Televison & Video
No OSD menu on Panasonic ST50 plasma TV
My guess is that the OSD function can only be enabled directly at the Panasonic TV.
Nov 18, 2013 | Yamaha Audio Players & Recorders
Verizon Fios connection issue with RX-V663 Receiver
I had the same problem with RXV3900, was told by verizon and yamaha it's a software issue with the box. Verizon is suppose to be working on a new update, but no time frame for now. I'm using component to receiver, and hdmi to tv with no issues.
Mar 15, 2009 | Yamaha RX-V663 Receiver
Connecting TV to Hi Fi wirelessly
There are several different wireless receivers that you can consider.
A simple solution would be the following:
Both devices being connected must support the ARC feature. HDMI ports may be marked with ARC to show which one to use. If not, check your product manual or specifications to see if the ARC feature is supported.
If you find that your TV, A/V receiver or home theater system does not support ARC, you will need to use Option 2: Coaxial Digital Cable, Optical Digital Cable, or Audio Cable to connect your devices.
Make sure that both devices support ARC functionality.
Make sure that the TV and receiver are connected using an HDMI cable.
Connect the cable to the HDMI port that is labeled ARC or the port identified in your manual that supports ARC.
Turn on the Control for HDMI setting on both the TV and the receiver or home theater system.
NOTE: The steps required to enable the Control for HDMI feature may vary. Check the operating instructions supplied with the devices for model-specific steps.
Apr 18, 2017 | Televison & Video
Televison & Video Logo
119 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
