Question about Samsung HCM4215W 42" Rear Projection Television
Tv won't turn on
When the power button is pushed on either the tv or remote the red timer light next to the power button lights or flashes but the tv does not turn on.tried unplugging tv for over 24 hours to reset settings and same condition still occurred
  • 1 more comment
  • edward kenney Jul 22, 2007
    found the gonvergence board,unplugged the connectors,and the set came on.it was out of focus,but it came on.took the convergence board out and will replace the convergence ic's later this week when i can get the parts. it's not fixed yet,but thankyou very much for putting me on the right track.will let you know when it is finished.
  • kloor Jan 04, 2008
    I have an akai flat t.v w/built in dvd, the t.v. just shut off i tried unplugging it fir one hour and it still did not come on the red light is on but when i try to push the power button it does not come on t.v. is one year old
  • tmrockwood May 11, 2010
    Where is the convergence board located
    President:
  • 3,130 Answers
Your problem could be the Convergence board is loading down the power supplies and will not let the TV set come on, or the power/deflection board, part number AA94-08574A, or the STR type regulator IC, part number AA13-00105A. If you locate the convergence board, unplug the connectors, and see if the set will come on. if the set does come on, replace both of the STK convergence IC's at once. The part numbers for those IC's are STK392-40. You can get the original replacement IC's from MCM electronics for about 15 to 16 bucks a piece. Do not use the less expensive STK IC's as they are not the same. the replacement IC's should have the name of SANYO printed right on the face of the IC's. Good Luck
Posted on Jul 22, 2007
  • Larry  Dillon
    Larry Dillon Jul 23, 2007
    No rating?
  • Larry  Dillon
    Larry Dillon Jul 27, 2007
    I told you where to get the parts from.
How do i locate a schematic of this tv? I probably know just enough to get me in trouble but i'm not in a position to hire someone to fix so it's either me or trash. I have the same problem but don't know which board is the convergence?? thanks
Posted on Jul 19, 2008
Hey technman,
Thanks for the instructions. In my case the power did not come on after I unplugged the connectors on the convergence board. Do I need to replace both the power/deflection board and STR type regulator IC or just one of the two?
Thanks,
Gonzagarules
Posted on May 04, 2008
SOURCE:
TV does not turn on? (Relay problem?)
The power supply could be failing intermittently. That's why it sometimes works and sometimes doesn't. Also, the relay could be erratic.
May 26, 2014 | Funai Magnavox 40" Class 1080p 60hz LCD...
Red Light Won't Stay On
1. Remove batteries from remote to "zero" it, then reinsert batteries
2. Turn on TV (RCA?)
3. Press and hold CODE SEARCH button until indicator lights
4. Press and release TV button. Indicator will blink and remain on
5. Enter code from list in instructions
6. Point remote at TV and press on-off button. TV should turn off
7. Use remote to turn TV on again and press CH+. If TV responds you're all set; if not, repeat the process with the next code
Nov 19, 2012 | RCA CRK76TE1 UNIVERSAL REMOTE - With...
Mitsubishi tv won't turn on
did you try new batteries in the remote? if the tv has buttons on the side and one of them being power di you try to push that? did you push tv power or cable power holding the buttons longer? those things might work.
Jun 05, 2012 | Mitsubishi WS-55909 55" Rear Projection...
Tv won't turn on only a red timer light appears when the power is pushed on
First press on the power button on the tv remote control. if it is also not solved then i think your tv has a internal hardware problem which may be failure of some electronic components. It will be better to take it to nearest service center
Oct 16, 2011 | Televison & Video
I have a Sharp 32"
try checking the system for timer or sleep mode operation try to setting it off
Jul 16, 2011 | Sharp 25R-S100 25" TV
Tv won't turn on or respond
if its a sony bravio LCD the backlight inverter failed
Dec 06, 2008 | Televison & Video
Blinking red light standby/timer
It seems to respond to power supply, send it to a nearby technician. The problem might be it fused the picture power supply fuse. make sure the installation is at you presence.
Sep 06, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Timer light is flashing but tv wont turn on!
When the timer light stoped flashing the remote control would not turn on the TV. The next time the light quit flashing I held the power button in on the TV for about 5 seconds and it came on and has had no problems since then with the remote or the local TV power button.
Greg Allen
Aug 29, 2008 | Mitsubishi Televison & Video
Tv wont turn on only clicks and then flashes red timer light
tv wont turn on when i hit power it makes the clicking noise like it is going to turn on, but never does and the red timer light next to the power button just flashes.
help!
trinitron kv29f1u
only clicks and blinks
Jul 26, 2008 | Sony KV-35S42 35" TV
View timer only lights
TV WILL NOT NOT TURN ON RED VIEW TIMER LIGHT FLASHES AND THEN I CAN'T TURN OFF TV
Mar 29, 2008 | Sharp 61RWP4H 61" Rear Projection...
Samsung HCM4215W 42" Rear Projection Television Logo
433 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
