Question about Kenmore 23822 Top Load Washer
I hope you can help me
I have a kenmore series 80 washing machine
(model #23822100 - Serial #CM3390701 - Type #111)
as of now it will fill with water and agitate but when it gets to the part where it should drain and then rinse and spin...it just stops. There is a clicking noise that happens when its supposed to drain. It does this on all settings. Also I checked the door button and thats fine...then i checked the hose (which had no kink in it) but when I lowered the hose (about 1 foot from the ground) water started to come out and then when I pick the hose up the water stops coming out! WTF! So I continued to take out all of the water by bringing the hose close to the floor and letting the water drain out... many pot fills of water later it was empty. Then like the genius I am I decided to try the machine again (with no clothes this time) to see if it would drain and well I'm writing you so obviously no drain or spin... just fill and agitate... what can I do?
  • brentwin Jan 30, 2009
    Mine is doing the same thing except I haven't undone the hose I just put it back on spin and restart it and then the water will drain out
  • air_ick_uh Feb 02, 2009
    Same thing is happening to us today! =o The machine filled, agitated and did not drain. Me and my boyfirend our ringing out clothes right now! What a mess! HEEEEELP!
    Problem Solver:
  • 7 Answers
Replace the coupler between the motor and pump. Coupler about 18.00 dollars at Sears parts store.
Posted on Feb 04, 2009
My kenmore 80 series washing machine makes a horrible noise and cold side fills about half speed when filling with water. What should I check?
For the slow water issue, you will need to replace the water inlet valve. Here is a link to the part.
Could you describe the noise and where it is coming from?
Oct 19, 2012 | Kenmore Washing Machines
Washer will not spin. water drains. motor runs. Kenmore 80 series mod # 23822100 please help thanks
With old washers and with new washers sometimes you have to get in there and tighten the belt or replace the belt. Your problem sounds like this to me.Your question was posted sometime ago and you probably found your problem. If not please get back to me and I will be happy to help some more. GOOD LUCK.
Aug 02, 2011 | Kenmore 23822 Top Load Washer
Fills with water and then nothing kenmore washer model 23822100 type 111
Top load machines will fill with water while the lid is open. Your problem starts when you close your lid. NOTHING happens. I believe this to be your LID SWITCH . Replace or have replaced and you should be OK. GOOD LUCK.
Jul 26, 2011 | Kenmore 23822 Top Load Washer
I have a Kemore 80 series washer model not filling properly
Check the inlet hoses for plugged screens at the faucet ends. The screens are usually replaceable if you can't get them clean in a white vinegar/hot water solution. Check the inlet ports to the washer for similar screens. Hope this helps!
Mar 17, 2010 | Kenmore 22422 Top Load Washer
Kenmore 111 stuck mid cycle with water in barrel
Try unplugging it for a hour - see if it clears..
Hope this helps !!
Jul 13, 2009 | Washing Machines
Water will not stop filling for the wash or rinse cycles
OMG! Dude, what up cuz, down here in Mobile trying to solve my own washer problem!!! Tina Wow, talk about coincidence!!!
May 30, 2009 | Kenmore Washing Machines
No cold water going into tub, valve is open
make sure the hoses are not kinked and check the screens inside the valve inlet and make sure they are not clogged
May 25, 2009 | Kenmore Washing Machines
Kenmore 23822 Top Load Washer Logo
314 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
