Question about Coleman Powermate Powermate 5000W Generator
Oil requirements for Powermate 5000
Need to change the oil and don't have an owner's manuel. Can someone tell the how much oil to add?
    Scholar:
  • 149 Answers
10-30W or a SAE30. usualy 600mls 0r 1200mls
Posted on Jan 30, 2009
    New Friend:
Thyanks
Posted on Jun 26, 2013
I am looking for an owners manual for a Coleman Powermate generator model PMO645250
Powermate doesn't have an owners manual listed for the PM0645250 on their website.
Since wintertime is a good candidate for power failures I would recommend using a good synthetic 5w-30 oil as it is a good year around oil. This would make starting much easier during the cold weather
Oct 20, 2014 | Coleman Electrical Supplies
What type of oil and weight is used to change oil every 5000 miles?
have you looked on the cap where you add the oil?...some will have the type of oil required, printed right into that filler cap...check it out
of course, you could also check your owners manual for recommended grade ..if you still have it.
Jan 07, 2011 | 2008 Toyota RAV4
I do not have a manuel could someone tell me how much oil is required when changing a 2.2 engine.
Generally in the 5 to 6 litre (quarts) range. Put in 4 litres and check on dip stick. Add remainder half a litre at a time checking the dip each time. The volume of oil required to be added to go from "MIN" mark on the dip stick to "MAX" is just half a litre.
May 02, 2010 | 2001 Pontiac Sunfire
9hp briggs and stratton engine has gasoline in the engine oil
Old gas, gone bad from sitting. Drain all gas out and use carb cleaner in unit to clean. Add fresh gas.
Oct 01, 2009 | Coleman Powermate Powermate 5000W...
Olio carrera 4s porsche
Usually the specs are located in the owners manual. It tells you the grade and amount of oil required on an oil change. If the specs are not in the owners manual, you can look at the oil fill port on the engine and normally has the recommended grade of oil. Otherwise, see if you can get your hands on a service manual. Good Luck.22
Jun 13, 2009 | 2007 Porsche 911 Carrera S Coupe
Maintance light
To reset your maintenance reminder system (even if the light hasn’t come on yet), you’ll need to turn your key to on (but don’t start!) and make sure your odometer is on TRIP A. Then key off. Press and hold the Odometer/Trip button. While holding down on the button, key the ignition to on (Don’t start the engine!) The display panel will count down from “------“ to “-“Continue pressing the button until the Trip A is displayed.
Mar 28, 2009 | 2007 Toyota Tundra
How often do I change the oil in my new Lincoln MKX ...every 2000 km or every 5000 km?
The owner's manual calls for changing oil and filter every 7500 miles in normal service, or if driving in dusty conditions, offroad, or lots of low speed and idling (a taxi or maybe an unlucky commuter), go to the extreme service intervals of 5000 miles. Changing oil every 3000 miles is definitely NOT required.
Dec 15, 2008 | 2007 Lincoln MKX AWD
What type of oil for a Coleman 5000 Generator?
You need a quart of regular old SAE 5W30 motor oil with detergent.
The engines on these generators are more or less the same as a lawn mower.
Don't forget to service/change the air cleaner when you change the oil, that should keep your generator producing full power.
Regards,
Carl
Dec 14, 2008 | Coleman Powermate Premium Plus 6250W...
Oil for Coleman Powermate 5000 PM0545305.03
Yes, SAE5W30 is just the right oil for this machine,it will take about a quart to fill it up to the bottom of the threads in the oil fill hole.
The engine of this generator is essentially just like a lawn mower with a fixed throttle setting. You should expect all of the same issues as any small engine that's been sitting for a while. Check the fuel tank for water/debris, check the carb for fouling, check the spark plug, etc.
If the generator has been sitting for 3+ years without running you may need to flash it to get any voltage out of it. If you get the engine running and it won't make any electricity ask me directly and I'll talk you thru the procedure.
I looked on www.powermate.com for an owners manual but they only seem to have the parts list, rats.
Regards,
Carl
Dec 13, 2008 | Coleman Powermate Powermate 5000W...
Coleman Powermate Powermate 5000W Generator Logo
1,014 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Phil Walker
Phil Walker
Tim Garcia
Tim Garcia
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
