Question about Honeywell Programmable Thermostat Heater
Readings disappear on thermostat for awhile then come back
This is a Honeywell nonprogrammable thermostat. This is a vacation home. Temp was set during our absence at 51 degrees. When I visited the house I turned the thermostat up to 64. I happened to look at the thermostat about one-half hour later and the readout was blank- nothing on the dial. Later the numbers came back into view and the heat was working.
Should I worry that the thermostat is not reading the room temp if/when the readout goes blank? W/o heat, the house pipes will freeze. If needed, I'll call a repairman to replace the thermostat unless the readout has nothing to do with the thermostat sensing the temp. This happened once before but it lasted just a few minutes. In both cases when I noted the readout was blank, I did not notice if the heater was running.
Linda
  • Troy360 Feb 14, 2009
    My house is starting to get cold but the buttons don't work and the numbers dissapeared. Should I be worried?? Or will it come back on all on it's own???
    Problem Solver:
  • 12 Answers
Hi Linda,
There are a few things that cause this:
  1. When the heat is starting, it will sometimes go blank for a few minutes and then resume.
  2. Most have batteries, replace them with fresh new ones, if the electricity goes out while you are away, the batteries will keep the settings.
  3. Have someone check the house when it is extremely cold or hire a service to monitor. Your alarm company can usually add temperature sensors to your home, it will add a little safety net for you.
Hope this was helpful, please rate my answer.
Thanks,
Paul
Posted on Jan 28, 2009
Time and vacation symbol flash-all buttons non responsive - how do I fix
Hello there,
Are you SURE the floor temp sensor is wired correctly Page 8 of the Manual ???? It should be across 1 and 2 . if it was on the number 2 and 3 connections, this would simulate a 'remote switch' check the wiring of the floor sensor carefully in the back of the unit.
Something odd about the 'Vacation'mode' setting. You said it has no remote switch but only this 'remote switch' can disable it. by going open circuit. which sounds suspiciously like something is across pins 2 and 3
Time flashing is 'Temporary override'
Read page 16 AND 17 (flashing as you say) of the user manual
https://customer.honeywell.com/en-US/pages/product.aspx?cat=HonECC%20Catalog&pid=TH115-AF-GA/U
Click literature and download.
Sep 22, 2014 | Honeywell Aube TH115-AF-GA 7-Day...
Tip
Honeywell TH8320U Thermostat
The Honeywell Vision Pro 8000 Digital Thermostat is a fully programmable thermostat that is so easy to use that you might think that it is reading your mind as you work with it.
This intuitive logic responds to you as you program this thermostat and helps you to do what you wan to do. The instruction manual almost becomes a thing of the past. This thermostat also will learn your building and HVAC system. It then adjusts to keep your temperature within 1 degree F of the set point. This will give you the best in comfort. The comfort is achieved while still giving you the very best is efficiency. In some cases efficiency has been increased by up to 30% by simply installing this thermostat.
The fan can be programmed separately for increased comfort when running an electronic air cleaner or a humidifier. A 35% circulator mode is also available. Hold options will let you easily go on vacation or temporarily override the programmed settings. The vacation setting will even let you set it to go back to the schedule before you get home. There are also built in reminders for many of the things that need scheduled maintenance.
If you are thinking about or have a dual fuel set up or a heat pump furnace set up, then this is the thermostat for you. With the addition of an outdoor sensor you can set the thermostat to switch from one heat source to the other at whatever temperature you set.
This feature will eliminate the need for “change over kits” extra relays, etc… when you are setting up a system that has a backup heat source.
This thermostat will also allow you to run it from the power of your HVAC system or run it on battery power. Just hook up the common wire and the thermostat will run off of your HVAC system. The changeover of the unit from A/C to heat can be programmed to be either manual or automatic. Scheduling of the program can be done in many different ways. You can decide between 1 day, 7 day, 5+2, or 5+1+1, day. Four periods, 2 periods per day or nonprogrammable are all options also.
The keyboard can be locked completely or partially. With the purchase of additional sensors you can wire up remote indoor sensors. These can also be wired to average the temperature is you want to sample the temperature from more than one place. An outdoor sensor can be installed so that you can see from your thermostat the outdoor temperature.
A five year manufacturers warranty is standard and you will also get a thermostat that has earned the energy star rating.
http://www.fixya.com/support/r3869033-replacing_thermostat
http://www.fixya.com/support/r3623083-thermostat_wiring_terminal_designations
http://www.fixya.com/support/r3894275-manual_honeywell_find_honeywell_manuals
on Jan 18, 2010 | Heating & Cooling
Honeywell TH5110D1006 FocusPRO NonProgrammable Thermostat Is there any trick that can make it so I can keep a child from messing with the thermostat Anything even if its just disabling to buttons We leave...
I believe you can set a range stop in installer mode, the instructions are here but if you have difficulty ask your installer as if you don't know what you are doing you could stop your system working by changing the wrong settings in installer mode.
https://customer.honeywell.com/resources/Techlit/TechLitDocuments/69-0000s/69-2021ES.pdf
Apr 02, 2014 | Heating & Cooling
How do I set the temporary or permanent override feature on the Honeywell RTH2310B model thermostat?
To set the temporary override, press arrows up or down to desired temp. This will keep temperature
at temporary setting for 2 hours then return to programming. To permanent override press MODE button until schedule period number disappears (number inside little house on stat). Then adjust temp with arrows. Press the MODE button again to cancel override and return to programmable.
Jan 25, 2011 | Honeywell Programmable Thermostat Heater
My nonprogrammable Honeywell thermostat th5110D is no matching temperature settings (desired and actual). There is about 4 degrees difference. I have looked at the manual and reset the system and changed...
Your thermostat is reading the temperature where it is located.
If it is located next to a heat source maybe it is picking up that added heat .
Try relocated your thermostat
May 30, 2017 | Heating & Cooling
My thermostat is set to 73 degrees when i get home at six it is set at 75 during the day when im not home the past couple of days it wont get to 73 it actually goes up to 76 77 it is working cool is on why...
may need charged a out of adjustment can cost lots is it old unit is outdoor temp. very hot may have trouble catching up to setpoint.on a 95 degree day good luck.
Jul 07, 2010 | Honeywell Electronic Programmable...
I have a Honeywell programmable Thermostat (an expensive one that handles humidity, etc) and every spring and fall the thermostats behave improperly by ignoring the programmed temperature and cooling the...
What is the model number of the thermostat? What may be happening is the humidity control is trying to satisfy the humidity setting by running the a/c. In the installers set-up, there should be a setting to determine how long the system should run to satisfy humidity setting. I typically set thermostats for a 3 degree droop. Meaning it'll only drop 3 degrees below set temp. Also check your humidity setting to be sure it's not set too low. It should be set between 45% and 50%.
May 03, 2010 | Honeywell Programmable Thermostat Heater
The unit says the indoor temp is 5 degrees higher than the actual temp in the house. Is there a way to calibrate the temp?
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Feb 07, 2010 | Honeywell Programmable Thermostat Heater
Hello. Our RTH230B thermostat has a mind of it's
I think your feedback temp sensor has faulted, get it looked at.
Jan 24, 2010 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
592 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
