Question about Empire DV-35 Heater
I need to convert my DV35 2Sg from LP to natural gas what parts do I need or who do I call for the part
2 Suggested Answers
  • 15273 Answers
SOURCE: Empire Mod#UH-1250-1FSP Ser # K49789WR
need to notify empire their specs for their natural gas should have the answer the kit or conversion unit should have had the part -it might not need to be changed--but if it does info needed is size of heater btu's size of line what kit/gas valve unit ur using
Posted on Jan 25, 2010
Tip
Changing your gas appliance from natural gas to LP or vice versa.
You have an LP gas stove which you really like and would like to take to a new home but the new home has a natural gas hookup. Since natural gas is already available it would be convenient to be able to use it. Can you convert your unit over to work on natural gas?
Yes it is possible to convert any LP gas appliance to natural gas or from natural gas to LP. The only difference is the size of the orifice used in the burner.
LP gas is composed of a much larger molecule than natural gas and requires a larger orifice to output the same amount of gas as a natural gas unit at the same setting. Therefore if you used an LP stove on natural gas it would produce too much heat and burn rather intensely. If you used a natural gas stove on LP it would not have much flame at all. You can see the problem. The solution is also obvious. You need the correct orifice.
Changing the orifice is easy. It is located in the middle of the burner and unscrews out of the unit. Install the new one the opposite way. Do not overtighten it.Usually the burners are made of soft metal and can strip easily.
The parts you would need are available at most good appliance stores but I would recommend the following site http://www.repairclinic.com . The parts will be cheaper at repairclinic. They have parts for almost any brand and a great search engine. They also have excellent videos showing how to make the repair.
Thanks for using FixYa and for the great rating.
hardrocko
on Dec 10, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
How do I convert from liquid propane to natural gas
You need parts from the manufacturer. The gas orifices are different sizes between natural gas and LP gas. If you try natural gas with an LP gas orifice, you will not get much flame. If you use LP gas with a natural gas orifice, you will burn off your eyebrows and possibly other things.
Dec 19, 2013 | Capital Cooking Titanium X CCE26XRBI (NG)...
Hi: I purchased a GE used dryer model #WSM2780DBWWW. It had been converted to LP. Now I want to convert back to natural gas. Can you tell me the parts I need to order to go back to natural gas. ...
You will need to replace the orface the one for the LP is smaller and won't let enough gas out. LP has a lot more presure. Best to take your model # to an appliance parts store and get the right one.
Dec 05, 2010 | Dryers
Converting Weber from LP to Natural Gas
On the weber model you need to purchase the natural gas model. It will cost you alot more to buy all parts needed to convert. Weber doesnt want you to convert do to safety reasons. This is why they will only tell you you can't convert. Buy the right grill and save yourself a headache.
Jan 19, 2010 | Weber S-420 (NG)
We have a dynna glo zero clearance for Natural Gas
Before you attempt to covert to lp. You need to check the flue. Black smoke is cause by incomplete combustion. So it may be now plug with black soot. Heat-exchanger may be damage Before you invest in a lp kit. Make sure it is worth it. To convert you need the main burner orifices and lp spring for gas value. Once you replace these parts you must adjust gas pressure, nat gas is measured at 3.2 - 3.5wc lp is measured 10.5 - 11.00 wc. In my honest opinion this is to dangerous for customer to attempt. Please a HVAC contractor inspect unit and install lp kit.
Nov 20, 2009 | Dyna-Glo D-E37 Wall Mounted Panel Heater
I converted my 40'' Figidaire range to LP a few years back when I did not have access to natural gas. Now I need to convert it back. I do not still have the old parts and there seems to be no ''Natural gas...
I am having almost the same problem. Frigidaire told me to replace all 5 mixing tubes, ~$385, yeah right. They don't have the orifices itemized as an individual part, so no-one carries them, just the LP conversion kit. Another repair/parts guy advised me to drill out the orifices. Some other threads/blogs give the diameter to drill. Basically, since natural gas is 0.5 psi, you need a larger hole than your current propane orifices provide. Please speak up if you find out anything, I will try to do the same. Good luck.
Sep 25, 2009 | Frigidaire PLCF489AC Dual Fuel (Electric...
Converting a GE Profile Gas Range from LP to natural gas
GE ships gas ranges set for natural gas, with the LP orifices included, usually on a metal tab held with one screw right near the regulator (where the gas connects to the range). If the range was converted to LP, the person who did the conversion was suppose to put the natural gas orifices back in that holder. If they are missing, comment back on the exact model number and I can look up the part number(s) for you.
Jan 06, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Converting Dacor ERD30S06CH/LP/H to Natural Gas
I know they won't convert gas water heaters but I didn't know they were afraid of stoves. See if your gas company will help. Sometimes they can drill out the orfices. Some of the older repair people still remember how to do this. The orfice for natural gas is larger as the pressure is a lot less. The gas pressure regulator will also need to be replaced. This can be done with a generic part.
Jul 12, 2008 | Dacor Preference SGM365SS Gas Cooktop
How to convert from LP back to Natural Gas?
I have an old Kenmore dryer that I need to convert from LP to gas. I have the parts but no instructions. Can you please help?
Thank you, Roxanne
Mar 06, 2008 | Maytag Neptune MCG8000AW Gas Dryer
Empire DV-35 Heater Logo
75 people viewed this question
Top Empire Heating & Cooling Experts
Paul Carew
vance jones
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you an Empire Heating and Cooling Expert? Answer questions, earn points and help others
