Question about RCA RCR311B Remote Control
I have a Hitachi T.V and a Toshiba DVD
I can get the DVD player done but not the TV Can u help?
All done thank u
Posted on Jan 28, 2009
Hitachi DV-PF 2U dvd player works fine when hooked directy to TV (channel 3) but won't work when connected through the new COX digital cable box. TV is set to channel 4, dvd player turned on, disc...
If the cable box needs to be set to 4, the TV will need to be set to 4 as well as the dvd player. The hookup should be cable box to dvd player to the TV for your system to work. Let me know if you have any other questions. Thanks.
Dec 30, 2010 | Hitachi DVD / VCR Combo
Have a Toshiba hlv87 tv/dvd combo that will not eject a good dvd
I've had the same problem. I called Toshiba support and all they could say was to unplug it. Since I already had done that, they were going to send a service person over for a couple hundred bucks (which they get a cut of) to take it apart. Haa
Aug 02, 2010 | Mintek LCD TV Progressive Scan DVD Player
I need the code to program my hitachi remote control to a SDV290 Toshiba Dvd player?
1.Turn on the component to be programmed, such as the television or DVD player.
2.Press the "Code Set" button on your Hitachi remote. The button is often located near the top with the separate component buttons.
3.Press the button for the component you wish to program with the Hitachi Remote(TV,DVD).
4.Enter the manufacturer's code for the component being programmed. The manufacturer's code can be found either in the Hitachi manual, the manual for the component being programmed or on the website of the manufacturer of the product.
5.Press the "Enter" button to submit the manufacturer's code.
6.Press the power button for the component being programmed. Make sure the remote is pointed at the correct component, and it should turn on if the program was entered correctly
Thanx
Jul 29, 2010 | Hitachi CLU-5713TSI Remote Control
Hooking up to a sony tv need to know were the wires go and is there any set ups to be done
cables go from dvd player/vcr OUTPUTS to tv's INPUTS,
Then turn tv to Input or AV channel and you should be good.
Apr 19, 2010 | Hitachi 168589 DVD Player/VCR
I need to know how to program my CLU-5729TSI to run my Philips DVD player DVP1013
I have Hitachi universal remote CLU - 5729TSI how can I Program it to change the code for a different tv. a toshiba 36 inch it is around a 1999-2000 model.
Sep 27, 2009 | Hitachi CLU-5713TSI Remote Control
When connecting dvd to hitachi 42hdm12a, screen said something was corrupted. Now, can't get picture. HDMI searching but won't get picture. help
1.Press [stop]button on DVD player to Stop DVD Playback
2.Press the [resolution] button on the DVD player.
3.change resolution to 480p
if you get a picture in 480P, continue your setup of the DVD player
If you still have no picture perform the next steps (stop at the step if you recieve a picture):
4. verify the video input of the DVD player to the TV and reselct it on the TV
5. use Video cable to verify the DVD player is still working
6 disconnect/reconnect HDMI cable to TV
7. power off/on the TV
8. power off/on the DVD player
7.
5. turn off TV then Tunr
Jun 24, 2009 | Hitachi 42HDM12 42 in. Plasma Television
Hitachi dvd cam dz-gx5060e
try dvd in other players just to be sure it's not a issue with certain dvd players-i'm pretty sure hitachi only uses - dvds make sure this is correct-best compatibility will be w/-r's
May 19, 2008 | Hitachi Video Cameras
46w500 hitachi tv-dvd
My Hitachi 46W500's DVD tray will not open. My son about 2 - 3 years ago said he had done something to he tray that may have caused this, is there any way to fix it at home ?
Jan 10, 2008 | Hitachi 46W500 46 in. TV/DVD Combo
NEED TV CODE TO REPROGRAM MY REMOTE
Hi
Had the same problem but found a similar looking remote for the SDV593SU online and the codes work!
http://tv.manualsonline.com/manuals/mfg/toshiba/sdv593su.html
Cheers!
Michele
Nov 08, 2007 | Toshiba SD-V392 DVD Player/VCR
Can I control my DVD player from this remote and how?
Probably only as long as it's a Toshiba dvd player, can't say i've ever got one to work even the TV hansets with dvd controls. This is what the site says it works with:- This replacement remote will operate all functions of models 32A33, 32A43, 32AF43, 32AF44, 35AF44, 35A44, 36A43 and 36AF43.
Dec 21, 2006 | Toshiba CT-90157 Remote Control
RCA RCR311B Remote Control Logo
21 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
