Refill staples impega hd111 - Office Equipment & Supplies
Place the stapler horizontally in front of you, as though you were going to feed in paper from the right-hand side.
On the left of the stapler you will find the staple strip - the metalic box with two small holes in the top. Push the stable strip to the right and tilt upwards to release it. You should now be able to pull it out to the left.
Remove the staple strip completely, and place the new staples onto the track above the spring.
Re-attach the staple strip by reversing what you did to take it out. The end of the staple strip should sit across the track in the same way as the staples. Be aware that this time there will be more resistance as the staples push against the spring in the staple strip.
Jan 22, 2013 | Office Equipment & Supplies
Savin C3030 copier. refilled staples, but copier thinks empty. How can I get the copier to sense the staple refill?
There is a sensor that tells the machine if there are staples present. Check to see if it has been moved out of position or if the wire going in has been broke or crimped
Mar 29, 2012 | Savin 8035e Copier
WHERE do I open it to refill it??
Located on the end opposite of where the staples come out, there is a spring loaded cap. Push it in toward the base of the stapler and slightly down to release the retaining hook. then let the spring release the pressure rod and pull it out. Connedted to the end of the rod you will see a plunger that is shaped like a short run of staples. Make a mental note of how and where this plunger slides into the base of the stapler. Place a run of staples into the stapler in the same manner that the plunger fits then replace the plunger into the same place following the run of staples. Compress the spring into the stapler and attach the hook as it was. Now you are ready to work.
NOTE: If you cannot compress the spring enough into the stapler you have inserted too many staples, just remove some of the run of staples and try again.
Nov 12, 2010 | Arrow T50P ARROW STAPLE GUN
Canon Imagerunner 3035. refilled staples, but copier thinks empty
frst: did you set the staples according to the instructions?
second: try the few times remove and insert staple cartridge in and out, until you heare the loading clicks.
third: check the staple holder for damadges or residuals of staples.
Jul 31, 2010 | Canon imageRUNNER 3035 Black and White...
Error 116-364
Error 116-364 Problem with the Xerox WorkCentre Pro 123/128 Copier Finisher Staple Refills Copier. Dear i am also facing the same problem, It would be very helpful if you share the solution you may had come across. Thank you very much .
May 17, 2010 | Xerox WorkCentre Pro 123/128 Copier...
What size staples does the B&G Powershot staple gun use? I bought a refill pack 3/8" & 5/16" long. They fit but the shank when pulled out and loaded with staples won't close. Thank you. Julia Carr
Hi Julia,
You have the right size staples. The problem is the length of the refills. Some staplers can't accommodate a full length clip.
Break the staple refill clip in half, then insert it. The shank will be able to close and latch that way.
Best regards
Mike
Dec 06, 2009 | Black & Decker 5700 Powershot Forward...
There's a jammed staple but I can't figure out how to open it to fix the problem and refill it
This is how it works on the Arrow staple gun. On the back bottom, opposite end from where the staples come out, there is a little plate. Push it in and it unhooks and pops out. attached to a rod. When you refill with staples, just push them in, then put the rod back in and the spring applies the pressure.
May 31, 2009 | Staples Swingline® 36115 Staple Guns Tools...
Loading staples
Hi Sharon. It is absolutely essential that you get the staples designed for this stapler. These are Powershot 5700 staples.
please mark this answer as a fixya! thanks.
Mar 12, 2009 | Black & Decker 5700 Powershot Forward...
jasbo
jasbo
