Question about GE Marquette Eagle 4000 Vital Signs Patient Monitor with Ecg Nibp SPO2
Hi to all, any one can help me? what is the service mode password of Dash 4000 monitor
F 56-2 ERROR CODE
Key Operator Mode
To the Key Operator
The key operator is trained to handle all special key operator functions that are not
accessible to the general user, such as monitoring overall copier activity, machine
performance, and service information; modifying machine settings; and controlling user
activity, for billing purposes.
A unique 4-digit key operator password is normally set by service at installation. If the
unique code is not set by service, the copier will not display Key Operator Password
Entry Screen when the Key Operator mode is being accessed, and a key operator
password will not be required. A service-set 8-digit ECM master key code must be
entered by the key operator to access the Electronic Copy Monitor functions, and a
service-set 4-digit Weekly timer master key code must be entered by the key operator to
access the Weekly timer functions.
To ensure the security of Key Operator mode, it is recommended that you establish a
unique key operator password, along with the key operator ECM master key code and
Weekly timer master key code, and keep them in a confidential file.
r HELP is unavailable in the Key Operator Mode
Key Operator Mode Screen 2
NOTE: The function number [12] Call remote service center and [13] Save ECM data to memory card on the
Key Operator Mode Screen will be dimmed and cannot be selected on the copier without the remote
diagnostics activated.
Key Operator Password Entry Screen Key Operator Mode Screen 1
Key Operator Mode 13-3
Key Operator Mode
To the Key Operator (continued)
How to Access the Key Operator Mode
1 First, be sure the copier power switch is OFF.
2 Then, turn power back ON while pressing the [HELP].
The Key Operator Password Entry Screen displays when the 4-digit key operator
password is set by service.
Otherwise, the Key Operator Mode Screen displays without the password
requirement.
3 If the Key Operator Password Entry Screen is displayed, use the keypad on the
touch screen to enter your 4-digit key operator password; then touch OK, to display
the Key Operator Mode Screen. (See note.)
If the key operator password is not valid, check with your service representative.
4 To display menus [11] to [13] of the Key Operator Mode Screen, touch the lower
arrow key. To return the menu [1] to [10] of the Key Operator Mode Screen, touch
the upper arrow key.
5 Make setting changes from the Key Operator Mode Screen, as described on the
following pages.
NOTE: If an invalid Key operator password is entered, continue by entering the valid 4-digit password.
13-4 Key Operator Mode
Key Operator Mode
Function Menu Map
FUNCTION MENU SUB FUNCTION MENU AND SETTING OPTIONS
[1] Initial setting [1] Copy mode: [RADF; 1-1; 1-2; 2-2; 2-1]
[2] Copy density: [AES; manual]
[3] Lens mode: [AMS; ratio 0.33~4.00]
[4] Paper tray: [APS; trays 1, 2, 3, 4, 5, or Multi-sheet bypass tray]
[5] Output: [sort; group; staple-sort]
[6] Staple: [Normal 1 position left; Normal 1 position right;
Normal 2 positions left; Normal 2 positions right; Upsidedown
1 position left; Upsidedown 1 position right; Upsidedown 2
positions left; Upsidedown 2 positions right]
[7] Image scan: [Normal mode; High mode; Very High mode]
[2] Lens mode ratio [User Set ratio]
[3] ECM [1] ECM Password and User name setting
[2] ECM Count limit setting
[3] ECM Count Reset
[4] ECM On/Off Setting
[5] Copy-Limit-reached effect
[4] Lock/delete [1] Lock Job memory
job memory [2] Delete Job memory
[5] Paper type [Recycled; Colored; Letterhead; Special; Labels; Invoice; Legal;
Ledger; Blank]
[6] Control panel [Dimmer; Brighter]
contrast
[7] Key operator
[5-digit number]
Tel. No.
[8] Weekly timer
[1] Weekly timer On/Off setting
[2] Summer time setting
[3] Date & Time setting
[4] Timer setting
[5] Timer action On/Off setting
Feb 22, 2013 | Konica Minolta Copier Toner 7055/7065...
I can't logon to my Sensaphone IMS-4000 Host as I have forgotton the password
You will need to log in to the IMS-4000 through the serial port using a terminal Emulator such as Hyper Terminal, Putty or Tera Term. Option Number 9 on the menu will enable the Default User acct. This will allow you to login with the default Username: admin Password: ims4k
Once logged in, make the correct changes to your existing profile.
If you need more information here is a direct link to the manual:
http://www.sensaphone.com/pdf/LIT-0064_IMS-4000_Manualv3.0_WEB.pdf
Sep 16, 2011 | Sensaphone IMS 4000 Host Unit (IMS-4001)...
Y there is svc tire monitor in 2008 pontiac g6?
Hi, check all tire pressures, they need to be as close as possible to what the door panel/jam list for recommend inflation psi. If not this service tire monitor will light on dash.
May 17, 2011 | 2008 Pontiac G6 Sedan
I need the service password to reset the unit to factory defult setting
hi,
remove the AC power. then remove the battery from the machine. reinsall the battery after 15 minutes. then power on. it will be at factory settings. if u need its service manual pls contact me through fixya . for removing battery watch the pictures bellow.
ok
Jan 09, 2011 | GE Marquette Eagle 4000 Vital Signs...
Lost power on password toshiba portege 4000
The only solution is to take the computer to a Toshiba Authorized Service Center to have the password reset. If you have registered ownership of the computer with Toshiba they will be able to help you for a fee.
Hope it helps.
Aug 29, 2009 | Toshiba Portege 4000 Notebook
Need ecm code for konica 7055 or a reset code is there an override code?????
Key Operator Mode
To the Key Operator
Key Operator Mode
requirement.
following pages.
Key Operator Mode
Function Menu Map
[3] ECM Count Reset
Ledger; Blank]
contrast
[7] Key operator
[5-digit number]
Tel. No.
[8] Weekly timer
[4] Timer setting
Jul 23, 2009 | Konica Minolta Office Equipment & Supplies
Kyocera Copier Password (KM-4050)
The factory default password should be 4000. If thast doesn't work you will have to reset or display the admin password in service mode.
To enter service mode hit the ststus button and then type 10871087. Scroll through the menu with the * and # keys. If you make changes in service mode and do not know what you are doing you can cause the copier to permanently fail.
Nov 14, 2008 | Kyocera Copystar CS-1820 Black and White...
T-mobile dash
How to re-est T-mobile dash if you forgot security password !!!!!!! first turn off your device,then keep press both tow minus - - button (under neath screen ) and the mean time press one time power button then release the button after that when screen comes up press green call button one time. then wait for complete the process and then after finish press ok .remeber your all personal deta will be erase after the reset .
best regards
Oct 05, 2007 | T-Mobile Dash Smartphone
GE Marquette Eagle 4000 Vital Signs Patient Monitor with Ecg Nibp SPO2 Logo
Top GE Medical Experts
Electro Med Services...
Are you a GE Medical Expert? Answer questions, earn points and help others
