Question about Samsung SCX-4216F All-In-One Laser Printer
Cru prints meaning - Samsung SCX-4216F All-In-One Laser Printer
What does CRU Prints mean?
cru means customer replaceable unit so i assume that is the number of prints used or the number of prints left on the unit
Feb 04, 2016 | Samsung SCX 4200 All-In-One Laser Printer
Faded black
Hi Evan Z,
Not quite sure what you mean faded black.
Is the print faded at one side or overall the page?
Now think if it's faded on on seed then it's possible that it could be a build up of toner on the laser head unit. If it's an overall faded page then look for possible poor connections on CRU's.
Check the other working CRU's do they look the same? Don't start turning rollers the opposite way they would normally rotate.
Finally a light overall image can occur when the developer tank has seized up, or a broken drive gear, effectively starving the developing system of fresh replenished toner.
All developer tanks regardless of colour work in the same way, perhaps a slightly different shape as to avoid incorrect fitment.
if in doubt goto the www.xerox.com website and seek more help there.
Good luck.
Sep 01, 2013 | Xerox Phaser 6130 Laser Printer
What does the term Grand Cru mean on a wine bottle?
Grand Cru is considered the highest classification of French wine. This term is used to refer to wine either by the plot of land where the grapes are grown or by the Chateau where the wine is made.
Feb 03, 2013 | Wine & Spirits
How to solve CRU Fuse error ?
Check the TONER Cartridge and Reinstall it
CRU Fuse Error
Means : The toner cartridge is not installed correctly
You can set the machine to ignore the “[Toner Empty]”
message and to continue printing incoming faxes.
Ignoring the Toner Empty Message
1 Press Menu until “Machine Setup” appears on the display.
2 Press the scroll button < or > until “Ignore Toner”
appears on the bottom line and press Enter.
3 Press the Scroll button < or > to select “On” or “Off”.
Select “On” to ignore the [Toner Empty] message.
Select “Off” to stop printing incoming faxes when the
message appears. This is the default setting.
4 Press Enter to save the selection.
5 To return to Standby mode, press Stop/Clear.
Jan 21, 2010 | Samsung SCX 4521F All-In-One Laser Printer
CRU Fuse Error
xeregtei bna aa nadad ogooch pls
Sep 30, 2008 | Samsung ML-2510 Laser Printer
Problem with printing
CRU Fuse Error The toner cartridge is
not installed correctly.
Install the toner cartridge
correctly. See “Replacing the
Toner Cartridge” on page 8.4.
www.zinetic.o.uk
Sep 04, 2008 | Samsung SCX 4521F All-In-One Laser Printer
CRU Fuse Error
you need to replace the toner cartridge and or the fuse on the toner cartridge
http://www.websitetoolbox.com/mb/copierquestions
Apr 16, 2008 | Ricoh AC104 All-In-One Laser Printer
Xerox xc1020
is it a printer/copier?
yes....do both prints and copies off the glass come out black?
yes...probably a problem in the drum/ CRU area
No- prints OK but copies black lift the lid and watch the exposure lamp...does it light up? does it move? Both of these scenarios would usually bring up a fault code, so I would still be inclined towards the drum unit.Pull the unit out and make sure no paper has sneaked up between the drum and the exposure slot, or even into the drum unit. another cause could be a broken corotron wire (very thin wire close to the drum usually behind a grid (charge grid) If it is a customer replacement drum unit (CRU) the charge grid will be built into the unit and will require the whole thing replacing.......
Dec 27, 2007 | Xerox CopyCentre C20 Black and White...
Double page copies and CRU Error
CRU Fuse error equates to a problem the machine has reading the print cartridge installed in the machine. It has nothing to do with the fuser.
Suggest that you change the print cartridge.
Oct 01, 2007 | Samsung SF 5100 Laser Printer
Samsung SCX-4216F All-In-One Laser Printer Logo
305 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
