Question about Ricoh Aficio 2016 Black and White Copier
Cannot detect tray sensor ricoh aficio 2016 - Ricoh Aficio 2016 Black and White Copier
SOURCE: Ricoh Aficio 2045 error code sc 502
sc 502 is the problem related to tray lift motor .open the backside of the machine ,almost downside u ll find one spring broken .replace tat the tray will start working.
Posted on Jan 21, 2009
  • 1257 Answers
SOURCE: Error code
Follow this article to fix the issue.100% Guaranteed
http://social.technet.microsoft.com/forums/en-US/itprovistahardware/thread/bd9763de-6141-45ea-990b-70c207fe3fb6
Posted on Mar 22, 2009
NALDZ
  • 38 Answers
SOURCE: Ricoh Aficio 2016 memory is full - can't fax
try enter 5-810
Posted on May 13, 2009
SOURCE: Ricoh Aficio 1075 - Change paper size on TRAY 1
you need to set the dial on the back of the paper tray
Posted on May 21, 2009
  • 1294 Answers
SOURCE: Ricoh Aficio 240W is limited to bypass tray use
Enter into service mode:
1.Press the clear modes key.
2.Enter 1-0-7.
3.Press the clear/stop key for more than 3 sec until the service program menu appears on the touch panel.
Select paper tray setting,and set the new value.
Posted on Aug 02, 2009
How do i clear code sc322 on nashua aficio 2016
Code SC322: Laser synchronization error
The main scan synchronization detector board cannot detect the laser synchronization signal for more than 5 consecutive 100 ms intervals.
Causes:
• Poor connection between the LD unit and the BICU board
• Damaged cable between BICU and LD unit
• LD unit out of position
• LD unit defective
• BICU board defective
Error Codes Ricoh Aficio 2016
Jan 04, 2015 | Office Equipment & Supplies
Why Ricoh aficio 2016 asking for toner when toner is full
please check that the toner unit is not choke with toner,
again, check if the toner motor is rotating,
also check if the buttom of the toner unit is designed to fit the toner motor.
finally check the td sensor .
this may be the major cuase of this problem.
good luck.
Jul 16, 2014 | Ricoh Aficio 2016 Black and White Copier
What does 'SC726 Problem with finisher' mean on a ricoh aficio 2022
sc726 is a finisher lift motor error. The lift motor could be bad, or the sensor that detects where the motor is might be bad. It could also be an overload problem, if something is in the way preventing the shift tray from lifting.
Aug 12, 2011 | Ricoh Aficio 2022 All-In-One Laser Printer
J'ai un ricoh mp 1600 apres un bourage j'ai un message d'ereur sc 559 comment faire
The exit sensor and
the duplex sensor
detect a paper jam 3
times in succession
Paper jams can occur for the following
reasons.
???? Dampness
???? Paper curl
???? Incorrect paper setting in the paper
tray
???? Stripper pawls coming apart
Apr 22, 2011 | Ricoh Aficio MP 1600L Black and White...
I have a Ricoh/Aficio 2015. My problem is with the paper tray. I filled the tray and sled tray back. But the paper or the tray is not detected.
This copier has a motor to lift the tray. Or the engine is defective or springs are broken. It is not the first time this has happened in these models. In all cases you will need to call technical assistance.
Reply any questions, ok?!
Jan 28, 2011 | Ricoh Aficio 450 Copier
I have some ricoh aficio 1224c with errors c481
SC481
Transfer belt mark detection error
• The main motor is operating; and
the lock signal is detected. → The
belt mark sensor signal does not
change for 120 milliseconds.
• Defective main motor
• Image transfer belt out of position
• Belt mark blurred or absent
I would remove the pcu unit (3 screws)and check the transfer assy belt mark and clean the sensor that reads the belt mark. Worst case senerio is replaceing the entire pcu unit.
Mar 07, 2010 | Ricoh Aficio 450 Copier
Ricoh SP c222sf is not recognizing that there is paper in Tray 1 or bypass - tried to rest tray 1 and turn on/off, but the display still shows that there is no paper. What else can I try?
There is a paper detect sensor which sits in the frame of the machine above the paper tray. Pull the paper tray out and make sure this sensor didn't get broken or knocked out of place. (If you have a can of compressed air, shoot some into the sensor to get rid of possible paper dust.)
Mar 07, 2010 | Ricoh Aficio SP C222SF All-In-One Laser...
Describe your ricoh aficio 2232c manual copier internal tray problem solving Problem display screen says internal tray open cholland@shawu.edu
just take a air blower and flow the area from where the paper comes out ur internal paper tray sensor is dirty
Jan 22, 2010 | Ricoh Aficio 2232C Color Copier
We don't get print from Ricoh after formatting the
try and print a test page from the driver and make sure paper is set corectly
Oct 25, 2009 | Ricoh Aficio 2016 All-In-One Laser Printer
Ricoh Aficio 1515
is thera paper jam sensor wigle paper in and out unplug unit from wall 2 min ten back in hit sensor with paper hit reset on unit
Jan 22, 2008 | Ricoh Aficio 1515MF All-In-One Laser...
Ricoh Aficio 2016 Black and White Copier Logo
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
