Question about Westinghouse Ovens
Oven stops working during a pyrolytic function in a westinghouse oven
We have a westinghouse pyrolytic oven model POP883, I have used the pyrolytic function before however, now when I select pyrolytic accept it attempts to heat up and the picture of the temperature gauge shows it is heating, however after about 5 mins it stops and displays FO2, then just blows out cool air and stays like that with the door locked to stop it we have to turn off the power to the oven. We have tried now several times and it still does this. Why and how do we fix this problem and actually get it to perform a clean???
catriver
  • 878 Answers
SOURCE: Oven shut down during Self-cleaning
tde, sounds like your thermal fuse (TC0) opened on the back side of the oven. If this opens, it will shut the oven down. This happens alot during self cleaning on built ins. Sometimes I have to re-route the tco to a different area to prevent this from happening. Your part number is 4451442. You will have to pull the oven out far enough to remove the back paneling and replace the fuse....Catriver..post back.
Posted on Oct 25, 2006
SOURCE: pyrolytic cleaning fault
fixed very simply just turned off oven at mains turned back on and it worked perfectly!!!!!!!!
Posted on Aug 20, 2008
  • 33 Answers
SOURCE: Oven does not work after running self cleaning
Dear Dupe,
please rate this solution if it mends up ur needs,else choose fixya,
please do the following checks,
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Check the thermometer bulb
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • please rate this solution if it mends up ur needs,else choose fixya.Thank you
    Posted on Dec 17, 2008
    SOURCE: Pyrolytic cleaning won't start. Neff B15P42.0 GB
    you have to remove the shelf supports (left and right) as well as the shelves. The manual tells you about the shelves but not the supports. I only found out as someone wrote the answer on another website
    Posted on Aug 28, 2010
    micromatikal
    • 2777 Answers
    SOURCE: I have a Jenn Air
    This is a control board / unit problem with these models. It is not an easy repair really, but if you are extremely handy it can be done. Let me know if you want to try the repair yourself and I can find the part.
    Thanks
    Tim
    Posted on Oct 09, 2010
    After a pyrolitic cleaning cycle, an error code F04 has appeared and the menu does not want to start any more.
    Miele fault code f04 Ovens Questions & Answers - Fixya
    www.fixya.com > Forum > Tags > fault code f04 > Ovens
    Miele ovens fault code f04 related questions and answers. ... Can't use my Meilepyrolitic oven fault 90 I turned it off at the main power source and then ... fault 23 is displayed on the control panel after using teh self clean function on our miele ...
    [PDF]USE & INSTALLATION MANUAL - Smeg
    www.smeg.com.au/smeg_au/docs/user_manuals/DOA330X.pdf
    Smegelements or interior surfaces or racks of the oven during or immediately after use. During the oven ..... locked automatically due to self-clean mode. "USER LOCK" is ...These codes are displayed when the electronic control detects a ...... The ovens feature a pyrolytic self-cleaning function ..... F03 or F04 Error appears.
    [PDF]user manual e:line built in ovens - Appliances Online
    manuals.appliancesonline.com.au/epee63cs/epee63cs.pdf
    Jan 10, 2016 | Ovens
    How do I clean the electrolux oven? It won't start after i take the racks out
    As you did not specify the exact model I assume that this is a self-cleaning oven, in other words with pyrolytic cleaning. It has a microswitch which is activated by removing the racks and just because that you can not run the pyrolytic cleaning otherwise racks would be destroyed. Do not forget that the temperature during pyrolytic cleaning is app. 500 degrees Celsius. For that reasons the oven door is locked when temperature increasing to app. 300 degrees and unlocked when the temperature decreasing to the app. 200 degrees. It is clear that when you remove the racks only program that you can run is pyrolytic cleaning.
    Dado
    Oct 10, 2014 | Electrolux ICON Designer E30SO75ESS Oven
    When the pyrolytic function is switched on the oven starts the process then after about ten minutes the code f1 appears on the digital control panel and stops
    Hello katefreeman1 - Typically error code F1 indicates that the range has detected an issue with the runaway temperature (overheating). A certified technician will need to check the RTD sensor probe and/or EOC and replace if necessary. Try reprogramming the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart range. Usually this will clear most false error codes. If it proves to be ineffective, contact a professional to move forward accurately.
    Jan 22, 2013 | Electrolux EOC6690X Pyrolytic Electric...
    Mile Pyrolytic Oven got a PY flashing
    Mine is doing this too. Did you find a solution?
    Apr 05, 2012 | Miele Ovens
    Sep 10, 2009 | Neff B1476 Pyrolytic Stainless Steel...
    Neff B4562 Pyrolytic Cleaning Not Working
    You need to remove the rack side supports too. Its not clear in the book as it just says shelves and racks but everything needs to come out the oven.
    May 01, 2009 | Neff B1476 Pyrolytic Stainless Steel...
    Westinghouse Freestyle 668 oven not doing anything , just blinkin
    Yes I can help.Hold down the buttoms on the far left at the same and then set the time using the + and - buttons.Cheers
    Apr 20, 2009 | Ovens
    Oven Light does not turn off
    The problem is due to a faulty door switch, this is part of the door lock mechanism. The reason is that the oven thinks the door is open , this puts on the light and stops some of the oven functions ie the fan the fan element and probably the bottom element.
    The answer is to fit a new door lock mechanism.
    Mar 08, 2008 | De Dietrich DOP390 Pyrolytic Electric...
    Ovens Logo
    23 people viewed this question
    Top Westinghouse Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you a Westinghouse Oven Expert? Answer questions, earn points and help others
