Question about Infinity BASSLINK Car Subwoofer
Power indicator light won't shut off.
This is the third Basslink I have installed (in different vechicles), the other two worked fine. This unit is installed in a 2003 GMC Sierra with the stock radio. I am using the speaker level input (not the preamp level) with the power selector set to "Auto". With the selector switch set to "Auto", I can unplug the speaker inputs from the base unit, and the indicator light still remains on, 24/7. With the selector switch set to "Off" and the speaker level inputs unplugged, the indicator light will then go out.
Help!
  • roy_hughes Jan 28, 2009
    There is no remote turn on wire when using the speaker level inputs. The base unit detects a signal in the speaker wires and that signals the unit to turn on. A remote turn on wire is only needed whe you are using the preamp level inputs.
    Thanks!
    Scholar:
  • 116 Answers
Is you remote turn onwire (usually blue) always on? Check voltage with a meter or test light. It's possible that the wire is on all the time.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Posted on Jan 28, 2009
  • Larry Tezekjian
    Larry Tezekjian Jan 28, 2009
    OK. Thanks for the input...(No pun intended). How about this. Is there any way that maybe a strand or two might be touching the terminal screw where the remote wire is suppsed to go? Just a thought. Also, humor me and check that terminal to see if it is getting voltage by accident. I suppose that you always "could" have a defective amp. Let me know. Sorry I can't think of anything else that would cause that.
    Take care.
    Larry T
    Winona Lake, IN
    http://www.cybersoundsaudio.com/cybersou...
The indicator lights on my dash for the anti-lock, the brakes,and low tire won't shut off eventhough i just fixed all three.
IF YOU SEE ANTI LOCK AND BRAKE WARNING LIGHTS YOU HAVE BRAKE FAILURE.NOT SAFE TO DRIVE CAR.BEST TO LET DEALERSHIP FIX ABS BRAKES MODULATOR MASTERCYLINDER UNIT AND THEY CAN RESET LOW TIRE LIGHT.VECHICLE NOT SAFE TO DRIVE.
Jul 28, 2011 | 1999 Oldsmobile Alero
Power light
Hi Bill, I believe the power problem is related to the Remote wire which should be blue or yellow. The remote wire is suppose the turn the Basslink on and off when the radio is turned on and off. The yellow wire is normally used for power antenna. Traditionally the remote wire is blue. You can use a Speaker level adapter and splice in with the L/R rear speaker wires, and the adapter will convert the speaker level to line level. The output of the adapter will go to the Rear speaker input on the basslink., Write back if you need more detail on the adapter.
Oct 07, 2007 | Infinity BASSLINK Car Subwoofer
I have a 2005 Mitsubishi Eclipse with the Infinity high end stock radio installed, which has a 200 watt amp under the seats. The head unit does does not have direct speaker outputs. The head is connected...
I am going to refer you to the live help
at crutcfield.com audio
They can give you ideas on compatible equipment and designs that will achieve your desires without the OBVIOUS overlad/mismatch.
Your search for comparison returned these articles
Free factory (usa market) wiring diagrams
BBB Industries Premium Alternators Starters Power Steering Products
Mar 11, 2017 | Infinity BASSLINK Car Subwoofer
Basslink red light on but no sound
check the all power lines and regulator .is any of them overheating?
then check the power amp ic or transistors.
nuwan.
Jan 12, 2009 | Infinity BASSLINK Car Subwoofer
2nd Basslink, still no power-on. Please help
this is in response to the post below:
I just bot a basslink t and i wired it up and nothing it just keeps blowing the fues in the unit i got mine on ebay2.gif so i dont know if i can use the warranty dose anybody have an ida for me- britter623
I got a used basslink about a month ago and had the exact same prob kept blowing fuses...found out that the voice coil had blown on the infinity...so I had a brand new dvc polk 10 sittin in the closet, I swapped them out, put the polk in the place of the infinity sub, however, the magnet is much larger, hence, dual voice coil, it would rattle sooo much from the passive radiator against the magnet, also could not turn the gain up at all due to the rattle. I got the bright idea to build a "custom fiberglas enclosure for the polk and incorporate the infinity's parts(amp/control) I finished the box finally last night and hooked it up this morning, no power, no lights, no nothing! s@#%, F&@%! ANyone had a prob w/the amp not having the lights turn on, no power??? Hope that helps about your fuse blowing issue.
Jul 15, 2008 | Infinity BASSLINK Car Subwoofer
Basslink keeps cutting off into protection!!
From what i have heard, If you have a speaker level input connection. this sympton does occur. You buy a scosche LOC and try giving the input to Basslink, it should work fine
Jun 24, 2008 | Infinity BassLink II Car Subwoofer
Infinity Basslink 2
Follow these instuctions and piece together where you went wrong. Sounds like a wiring fault.
http://www.ehow.com/how_5829_wire-car-stereo.html
Dec 23, 2007 | Car Audio & Video
Basslink "Motorboating"
Good evening, my name is Colmen here is a guy that might be able to help you 917 504 0461 please let me know how you make out, he has done a lot for me, by the way his name is Cee...
Dec 19, 2007 | Infinity BASSLINK Car Subwoofer
Basslink drops out.
The auto on switch should only be in the on position when the REM wire is NOT connected. Auto on can be flaky. Basslinks respond better to RCA inputs then the high level ones. You might try getting an RCA line converter, they work very well with the Basslink.
Oct 02, 2007 | Infinity BASSLINK Car Subwoofer
Amp keeps blowing fuse
I have this same problem. You have blown the internal amp. I have had 2 of these do the same thing. There is nothing you can do but report it to infinity and try to get the unit replaced.
Dec 21, 2006 | Infinity BASSLINK Car Subwoofer
Open Questions:
See all Infinity BASSLINK Car Subwoofer Questions
Infinity BASSLINK Car Subwoofer Logo
452 people viewed this question
Top Infinity Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Colin Stickland
Colin Stickland
Are you an Infinity Car Audio and Video Expert? Answer questions, earn points and help others
