Question about Hotpoint Aquarius WMA42 Front Load Washer
Drive belt came off Hotpoint Aquarius WT540
How do i remove the top of the machine without damage to refit the drive belt
  • hm1flory Jan 27, 2009
    Exellent. A hard bash did the trick, thank you, saved me quids
  • 135 Answers
At each side of the lid there is a small plastic cover. Remove these then take out the screws. Lift the lid at the front and push it back then lift off.
Thankyou for using Fixya.
Posted on Jan 27, 2009
  • pedropony2 Jan 27, 2009
    Could you confirm model please. I have wma42 on my screen!
    I now have wt 540 in which case remove screws at back of lid and push back. It will need a firm hit with the palm of your hand as these are always extremely stiff.
Hotpoint wt540, reduced creases and extra rinse lights are staying on all the time
1) clean the contacts ribbon with erase pencil and put a little ethylic alcohol.
2) try it 3) if the problem persist the control board is faulty.
God bless you
Oct 11, 2012 | Hotpoint Aquarius WT540 Front
Hotpoint aquarius wt540 - it has started to malfunction
Most likely a control board failure, you need a service tech to come out.
Oct 27, 2017 | Hotpoint Aquarius WT540 Front
Hotpoint drive belt
un plug appliance, remove lid and back plate, place belt on motor and carefully on drum pully, turn pully to pull belt onto its, its quite tight to do but is possible, watch out for trapping your fingers.
Apr 07, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
How to fit a belt to a hotpoint aquarius when the back cannot be removed
If there is a small inspection panel at the back where you can get to the motor remove that then remove the top lid of the machine. Loosen motor mounts and swing motor up and remove belt from motor. Now remove belt from pulley from the top of machine. Reverse the order starting from the top to replace belt.
Jan 24, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Drum will not move
Try to remove drum belt, and then turn drum by hand, if it does not turn , then you have either siezed drum bearigs, or some thing jammed between the inner and outer drum
If drum turns freely, then check motor to see if it is free to turn.
Please rate my solution.
Thanks.
Jul 24, 2009 | Hotpoint Aquarius WD63 Front Load...
The drive belt as come off
It is virtually impossible to fit belt from top on this washer dryer. as there is no room to get your hands in.
The easiest way to do it, is to remove the rear panel, and fit it from the back.
You will find it easy to do it this way.
Plz rate my solution.
Thanks.
Jan 27, 2009 | Hotpoint Aquarius WD63 Front Load...
Need to replace drive belt on hotpoint wf430 but to tight to get
Put it on the motor spindle first then feed it onto pulley. It is tricky with such limited access.
Hope this helps &thanks for using Fixya.
Jan 22, 2009 | Hotpoint Aquarius WF000 Front Load Washer
I am trying to fit a new drum belt on a hotpoint aquarius vtdoo reverse action
You need to remove the top cover, remove the right hand side panel,ease the drum forward and fit the new belt.
It is very difficult to fit the new belt without the proper tool avialable from Hotpoint.
It can be done without the tool, but be prepared to stuggle
Dec 04, 2008 | Hotpoint Aquarius WMA52 Front Load Washer
Belt has come off
I have fitted a replacement belts on a few older machines (Hotpoint WMA series). The procedure is likely to be very similar on yours.
Check your belt for wear - if it fits really easily it may already be stretched and will come off again quickly. A replacement is less than £20.
1/ Turn off power and disconnect.
2/ Check you have Turned off power and disconnect.!
3/ You best course of action is to open the lid. You will need tools. Torx set etc. Look for little finger nail size plastic covers over torx heads on the sides. Remove lid (push back and lift).
Once opened you will see large drive wheel connected to the back of the drum and the drive motor is at the bottom. Use a torch if its dark!. You will need to ensure the belt is fixed around both of these. This is not easy to do. And try not to pinch your fingers.
It may help to remove the concrete block on top of the drum to give you more room. Use large spanner. (You must remember exactly how this is fitted to refit)
4/ Dangle the belt around the motor spindle and lightly pull it to stop it sliding off. Next pull the belt round one side of the drum wheel. Gently rotate the drum until the belt is looped round the drum wheel and the drive motor at the same time. Sounds easy? it's not.
Regards
Nov 17, 2007 | Hotpoint Aquarius WF210 Front Load Washer
Hotpoint Aquarius WMA42 Front Load Washer Logo
676 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
