Question about Polti PFUS0001 Vaporella Professional Iron Attachment 1700W, Variable Steam, OnOff Switch, for Vaporetto 1020, Eco Pro 3000, Mondial Vap 2000 Cleaners
Can't get cap off Polti vap 2000.
There is no pressure in the tank but I can't get the cap off
Polti vaporetta comfort steam cleaner...no steam
if you put two much water in it it wont steam
Dec 26, 2012 | Vacuums
Unable to release steam
It's always a crapshoot of course, but could you possibly have forgotten to put the cap on the tank,, to keep the steam inside, so it could be pushed to the outside through the proper orifice? Believe it or not that's the most common mistake I encounter. If that's not it, then it's possible that some calcium or lime deposits are so thick that they're clogging the lines. You'll want to check that.
Jan 05, 2012 | Polti Vaporetto 2400 Canister Steam Vacuum
My polti vaporetto 2300 is belching with steam,have changd the safety cap seal,but hasn't helped --any ideas
My polti 2300 vaporetta is heating the water but not getting up to steam, could the problem be the safety cap?
Nov 17, 2010 | Polti Eco Pro 3000 Canister Steam Vacuum
I cant unscrew the filler cap for my polti 950
I had the same problem with the 2400 model, because the filller cap is a safety cap it thought there was pressure in the tank so wouldnt unscrew just kept going round and round. It had a little water it it. I switched it on heated it up then switched it off and let it cool a bit. There was a small metal bolt on the underside of the tank which I could unscrew with a alan key. This let the pressure out, I then rinsed it out with cold water and hey presto the safety value released itself. hope this helps
Jan 04, 2010 | Polti Vaporetto 2400 Canister Steam Vacuum
Starting a polti vaporetto steamer
Put a couple of lts. of water in the tank, replace lid, assemble hose with tool you require. Plug in switch on, wait for needle to climb into yellow then pull trigger for steam
Jan 23, 2009 | Polti Vaporetto 2400 Canister Steam Vacuum
Polti steam cleaner
It should go just below the red providing steam isn,t escaping from the cap otherwise you won,t get the pressure build up to enable it to come out when you pull the trigger
Oct 23, 2008 | Polti Vaporetto 2400 Canister Steam Vacuum
Polti vaporetto lux xteam cleaner
Ok, this may sound silly, but do you need to push down on the cap to get it off? Just a thought.
Jan 27, 2008 | Vacuums
Polti Vaporetto 2400: Water out light comes on when tank is full
Hi you need to put 5ml of Kal Stop fo Polti machines into 1000/1500ml of water into the tank, The stronger solution is better (1000ml) Let it heat up and this should break down the limescale on the solenoid. I tried this today and it has worked saving ££££'s in repair by Polti.
Nov 04, 2007 | Polti Vaporetto 2400 Canister Steam Vacuum
Polti PFUS0001 Vaporella Professional Iron Attachment 1700W, Variable Steam, OnOff Switch, for Vaporetto 1020, Eco Pro 3000, Mondial Vap 2000 Cleaners Logo
27 people viewed this question
Top Polti Vacuums Experts
Billy Detlefsen
Are you a Polti Vacuum Expert? Answer questions, earn points and help others
