Question about Sony DAV-C450 System
Sony DAV C450 No Power - Dead Unit
My player just died!!! it was working fine but then it just died! I turned it off and it won't turn on again... I have checked for fuses ( all ok) and removed all the dust that collects around and about... There are several posts on other websites with the same problem - Does anyone know wat it is??? Please help, i can't afford a new unit!!!
  • radarguy Nov 21, 2007
    My Sony DAV-C450 also just "died". No power. I have plugged into 3 other working outlets but it still will not turn on. At the time it went out I was playing audio cd's.
    Sniper:
  • 62 Answers
I am having this same problem. I have checked all fuses and all seem ok. Does anyone know what else might be keeping this from powering on? Any common problems that this one had to cause this? Also does anyone have a diagram of the schematics or the service manual?
Thanks in Advanced.
Posted on May 21, 2008
  • Alvin Moats Sr.
    Alvin Moats Sr. May 24, 2008
    Does anyone know any common problems that would cause this? Please help if you do.
    Thanks
  • Alvin Moats Sr.
    Alvin Moats Sr. Jun 20, 2008
    Door stop I think ! I decided on this one that the parts to fix it were worth more than the system.
    Just my opinion!
    ETRONIC
I just got done with Sony customer support on this. It took 5 minutes to do.
Push the power button on the unit to ensure it is off.
Unplug the unit from any power stips and leave unplugged for at least 1 minute.
Plug the unit DIRECTLY into the wall.
Push the power button.
Turn on the rest of the unit with the remote.
Hope this helps.
Posted on Jul 20, 2009
My 98 mercury mountaineer died and won't start
check fuse, check for fire, if no fire when turning over probably busted timing belt/chain, if fire then check for fuel
Sep 07, 2013 | Cars & Trucks
Sony DAV-C700 DVD player not working
is there any display in the LCD screen of your player??
Jun 28, 2008 | Sony DAV-C700 System
JVC KD -S680 needs help
maybe short circuit or similiar problem inside since its geting hot, probably not a problem with the faceplate I would remove the cd player from your car and take it to a professional for a diagnosis / repair estimate. Can't solve this one with text only.
Jun 18, 2008 | JVC KD-S680 CD Player
2006 Jetta 2.5 battery died, jumped car, radio won't turn on
Take it in to have a charge system check done on it, Your alternator is probally shot,
Nov 27, 2012 | Cars & Trucks
Car won't fire
check your fuses as a start then check relays and then fuel pressure because the filter could have only 1000 miles on it and have problems with it and it could also be the coil pack died on it .
Jul 02, 2012 | Hyundai Sonata Cars & Trucks
Fuel injector fuse is blown, keeps blowing. Engine turns but won't catch and start.
if the injector fuse is blown then the car won`t start as its not getting fuel into the motor to fire.if the fuse keeps blowing then you could have an injector/s that is drawing too much or the injector driver in the ecm may not be any good and needs replacing or a used ecm.it could be a short some where in the wiring for the injector system that is going to ground.
Feb 22, 2012 | 1995 Chevrolet Lumina
Stop on stop sign engine died
If the engine won't fire up, but your starter turns over, you may want to check your timing unless you have a check engine light on. If the CEL light is on, have the codes scanned.
If the engine won't turn over with the starter or it clicks, have your battery tested at autozone or advanced auto parts. Replace the battery if it is bad. Else, have your starter tested.
If the engine still won't turn over and the battery and starter are tested fine, you may have a blown fuse, bad ignition switch, or a failed relay.
If the engine fires up but randomly dies and starts back up, you either have a failed sensor, failing fuel pump, clogged fuel filter, bad plugs or wires, or a failing ECU.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Sep 06, 2011 | 1996 Nissan Quest
Sony DAV-C450 System Logo
803 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
