Question about Alcatel OmniStack 6124 (OS-6124) Networking Switch
Alcatel 6124 reset switch - Alcatel OmniStack 6124 (OS-6124) Networking Switch
Factory reset for alcatel a392a??
Hard reset is the only option thats in hand.
Sep 15, 2016 | Alcatel UNLOCKED OneTouch A392A Quad Band...
How to master reset alcatel one touch
master reset alcatel Dustin, Check the attached links,instruction and guides to reset Alcatel, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
ALCATEL One Touch 4007D Pixi How to Hard Reset my phone HardReset info
How to perform hard reset when my ALCATEL ONETOUCH Idol is unresponsive
How to hard reset ALCATEL phone HardReset info
Jul 09, 2016 | Alcatel Cell Phones
Recover password reset
You may have to update the firmware using a com port cable - check here for information about your product and to get firmware
https://service.esd.alcatel-lucent.com/portal/page/portal/EService/product_specific_support_media?p=OmniStack_6x24_6148
Apr 13, 2014 | Alcatel OmniStack 6148 (OS-6148)...
Alcatel 5052 core switch
Try this althought is not the same some times work.
GENERAL ROUTERS RESETING
Jan 16, 2014 | Alcatel oc-5000-1080 - 5052 20-port...
I have a leviton 6214 programmable light switch - it lights up inside but it does not turn lights on outside.
Is this a new installation? New installation then wiring might be bad.
Or older installation that has stopped working? Timer might be bad.
The Leviton 6124 is rated for incandescent light bulbs up to 1200 watts, and does not appear to be rated for CFL, but could possibly work with CFL and LED.
Change bulb to incandescent.
Copy following link to identify timer, and correct wiring.
http://waterheatertimer.org/pdf/6124-manual.pdf
http://waterheatertimer.org/Programmable.html#wire
Nov 27, 2011 | Electrical Supplies
Programing
You posted under Leviton 6124 programmable timer.
If this is not your timer, add a comment
Leviton 6124 manual:
http://waterheatertimer.org/images/6124-manual.pdf
If you have different timer, look at link below to help identify timer.
Leviton Timers:
http://waterheatertimer.org/Leviton-timers.html
Leviton 6124 timer instructions:
Timer comes with plastic protector over display >> remove protector to see display.
Large button is manual override.
After timer is wired, push override to make sure Load turns ON and OFF.
Timer has 3 small buttons located below manual override used for programming
Display is divided into 24-hours with am times on left and pm on right.
24 Hour day is divided into 1/2 Hour segments
Each 1/2 hour must be set for ON or OFF
Start by pushing left-side event-cursor-advance-button and it scrolls down each 1/2 Hour.
Once you arrive at 1/2 hour > make decision if you want timer ON or OFF for that half hour.
Press event-set-reset-button in center to set ON-OFF for that 1/2 hour.
Press center event-set-reset-button and solid black rectangle fills in for that half hour.
Solid black rectangle means timer ON for that 1/2 Hour.
Once solid square is selected, press event-cursor-advance-button and cursor advances again and starts filling in black rectangles for each 1/2 Hour period.
Keep filling in black rectangles for all times you want timer ON.
When you reach 1/2 Hour period you want timer OFF, then press center event-set-reset-button so that no black rectangle is visible for that 1/2 hour.
No black rectangle means timer is OFF for that half hour.
To set current time, use right-side time-advance-button.
Press and hold time-advance and time cursor advances down through the am and then pm hours.
Stop cursor at current time, and timer is ready.
Dec 02, 2010 | Leviton 6124H-A 6124H-A Decora LCD Timer...
Need instructions to set my timer. Where can I find these?
If this is not your timer, add a comment.
Also see Leviton timers at:
Leviton 6124 manual
Wiring for 6124 timer:
Add a comment if you need help wiring this timer
Nov 30, 2010 | Leviton 24-Hour LCD Programmable Timer,...
Grundig GDP-6124 DVD Player has no sound
I have grundig 6124 and cant get standby off :(
May 30, 2010 | Televison & Video
Alcatel OmniStack 6124 (OS-6124) Networking Switch Logo
61 people viewed this question
Top Alcatel Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you an Alcatel Computer and Internet Expert? Answer questions, earn points and help others
