Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
Solution wont comeout of the scrubber
Solution will not come out of scrubber when scrubbing rugs
  • Official Brand Answer
  • 315 Answers
Hey Ellen! Not having spray when trying to clean your carpet can be frustrating. Here's a quick link to troubleshooting steps to assist you.
http://www.bissell.com/FAQDetail.aspx?id=1122&cid=ccsocial
Posted on Jan 23, 2013
What is the speed range for moving our Miele Solaris S 514 horizontally over the carpet for optimum weekly dust removal?
When the dust is gone the speed is correct . You should use a back and forth movement so the rug fibers contact the machine efficiently. There is no perfect speed since the amount of dust in a carpet is not uniform. Hi traffic areas will require more time spent removing dirt than an area close to the wall here there is no foot traffic.
Aug 14, 2016 | Miele S514 Solaris Electro Plus Vacuum
With my floor scrubber, I end up with really clean spots (where the tiles are high) and dirty spots (where the tiles are low). Tips?
High spots are preventing scrubbing element from reaching the lower spots. Guess you will have to get on your knees to finish the job.
Jul 24, 2016 | Vacuums
Why did I lose power to scrubber
Your motor just burned up. There was probably a burning, electrical smell too, right ? You are done with this machine. Buy a F5914 Hoover and your troubles will be over. For a second opinion, take it to a vacuum repair shop.
Aug 19, 2014 | Royal RY7910 Upright Steam Cleaner
Why it won't pick up water?
Make sure the switch is on the setting you are using, I.E. spin scrub. If this isn't the problem you may have a bad turbine blade, if the scrubber brushes aren't turning that is your problem. $45, a screw driver and general mech. abillities will fix it. http://www.vacpartswarehouse.com
Jul 21, 2014 | Hoover Spin Scrub 50 Deep Cleaner
Hoover spinscrub
I would be careful in mixing solutions with different machines. The steamer carpet cleaner applies the cleaning solution differently than the spin scrub. If anything, I would delude the solution before using it in the shampooer. The steamer automatically deludes the solution, the scrubber directly applies a thick coat.
Elisa Jed ' http://www.babayans.com/en/
May 01, 2014 | Vacuums
Bissell lift off scrubbing bars not working
Hi Pamela. I'm sorry you're having difficulty with the brushes not turning.
Here is a quick link to troubleshooting steps to assist you:
http://www.bissell.com/FAQDetail.aspx?id=18992&cid=ccsocial
Apr 19, 2013 | Bissell Vacuum, Lift Off Deep Cleaner
Bissell model 1694 rug scrubber works for a while then makes a loud noise when you pull it toward you like it is. Umping over something, roller is very easy to pull on, is it loose or a belt?
Dear Sir:
Possible the motor can be faulty, or test the belt if is crack and replace. However you must see if there are some debris inside. Please see the section troubleshooting in your user manual. Download Biseel.com or www.fitness.manualsonline.com or www. retrevo.com or www.manualsfactory.com
God bless you
May 26, 2012 | Vacuums
When trying to scrub rug, the cleaning fluid runs out but the scrubber will not **** it back up. My rug is soaked!
You have an air leak. This is almost always caused by the lid not being correctly installed on the recovery tank. Remove the lid, hook it in the back, and snap the front latch in place. A less common problem is that the square duct on the front of the lower tank has been removed to use the attachment hose and not put back in the tank after use.
Feb 02, 2011 | Hoover SteamVac F5914-900 SpinScrub...
Hoover all terrain dual v spin and scrub 12 amps
All of the hoover cleaners use air to spin the brushes the air intake is probably clogged. There is a Little clear window on the top of the machine pull that off and underneath is a little screen clean that out and that should fix your problem. If you need any parts or cleaner for your machine visit www.stevessewandvac.com
Aug 12, 2008 | Vacuums
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
42 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
