Question about Husqvarna Freesia 415
The needle keeps breaking.
I have a Viking Freesia 415,425 and the needle keeps breaking and hitting the plate underneath. I have broken 6 needles consecutively and can't find a solution in the manual trouble shooting.
  • carolyn_lipp Feb 27, 2009
    This solution is not helpful because I don't understand what you mean by making sure the needle is set to the correct position. It is placed in the holder correctly and I am not aware of any "setting" for needles. there is nothing in the book about this.
    Problem Solver:
  • 5 Answers
Make sure the needle is set to the correct position
Posted on Feb 27, 2009
My Viking opal 690Q needle is tapping plate underneath won't let me sew over loaded symbol keep coming on does the need re position it self can't sew need help.
If it's hitting the needle plate, try installing a new needle. If it is still hitting, then it needs adjustment. Take it for service.
Dec 18, 2016 | Sewing Machines
Broken needle
ck the alignment of the foot plate (under presser foot) if needle rubs this plate it will break every time
Jan 21, 2016 | Sewing Machines
Husqvarna #1+ sewing machine, is breaking needles under throat plate
This could be bad timing, or the needle is not in properly.
Make sure that the needle is pushed up all the way, and in the correct position. If the needle is too low, it will break.
Also, keep the bobbin case door open to see where the needle is catching.
Apr 10, 2013 | Husqvarna Sewing Machines
I need to adjust the bobbin/lower thread tension on my Freesia Viking sewing machine.... Now I know why it was sold. I sew lots... but am at a standstill on how to remove or get to it to adjust it..
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 08, 2011 | Husqvarna Freesia 415
Needle seems to be hitting the plate and sounds
sounds like the sewing head is out of line. Suggest that it be serviced by an authorized Husqvarna Viking Dealer. You can find the nearest dealer by click on the "Dealer" link at http://www.husqvarnaviking.com
Good luck.
Feb 10, 2010 | Husqvarna Huskylock Computerized 910
The bobbin keeps jamming up and is not catching
Check that it is threaded correctly (both top and bottom) making sure that the upper thread is in the takeup lever. Watch the needle as you slowly turn the handwheel counter clockwise (toward you) and the needle point touches the fabric (make sure presser foot is down). Is the thread still relatively taunt? If it is loose, the upper thread tension unit does not have enough tension. Check the areas where the thread goes and make sure you remove any loose threads or fluff which could be inhibiting the tension discs from closing over the thread. If the tension unit still is not tightening enough, the tension unit may need to be replaced or the circuit board replaced. If everything is ok in the upper thread area, now look at the bobbin area. With no fabric, watch as the needle enters the bobbin area. Does it go down and the upper thread catch the bobbin thread and pulls it to the surface? Check for anything preventing the bobbin thread from being pulled up to the surface through the needle plate. If you have still not been able to resolve the problem suggest you take it to an authorized husqvarna viking dealer for service. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
Feb 05, 2010 | Husqvarna Freesia 415
Husqvarna Viking Designer I breaking needles
Make sure that the metal plate is locked into position- Hope that helps!
Jan 20, 2010 | Husqvarna Designer I
My PE 100 keeps breaking needles, they are striking something during use.
    Here are some things to try.
    * Your broken needles may have been too thin for your fabric. Make sure your replacement needle
    is appropriate for the weight and type of your fabric and thread. You may also need a thicker needle if you’re sewing through bulky layers of fabric.
    * When you insert your new needle, make sure it’s positioned correctly (usually with the flat side
    away from the bobbin, but consult your manual), that it goes all the way into the holder, and
    that the screw is securely tightened.
    If this doesn’t seem to be the problem
    * Check your pressure foot
    Make sure it’s attached securely.
    * Change your pressure foot
    Your pressure foot may be bent, causing your needle to hit it.
    * Don’t sew over pins
    A needle that hits a pin can break. Always remove the pins from your fabric before they reach your needle.
    * Don’t pull your fabric as you sew
    You could be bending your needle back, causing it to hit your needle plate instead of going into the hole. Just guide your fabric, letting it feed on its own.
    * Check your needle plate
    Make sure it's securely in position.
    * Change your needle plate
    If you’ve been using a straight stitch needle plate (a plate with a small hole, often used for
    sewing fine, delicate fabrics), switch to a needle plate with a wider hole.
    * Check the position of your needle
    Sewing machines with zigzag capability allow you to adjust the position of your needle – right, left, or center. If your needle is not positioned correctly, it may be hitting your needle plate or pressure foot.
    I hope this helps.
Sep 11, 2009 | Brother Sewing Machines
Needle hits the plate that is over the bobbin.
If possible hoop the item. I have found that any item that has any thickness causes the presser foot to be pushed forward and the needle hits it and breaks. If you can press the item to lessen the thickness this may help. I spoke to Singer (I am a Singer dealer) and they did not have any help for this other than to recommend that the owner cut out the back of the foot. I don't think that would be a solution as it would be difficult to cut out the back of the foot and still have smooth edges, also it would cause the foot to be weak and possible break or bend. Good Luck
Feb 25, 2009 | Singer CE-200 Quantum Futura Computerized...
I can't figure out how to shift the needle to the left
When topstitching using straight stitch the needle position can be adjusted in steps. The stitch width button(+), 0 is the center position, width 6 isleft needle position,width6 mirror image(diamond half clear and half black)is right needle position.
hope this helps, it is from the manual.
Jul 27, 2008 | Husqvarna Freesia 415
Sewing Machines Logo
325 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
