I have a HP Pavilion dv7-1235nr Entertainment Notebook. The battery and powercords have been changed since I thought they were the problem but turned out not to be. The laptop remain off and make a beeping noise and won't come completely on. What's wrong and what can I do to get this fixed?
  • 32,281 Answers
Computer does not boot up The problem maybe the RAM, it is faulty or just needs reseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you. Just like you sometimes need a mechanic to repair your car, sometimes you do need a technician to diagnose and identify the fault or faults on your computer. Not only does a good service technican have the experience to deal with this type of problem, they also have the equipment that allows them to look at things the average computer user can't see, and he has a collection of replacement parts that can be used to quickly test individual components on your computer.
Posted on Jan 23, 2013
3 Suggested Answers
  • 26 Answers
SOURCE: boot up beep and blanck screen
The beep patterns always tell you what the problem is, but it depends on what kind of BIOS is in your computer. You can take a look here, maybe you find what is the problem with your machine: http://www.pchell.com/hardware/beepcodes.shtml
Posted on Apr 11, 2009
leecom72
  • 4806 Answers
SOURCE: need to replace keyboard in HP Pavilion dv6626us
Turn the computer off and close the computer lid.
Remove the battery and the AC power supply.
1st we need to remove the switch cover or keyboard bezel. This is plastic strip that runs above the keyboard.
Turn the computer upside down with the front panel towards you.
Remove the three Phillips screws that secure the switch cover to the computer.
Turn the computer display-side up with the front toward you.
Open the computer as far as possible.
Lift the rear edge of the switch cover and swing it forward until it rests on the keyboard.
Release the zero insertion force (ZIF) connector to which the LED board cable is connected and disconnect the cable from the LED board.
Remove the switch cover.
Now remove the panel directly above the battery compartment and remove the 2 keyboard screws there and another 2 screw in the battery compartment (they should me marked with icons of keyboards)
Turn the computer display-side up with the front panel towards you.
Lift the rear edge of the keyboard until it rests at an angle.
Slide the keyboard back to disengage the tabs on the front edge of the keyboard from the top cover.
Swing the keyboard forward until it rests on the palm rest.
Release the ZIF connector to which the keyboard cable is connected and disconnect the keyboard cable from the system board.
Remove the keyboard.
Just reverse the procedures to replace everything.
Good luck.
Posted on Sep 17, 2009
How to turn on hp pavilion dv7 wireless key
FN + a button with a similar key to this:
24628989-wsjhsfa5vjycjgfazcdhels3-5-0.jpg Or there may be a physical switch on the side of the laptop
If not, reinstall the wireless driver here
http://support.hp.com/us-en/product/HP-Pavilion-dv7-Entertainment-Notebook-PC-series/3837623/model/3860621/drivers/
Jun 14, 2014 | HP Pavilion dv7-1240us Notebook
Calibrate laptop battery
Let the battery drain completly
Under win7 change level of backup battery from 7% to 0%
If your battery is any good it will recalibrate itself after a few cycles
Sep 05, 2013 | HEWLETT-PACKARD Hewlett Packard HP 15.6"...
How to change keyboard on HP Pavilion dv5-1002nr entertainment notebook pc
Here is the Service Manual for your laptop, the specific instructions are on page 69 of the manual
http://h10032.www1.hp.com/ctg/Manual/c01550108.pdf
Oct 04, 2011 | HP Pavilion dv5-1000us Notebook PC
My pavilion dv4-2140us entertainment notebook is not loading windows, am getting black screen..please help i simply changed the boot settings t load all drives
This is a bad problem.
If you wrong changed booting, booting is impossible.
You must boot from a rescue disc, and configure after the bios.
JMG
Jul 17, 2011 | HP Pavilion dv42140us 141" Entertainment...
I have a HP Pavilion Entertainment PC. I push the
It sounds like a power supply problem (low voltage), or could be a battery going bad. Also, the vents to the cpu fan could be clogged up and overheating the cpu, causing it to shut down. You can spray the vents and area out with compressed air. Other than that, it will have to be serviced.
Good luck and hope this helps.
Jul 08, 2010 | HP Pavilion DV5234US Notebook Laptop
My HP Pavilion Entertainment PC will not turn on!
CHECK IF U ARE RUNNING ONLY ON BATTERY SO TRY TO REMOVE THE BATTERY AND INSTALL IT AGAIN AND CONNECT THE CHARGER
Jun 07, 2009 | Microsoft HP Pavilion DV6276US Notebook PC
Compatibility between HP Quickdock 2.0 Docking Station KN745AA and HP TouchSmart tx2-1020us laptop for external monitor viewing
Your tx2-1020us is not compatible with the KN745AA as this device is only compatible with the following:
  • HP Pavilion dv2700 Entertainment Notebook PC series
  • HP Pavilion dv6700 Entertainment Notebook PC series
  • HP Pavilion dv9700 Entertainment Notebook PC series
  • HP Pavilion dv2600 Entertainment Notebook PC series
  • HP Pavilion dv4-1000 Entertainment Notebook PC series
  • HP Pavilion dv5-1000 Entertainment Notebook PC series
  • HP Pavilion dv5-1100 Entertainment Notebook PC series
  • HP Pavilion dv6-1000 Entertainment Notebook PC series
  • HP Pavilion dv6-1100 Entertainment Notebook PC series
  • HP Pavilion dv6600 Entertainment Notebook PC series
  • HP Pavilion dv6800 Entertainment Notebook PC series
  • HP Pavilion dv6900 Entertainment Notebook PC series
  • HP Pavilion dv7-1000 Entertainment Notebook PC series
  • HP Pavilion dv7-1200 Entertainment Notebook PC series
  • HP Pavilion dv7-2000 Entertainment Notebook PC series
You can find the compatibility chart by clicking here
You can find the compatibility information for the ES631AA by clicking here
To resolve your issue you should purchase one of the following:
To dock your notebook you need the HP QuickDock KN744AA#ABA or
You could get HP Notebook Media Docking Station
May 15, 2009 | Computers & Internet
HP Pavilion dv4-1151TX Entertainment Notebook PC price in india
http://h10025.www1.hp.com/ewfrf/wc/prodinfoCategory?lc=en&dlc=es&cc=mx&product=3824509&lang=es
Please find complete details for HP Pavilion dv4-1151TX Entertainment Notebook PC in the above link.
The price for the same starts from HK$9,980
Thanks
Have a nice day.
Mar 20, 2009 | Computers & Internet
Computers & Internet Logo
67 people viewed this question
David Payne
David Payne
