Question about Cobra 148 GTL 120-Channels Base CB Radio
Transmits off frequency
Brand new in the box, at less than 1.2 to 1 this radio on side band is 6 minutes past centre. poor signal and poor reception. I would not advise anyone to buy this radio. Maked a decent doorstop. Brad Greenaway, canada
    Genius:
  • Cobra Master
  • 1,795 Answers
Did you put it on a frequency counter? they can be set back on freq. if you know how to set it. how old is it? I would send it back to where I got it and have them fix the problem.
Posted on Nov 25, 2014
4 Suggested Answers
SOURCE: Cobra 19 DX IV CB Radio Gets no signal at all
my only idea is the frequency that Canadians transmit/recieve on is different than us down south (in the USA). I know Europe and the UK use a different frequency range so my guess is that Canada uses a different radio frequency range than the U.S. making you unable to communicate with fellow radio users. You may be able to search the frequency range for Canada vs. the U.S. and see if there's a difference. Hope this helps...and again, it's just a thought.
Montana, USA
Posted on Jul 17, 2008
  • 36 Answers
SOURCE: have a new cobra 148 gtl took out of box no transmit or recieve
make sure that your [swr] hadn't changed or went higher than a 1.5, anything higher will interfere with your tranmitting an recieving. other than that with out being there to see an hear your radio this would be the first place to start.
Posted on May 05, 2009
  • 773 Answers
SOURCE: Radio will
If the radio is not transmitting, then there is something wrong with either the final transmit transistor, or antenna system.
Have you ever checked the SWR on the antenna? If it was high, over 2, or you never have, you may have burned out the final.
In that case the radio will need a tech.
Its possible there is something wrong either with the antenna or feed line. But then you would still get some RF, and you would see the ant light on, which is an indicator of a BAD swr, and potential danger to the radio's final.
Posted on Jan 27, 2010
How can I get my midland 9001z from AM to FM
Hi Trevor,
The Midland radio you have is NOT capable of FM transmit & receive. It is a Citizen's Band radio that operates on channels 1 thru 40 that are assigned to the 26.965-27.405 MHz frequency range. These are the standard 40 Ch CB frequencies in the U.S. (and may not be legal for use in other parts of the world without a license from your country's communications authorities). It also offers Weather Band reception - again these are US frequencies that may or may not even be used at all in the UK. Since the radio only displays a channel number, you don't actually know the frequency you're monitoring or transmitting on. Your friends on CH 5 may be in a completely different band.
Even if they are on the same frequency, the fact that they are operating in FM mode means that you would hear something - but it may not be intelligible - and the same would be for them listening to you transmit in AM mode. If you could have them switch their radio to AM, all would be fine. I suspect they use FM as there is much less static when compared to AM.
If they won't change to FM, you'll either have to stop trying to talk to them or buy a radio capable of FM (and make sure it has the same frequencies as theirs!).
Feb 08, 2013 | MIDLAND-2 WAY RADIOS New - Midland 9001z...
Ihave a gargeled recive sound
Check the position of the mode selector switch. You may be receiving a SSB (single side band) transmission that is not on the exact same frequency as you or, your radio is in AM or FM mode. You will need to select either USB or LSB (upper or lower side band) and vary the clarifier knob until the sound becomes intelligible. If the sound does not become clear, try the other side band and repeat varying the clarifier knob.
Conversely, if you are in USB or LSB mode and there is a transmission on AM or FM, it will have the same garbled sound. Try changing the mode to AM and the FM. If it does not become clear, it is likely a SSB transmission and you are not on the exact same frequency of the transmission you are hearing. Vary the clarifier knob until it becomes clear - or change to the other side band if needed and try the clairfier again.
The short story is that you must be in the same mode and on the same exact frequency. When in AM or FM, this is less of a problem as these are much more wide banded signals than SSB signals.
The 2990 is really a 50 watt 10 meter amateur radio - but is geared to CBer's as it is easily modified to work in the CB frequency range and the so called "free band" between USA's CB (11 meters) and worldwide amateur 10 meter bands. Be careful transmitting this radio on CB frequencies as it violates FCC rules for power output there - and transmitting in the 28MHz - 29.7MHz requires a valid amateur radio license. Fifty watts on ham frequencies is tiny compared to the 1500 watts permitted. Why not get your ham license (here's how) and leave the "Chicken Band" (and all it entails) behind. You won't miss it!
I hope this helps and good luck!
Apr 12, 2012 | Cobra Radio Communications
Cannot select USB or SSB.Displays LSB or LISB? Very poor reception
On the Satellit 750 you have a button marked SSB. If you have selected a shortwave band then you can press the SSB button. Pressing the button repeatedly will toggle between LSB and USB.
You will need to know the exact frequency and the broadcast time, and the side band. Turn the radio on. Select a frequency which you know carries SSB signal and wait. Those that broadcast on SSB are not radio stations, maybe ham radio operators.
You can also select a short wave band, press the SSB button once or twice to select the side band and launch the automatic tuning system. It will scan the meter band and stop for a few second when it receives a strong enough signal. If you are able to perceive a clear signal on LSB or USB then you found a broadcaster. Some radios just have SSB and you cannot choose the side.
Personally, when I buy a radio I always insist on SSB but I have never been lucky tuning in an SSB signal. I keep trying once in while.
Jun 23, 2011 | Grundig Satellit 800 AM/FM/SW Radio
Keeps dropping internet. the internet light on router flashes. i have to power it down and then it works for a while
Home wireless networks based on the 802.11b or 802.11g standards transmit their signal in a narrow radio frequency range of 2.4 GHz. Various other electronic devices in a home, such as cordless phones, garage door openers, baby monitors, and microwave ovens, may use this same frequency range. Any such device can interfere with a Wi-FI home network, slowing down its performance and potentially breaking network connections.
The 2.4 GHz Wi-Fi signal range is divided into a number of smaller bands or "channels," similar to television channels.Many wireless products ship with a default Wi-Fi channel of 6. If encountering interference from other devices within the home, consider changing the channel up or down to avoid it. Some Wi-Fi channel numbers overlap with each other. Channel 1 uses the lowest frequency band and each subsequent channel increases the frequency slightly. Therefore, the further apart two channel numbers are, the less the degree of overlap and likelihood of interference.
If this won't work, Then consider buying a new wireless router as your current is deemed broken.
Dec 15, 2010 | Belkin F5D72344 Wireless G Router 54Mbps...
Internet fails every day and i have to unplug modem wait afew minutes and internet comes back
Try changing your wireless channel.
Dec 08, 2010 | Computers & Internet
Unstable connection
Nov 21, 2010 | D-Link 802.11g Wireless Router WBR-1310...
The Wireless router in our house is resetting itself every few minutes disconnecting all of our devices. I've tried manual resets and recently had a repairman out here to adress the problem. He claimed to...
Good Luck.
Nov 10, 2010 | D-Link AirPlus DI-614+ Wireless Router
How can I tx on 81.575mhz. I have a bespoke external antenna for this frequency
What brand and model radio? Most ham radios cannot transmit on this frequency, as it is far outside the amateur bands. Even modified radios would rarely be capable of transmitting on the frequency referenced.
Dec 02, 2009 | Vertex Radio Communications
My wpn111 wireless adaptor keep dropping my router signal
There is very little you can do about this. You may not like that answer, and I am sorry for the trouble, but there are things you can try.
First, lets understand that wireless is a radio signal, much like a cordless phone. The handset has to be able to communicate with the base on a phone, and, the wifi pc's have to be able to communicate with the router. Some phones and routers (sadly) use the same frequency range, 2.4 ghz. If you have a cordless phone that operates on 2.4 ghz, or if your neighbors have one, then whenever they get a phone call, wifi goes bye bye. What can you do?
1. Upgrade your phone to a wifi friendly one, with a 2.4 ghz offset range (so that the bands are close, but not so close to cause interference) or get another frequency phone.
2. Change the frequency of the router to level 1. Usually they are AUTO or level 6. Level 1 is a low frequency, and lower frequencies usually give slower, but more reliable performance. You can choose between 1 and 11. try all frequencies to see which one gives less trouble.
3. place the router in a more centered location in the home, off the floor. Remember, this is radio. Radio antennas go into the air to receive signal, and your router is no different. A router stuck in the corner of the basement may give poor performance, while a router in the center of the home should service the home easily.
4. upgrade your wifi. Choose the wireless N router and adapters for your machines. they have better capabilities and less interference.
I hope this gives you insight into the issue. Wireless is at the mercy of its environment. Building structures, signal interference, power lines, atmospheric issues, and cordless phones can play a factor in your reception. its just like taking a portable tv thru the house and having to move the antenna around to try to get better signal. Good Luck.
Nov 05, 2009 | Computers & Internet
I have a FT-8900 and want to be able to open the AM side so I can use it on frequency 26.805 is there anyway it can be done
The Yaesu FT-8900 is a quad band FM transceiver only. It can not be modified to receive or transmit AM, SSB, RTTY or CW. It works on all or portions of 70 centimeter, 2 meter, 6 meter and 10 meter bands. The 26.805 Mhz frequency is 11 meters, so it is out of range of the 10 meter band in the radio, it is close. Even if able expand the transceiver, the AM / SSB mode commonly found in this band makes it impossible to use. Further, the radio is not FCC Type Accepted for use in this band.
Sep 05, 2009 | Yaesu Radio Communications
Cobra 148 GTL 120-Channels Base CB Radio Logo
64 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
