I have A HP Pavilion dv7-1232nr Entertainment Notebook. I got a new battery, the power cord has been changed. Now it won't completely boot up the screen stays black. What can I do? Sometimes it comes right on and then other times it takes hours for it to come on. Help please
  • Computers & ... Master
  • 27,725 Answers
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Remove the memory modules from their slots. Take the opportunity to clean the slots on the motherboards and the memory module connectors. Use compressed air to blow dust away and clean contacts with a soft cloth. Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components. Do not use solvent that may attract dust and never poke things like cotton buds in to slots. lightly rub an alcohol on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r Allow the pins to dry. They will air dry in a matter of minutes If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer. Check the memory module and memory slot contacts. They are either copper tin or gold. The colour will tell you which they are. Mixing tin and gold can result in corrosion that prevents proper contact. Look for any sign of physical damage to the memory module, memory slots or the motherboard. Reseat the memory modules. You should hear an audible click when they are in place. Do not use too much force to reseat the memory module in to the slot this can cause damage to the module, slot or motherboard. The hardware that you are trying to access is damaged or failing.
Could be a problem with the Hard Drive or the Hard drives PCB http://www.onepcbsolution.com/ There is a connection problem such as a bad cable
Test all power and data leads that attach to your hard drive SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a secure dust free connections and are not faulty. Although it would be very rare for the sata lead to be faulty. Make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty Computers need power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
Hope this helps.
Posted on Jan 23, 2013
Geekman
  • 32281 Answers
SOURCE: my laptop screen is flickering
You most likely have a defective inverter that supplies high voltage to CCFL backlight. It is unlikely a faulty CCFL lamp because your laptop is approx 1yr. old.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is the inverter or backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Posted on Apr 08, 2009
SOURCE: WONT BOOT BLACK SCREEN
this is a easy one plug up your unit take out ur battery for 30 sec while holding do the power button hit the power button once again and it should come on and if it dont the great things is there a recall on those pc call hp they will send u a new pc free of charge
Posted on May 22, 2009
benwabnick
  • 2404 Answers
SOURCE: HP Pavillion entertainment dv6000 - Power goes
Try reseating the memory one stick at a time in each slot one at a time and see if you can get video that way. If you can't constantly get video after this then take out the hard drive and then the dvd drive,
If your still getting intermittent video then the motherboard might be bad. You can also try another stick of known good working memory to make sure the existing ones you have are good.
If your still getting intermittent video then the moterboard is bad and would need to be replaced.
Posted on Jul 17, 2009
  • 21 Answers
SOURCE: HP Pavilion dv6700 Entertainment wont boot
1. Power on (NO Disc.)
2. Press Pause
3. Enter 314159(with remote)
Display will show "FF"
4. Quickly press "0" (for all region)
5. Press pause
6. Power off and powere on after 20 secs.
Posted on Dec 15, 2009
benwabnick
  • 2404 Answers
SOURCE: I have an HP Paviion dv9008nr Entertainment -black screen at boot
Unseat and reseat the memory one stick at a time in each slot on at a time. After each reseat of the memory, turn on the laptop and see if you get video. If you still don't get video, go ahead and take out the hard drive and the dvd drive.
Then try turning on the laptop, if you still don't get video then the motherboard is bad and you'll need to get it replaced.
Posted on Apr 15, 2010
My HP pavilion dv6700 won't power on. I have a blue light at the power cord but can't power up.
disconnect the power adapter 2) disconnect the battery too 3) Press the power and hold the switch button power by 60 seconds. Then proceed in reverse and Power again and can be fix it.Of course if the problem remain test the memory from your pressing the key f2 or f9 depending of your modell in the reboot and go to the test memory.
God bless you
Mar 22, 2013 | HP Pavilion dv6000z Notebook
HP Pavilion dv6-7010us won't boot up
Hello.The most common reasons for this issue are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.The
power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.
If no change, the power adapter is probably faulty and needs replacement.Hope this helps.
Oct 27, 2012 | HP Pavilion dv6-7000 dv6-7010us B5S11UA...
Hp pavilion DV4 won't start up
It doesn't start at all. Can you see something on screen ? Have you tried to remove the battery and charger and press power buton for 30 seconds ? And put back the battery ? Try also to check RAM Memory
Oct 14, 2012 | HP Pavilion dv4-1280us Notebook
HP Pavilion dv6448se Notebook PC Won't Boot.
it restarts on booting screen or else at start up screen itself?
Jun 08, 2012 | HP Computers & Internet
Battery won't charge
So put the old power cord back on since you say it charged the battery normally. Why did you change it if it was charging the battery? It's quite possible that the new power cord is faulty. Just because it is new does not mean it works.
Remove the battery and plug the new power cord in. Does it boot the laptop up? Are you able to function with the new power cord plugged in. If so, then your battery is more than likely dead and needs to be replaced. The battery only has a useful life and once it is completely bad it will not charge.
May 01, 2012 | Dell Inspiron 1545 Notebook
How to test laptop output to the battery
Click Start Control Panel and go into the Power Options to check the Battery Meter. Batteries on last for so long. Maybe it's time you buy a new one.
If the laptop works only off the Power Cord and the batteryis not charging, then the battery is dead.
To check to make sure the Power Cord is working remove the battery and let thelatop run for 10 minutes or so.
To check to see if the battery has any charge left in it put the battery in andremove the power cord. If it won't boot or shuts down then the battery is deadand needs to be replaced if the power cord is ok.
Apr 20, 2012 | HP Pavilion Dv9910us Notebook PC
Batterie ne charge pas
Apr 02, 2012 | HP Pavilion dv2000t 14.1" Notebook Laptop...
HP Pavilon dv6910us Entertainment PC Defective ac adapter connection? ac port?
Sounds like your Internal DC Power Jack is broken. It has to be repaired or eventually it will completely break and you won't be able to boot after the battery drains. It calls for taking your laptop apart since it is on the motherboard or sits in a slot on the motherboard. Most times it is soldered on the motherboard. You have to unsolder the old and solder a new on it it's place.
Mar 27, 2012 | HP Pavilion dv7-1132nr Notebook PC
My pavilion dv4-2140us entertainment notebook is not loading windows, am getting black screen..please help i simply changed the boot settings t load all drives
This is a bad problem.
If you wrong changed booting, booting is impossible.
You must boot from a rescue disc, and configure after the bios.
JMG
Jul 17, 2011 | HP Pavilion dv42140us 141" Entertainment...
Computers & Internet Logo
David Payne
David Payne
