Question about Marantz PMD670 Desktop Digital Voice Recorder
Manual reset has killed the Marantz pmd671
I tried a manual reset to restore original settings by inserting a paper clip in the reset hole on the back of the device. Now it does not power on despite AC plugged in. Help much appreciated
  • peter_macdon Jan 27, 2009
    Wonderful, and so quick, thanks. Saved my face and skin
How do you get the marantz to show up on your desktop?
Posted on Mar 29, 2010
  • 2,071 Answers
By unplugging the cord from the wall for 4 hours in oder to drained the current stored inside in the IC memory so it will erase and return to its original setting.
Good luck:
Regards:
VOTIT
Don;t forget to rate:
Posted on Jul 07, 2009
    Brigadier General:
  • 5,158 Answers
Turn off the power... wait about 15 minutes and use the paper clip to push the reset button gently a couple times... it may be stuck
Robert
Posted on Jan 27, 2009
  • randomonymous Mar 13, 2012
    I can't turn off the power because it won't turn on in the first place.
Would like to restore my 2701hg b gateway to factory settings
  1. Unplug Your Router
  2. Turn The Router Around
  3. Look For A Hole About The Size of A Pencil Point
  4. Looking Closely, You Will See <Reset>
  5. Using An Unfloded Paper Clip, Insert The Paper Clip End Into The Reset Switch Opening
  6. Press and Hold For 30 Seconds and You Are Back To Factory Settings.
Thank You For Choosing FixYa~!
Mar 24, 2011 | 2wire (2701HG-B) Wireless Router
How to reset a sidekick 08 when the screen is on lock mode
Press the Jump button to access the Jump screen.
Select to Menu,Settings,System Info.
Press Menu + Shift + X simultaneously.
This prompts you to erase Flash Memory.
Select Yes.
From the same screen, press Menu + Shift + R simultaneously.
This prompts you to erase Sign-In Information.
Select Yes.
Insert a paper clip in the reset hole while holding down the Power button
The device vibrates if done correctly.
You are now restored back to the original factory settings
Mar 03, 2011 | Cameras
I can not connect to any internet . help how do you restore the netbook to original condition?
There is a small hole on the back down right of the data plate, you have to insert a toothpic or straighten paper clip in the hole. depress and hold for a few seconds. re boot and you have the machine back to original.
Dec 03, 2010 | Sylvania G-Netbook
Can not get wifi conected
here should be a small hole in the back and inserting a paper clip will reset set it to the original settings, this is not he same as recycling. This should be explained in the manual. You'll then have to set up the router, e.g., log on, security, etc. Basically what you had to do when you first got the router. Then on the laptop run the wireless connection wizard.
Sep 16, 2010 | Nintendo Wii Console
I have acrossover GPS. every thing checks out but is stuck on one route. frooze up at that point Magellan
I'd suggest you reset it to original factory settings. The reset botton is a small hole, usually on the back. Insert the end of a opened paper clip a push gently.
Aug 02, 2010 | GPS
How to format a new CF Card without getting a display message that says "must format on PC"?
I have this same problem. I have 3 cards. 1 of them my Marantz PMD671 just doesn't like, and produces the error message "you need format on PC". I can format it on PC, and use it normally, but the PMD671 will not have it. The card is a cheapo Dane-elec.
I give up at this point.
Apr 22, 2010 | Marantz PMD670 Desktop Digital Voice...
My 3140 needs a restore program
there is no restore program...you can try the reset..little pin hole on the side...turn it on, then use a paper clip to reset it by inserting paper clip and depressing the reset button.
if you need further help, just reply to this post.
bill
Jan 18, 2010 | Magellan Maestro 4040 GPS Receiver
\how do I reset the router to restore security
to reset the unit you have a botton on the back bush it for a few seco. and that will reset the unit back...
Nov 08, 2009 | Linksys Wireless-G Broadband Router
Deleted a file
Is there a reset on your player? It would be a tiny hole that you could insert a paper clip in to push a tiny button in the player. Do this lightly if there is such a hole. The manual would tell you if there is one or not.
This is basically a reset button for your player, and it will should restore the original settings. Then your files might re-appear though if the problem is more serious, they may not. Either way you haven't lost anything by trying.
Check you manual or look for the player's manual on line to see if you have a reset function. Most players have them. And if you do this, do it lightly and keep the paper clip as straight as possible so as not to damage the innards of your machine. Good luck.
Feb 19, 2008 | Delstar DS-907 MP3 Player
Marantz 6200
Your unit's micro IC, is in need of a reset.Un-plug the unit and locate the semi large yellow capactor on the main board. (r-h side facing front) Now flip the unit over and look thru the vent holes in that same area and locate the two solder pins. Short them out with a thin metal object, like a straightened out paper clip or wire, and turn it over (just discharge the cap and remove your wire) this will default all settings and restore normal operation.
Dec 03, 2007 | Marantz SR-6200 Receiver
Marantz PMD670 Desktop Digital Voice Recorder Logo
454 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
