Question about True Refrigerators
Flip doors on gdm-07
Would like to make door open to left.
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 211 Answers
Only if there are screw holes on the opposite side. In that case, invert the door, install in other screw hole. Most likely, since true won't give up diagrams, you would have purchase a left hand door and hinges. Call true at +1 800 325 6152
Posted on Oct 29, 2013
3 Suggested Answers
  • 127 Answers
SOURCE: left door pops open when right door is closed Also
its a very airtight unit so sometimes the doors popping open when another is closed sort of briskly is normal, or the door has gotten tweaked/bent so its magnetic gasket is not making really good, firm contact with the frame to hold it shut..
the water dripping is (if memory serves me correct) the condensate drain for the unit was prone to sometimes getting clogged, or the pan leaking. you may be able to get a ladder and climb up to the cooling box and see where the water is leaking from and remedy fairly easily.
hope this helps,
best of luck,
ttfn
Posted on Oct 27, 2009
  • 2468 Answers
SOURCE: gdm-73 how to adjust the door closing?
there is no spring tension on refrigerator doors,you adjust the front legs slightly higher than the rear legs and this forces a small amount of incline and gravity on the door to help it close on its own
Posted on Mar 23, 2010
I have a Samsung refrigerator RL46WBSW. How can I reverse the direction of the door opening from left-right to right-left?
Most fridges are designed so that the door can be flipped to reverse the opening direction. Look where the hinges are now. Look on the other side of the opening. Are there mounting holes to accept the hinge bolts? If so, unbolt the door, flip it so the bottom is now the top, and re-attach the hinges and bolts.
If you lack mounting holes, the door likely cannot be flipped.
Mar 17, 2018 | Samsung Refrigerators
Model GDM-69
A GDM 69 three doors. Each door closes using a string attached to a weight, which runs through pulleys or copper tubing, and is held to the top of door. The pulleys or copper tubing can be accessed by removing the aluminum siding located inside cabinet on either side. The left side contains the pulley and weightfs or left and center door, the right for right door (each held on by 4 1/4 screws) . To make the door close, simply make sure string is attached to weight, running though pulley, and attached to top of door.
Nov 07, 2013 | True Refrigerators
My true GDM-26 never shuts off and my drinks are frozen?
Faulty thermostat, the thermostats are cheap and wear out easy
Aug 15, 2013 | True GDM-26 Refrigerator
True 3 door refrigerator model#GDM-72 door does not self close
hi, I lost a part of the true cooler model gdm-72 door part that let the door side itself to close
Nov 01, 2012 | True Refrigerators
I need to replace the door bulb and the bulb above the door in my True GDM-23. What size are the bulbs and are they available in a hardware store. Thanks
The door bulb is a standard , I believe 32" t-12 newer units may be t-8, common bulb in stores. I've got an older gdm 23 and the bulb on top is a curved one , harder to find. Also these lights have ballasts that power them, they also can fail
Jun 22, 2011 | True GDM-23 Refrigerator
How can I switch the door from left opening to right opening on an LG electrocool (top) fridge (bottom) freezer? The user manual says nothing about it.
Look at the top and bottom of the door. There should be two holes near the edge. If there is then you just remove the hinges by the screws and place them on the other side of the fridge and flip the door over. At that point your shelves should be able to be flipped also. But if the manual does not say anything then your doors may not be able to be switched
Jan 02, 2010 | LG (LRBC22522ST) Stainless Steel
ESTATE DRYER BY WHIRLPOOL TO SWITCH DOOR FROM LEFT TO RIGHT
Look in the whirlpool wedsite for you make and model and for spare parts list.
Jan 11, 2018 | Estate EED4300SQ Dryer
The doors stick when they close. how do I lube the pullies
Your door rollers are probably worn off.
To access these carefully lift the door off the rail, pull it out bottom first then unhook the string attached to the counter weight from the top part of the door .Tip the door upside down and you should be able to see 2 or 3 rollers spaced on the bottom track (or what is left of it
Feb 21, 2009 | True GDM-41 Refrigerator
Refrigerators Logo
44 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
