Question about Kyocera Mita KM-2550 All-In-One Laser Printer
Kyocera km 2550 won't print - PLEASE HELP!
Its connected via network to my mac. In my printer settings it says its in idle then in use when I try to print something it says that it is not connected to the printer.. PLEASE HELP!
    New Friend:
  • 4 Answers
Switch on your bonjour in the printer settings
Posted on Mar 13, 2014
  • 36 Answers
SOURCE: kyocera km 2050
The 2050 uses 2 network connections, one for the printer and one for the scanner.
Before I go into any great detail,
Do you have a home network? Are you using a switch?
Are you printing through the network connection or the USB/parallel port?
Are you trying to twain scan? Do you have the software CD for scanning.
If not, you will need to download the drivers from the Kyocera web site.
Posted on Apr 08, 2008
SOURCE: KM-2530 with C0050 error code ?
it's the the expansion card on the main board in the middle, has a yellow circular cmos battery. Either its faulty or popped out during moving the machine. if faulty, replace.
Posted on Jun 03, 2008
SOURCE: KM-3035 scanning issues
the 30/40/5035 series machines have two network cards in them. One for printing and one for scanning. and they have separate IP numbers also. make sure you have scanfile utility running on your pc or wherever you are sending the files and the folder set up in the utility. then set it up on the scanner network card.. Not the printer.
Posted on Jun 19, 2008
frcs68
  • 1605 Answers
SOURCE: KM 2550 SCANNER SETUP ON NETWORK COMPUTER
do you have the CD or the driver for the scanner? if so, use the CD to install it. if not, go to the follwoing link and download the driver
http://usa.kyoceramita.com/americas/jsp/Kyocera/download_center.jsp?pid=18154&pcat=10569&rcid=10009&rscid=10007&x=44&y=13
I assume the other 5 computers are not running Wndows XP or don't have the same operating system??
post back if you still having problem.
please don't rate the answer till we finish the Q&A.
Thanks
Posted on Dec 03, 2008
SOURCE: Can't print on Kyocera km-2550
I have an HP 1350 all in one printer/scanner. It was printing fine until I wanted to scan a document. I pressed the scan button and now its stuck there. I can't get it out of scanning. I tried turning it off, unpluging and replugging. Can you help me.
Posted on Feb 06, 2009
How do I install driver for Kyocera CS 5035 on MAC
Kyocera and Copystar models are the same just replace KM with CS.
The following instructions should help you. TO download the current driver use this link to th emanufacture website; http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?rid=18657.
Kyocera Printer Drivers and Mac OS® X 10.5 Leopard FAQ:
Is the installation for Mac OS X 10.5 the same as for Mac OS X 10.4 and earlier? Mac OS X 10.5 introduced a new printing architecture that requires changes to the installer and installation process. For this reason, Mac OS X 10.5 requires a new printer driver installer.
I cannot see my Kyocera AppleTalk® printer. How can I make it visible to OS X 10.5? AppleTalk is disabled by default in Mac OS X 10.5. Enable AppleTalk to discover your Kyocera printer.If you use the Kyocera installer, a message will appear, asking you to enable AppleTalk. Click Yes to continue the installation.
I cannot find Printer Setup Utility on Mac OS X 10.5. Is it still supported? Apple has removed Printer Setup Utility from Mac OS X 10.5. To install a printer, open System Preferences and click Print & Fax.
When I manually install a printer, multiple PPD files are listed for the same Kyocera model. Which should I choose? When manually installing a printer or changing a PPD for a installed printer, both Linux and Mac OS X PPDs are listed for some older Kyocera models due to a change in PPD handling in Mac OS X 10.5. Linux PPDs can be identified by the word Gutenprint in the PPD filenames.
Supported Multifunction Printers: KM-1650, KM-1815, KM-1820, KM-2050 ,KM-2530 ,KM-2550, KM-3035, KM-3050, KM-3530, KM-4030, KM-4035, KM-4050, KM-4530, KM-5035, KM-5050, KM-5530, KM-6030, KM-6330, KM-7530, KM-8030, KM-C830, KM-C830D, KM-C850, KM-C850D, KM-C2520, KMC2525E, KM-C2630, KM-C3225, KM-C3225E, KM-C3232, KM-C3232E, KM-C4008, KM-C4035E, CS-1650, CS-1815, CS-1820, CS-2050,CS-C2525E, CS-2550, CS-6030, or newer. Supported Printers: FS-820, FS-920, FS-1018MFP, FS-1020D, FS-1030, FS-1100, FS-1118MFP, FS-1300D, FS-1800, FS-1800+, FS-1900, FS-1920, FS-3800, FS-3820N, FS-3830N, FS-6020, FS-6026, FS-9100DN, FS-9120DN, FS-9500DN, FS-9520DN, FS-C5016N, FS-C5020N, FS-C5030N, FS-C8008N, FS-C8026N, FS-C8100DN, or newer.
I hope this is helpful,
Shawn
Mar 08, 2011 | Kyocera Copystar CS-5035 Copier
The kyocera km-2550 is giving me an error "Print Mode Erro"
go to printer properties, printing preferences and set the paper size to A4 or the size you are sending
Sep 07, 2010 | Kyocera CS-2550 Black and White Copier
I am trying to set up newtwork scanning on our Kyocera KM 2550 multifunction machine and I can't find in the manual how to do it?
cool... ok here is what you do goto usa.kyoceramita.com then downloads... then where it says choose product... choose legacy copier then choose product then... where it says select subcategories... select manuals you need the scan system f operations guides both the setup and functions editions...
Dec 22, 2009 | Kyocera Mita KM-2550 All-In-One Laser...
Macbook Pro will not connect to Copystar 2550
ok... I am tech... and I had the same problem... you need to install the generic postscript driver then goto this ip address (http://localhost:631)and tune the driver... if not you will only print from tray 1 and only a4 paper size...
Oct 27, 2009 | Copystar CS-2550 All-In-One Printer
Kyocera KM-2050 network trouble
check the ip address, subnet, and gateway on your printer... by going to print and then print status page...
Jun 09, 2009 | Kyocera Mita KM-2050 Printer
I'm using Mac OS 10.5.6 and the Kyocera KM-3035 prints my documents with missing letters, words, sometimes whole paragraphs. I've uninstalled and re-installed the driver to no avail. What else can I do?
use the generic print driver in mac and tune it with this tutorial also set the press printer on the copier and set emulation to kpdl auto... also see if you can make the driver spool...
if that doesn't work... then try moving a zipped 10 mb file from one pc to another on your network... make sure one pc or laptop is connected where your copier is... if you open the zipped file and its corrupted... then the problem isn't your copier... its your network...
Jun 08, 2009 | Kyocera Mita KM-3035 All-In-One Laser...
Feb 06, 2009 | Kyocera Mita KM-2550 All-In-One Laser...
CS 2550 software
You can find the drivers for this unit at the Kyocera-Mita America website. Follow this link to the download section and find the appropriate drivers for your operating system. I would suggest using the KX Drivers as they are the most useful and offer the greatest control of the printer.
http://www.kyoceramita.com/download/
Choose your country and then find your model of system. You will see everything listed at KM series, these are the same devices just labeled as CS for the Copystar line of machines. Find the KM 2550 driver file and download the software and install it as you would any other printer in Window or Mac OS.
I was a Systems and Technical Sales Engineer for Kyocera-Mita for more than 6 years from 1998 - 2005 and worked extensively with the R&D Teams in Japan on the development of these systems.
Hope this gets you going.
Cheers,
Keith
Dec 02, 2008 | Kyocera Copystar CS-1820 Black and White...
Kyocera Mita KM-2550 All-In-One Laser Printer Logo
289 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Adorjani Laszlo
AAAA262430
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
