Question about GE 24 in. Profile PDW7800 Built-in Dishwasher
Disposal works, won't drain, other side of sink drains fine.
Well, my disposal is not draining, though the other side of the sink drains quite well, and the disposal is running because it makes funnels in the full sink. Before I drained the sink manually, I notices other gunk coming up from the disposal, but still not draining out.
Could there be a clog inside the disposal?
  • Hannah Schroeder
    Hannah Schroeder Nov 08, 2017
    It's smart of you to check if the disposal is draining by seeing if it makes funnels in the sink. I have a similar problem, except I think my disposal isn't even draining like yours is. I'm going to call a sink repair service so solve my problems, so maybe you should too.http://www.rapidrooterofbend.com/service...
  • 31 Answers
Well if you put things like rice--chicken fat ==it will pass through the disposer but it will clugg your pipe so yes your pipe is clogged
open the j trup it might come out
Posted on Oct 02, 2009
Why does kitchen sink drain water from drain side to garbage disposal side
The two drains are connected, but below the disposal. Likely if it's not draining down, you still have a clog, and the person the "cleared" the drain didn't.
Sep 03, 2014 | Garbage Disposals
Garbage disposal and possible clogged drain
plug the one side of the sink so as to create a sealed enviroment for the plunger to work weffectively ... plung the open side ..
If this does not work , try running a metal coat hanger thru the outlet at the disposal exhaust line.
Mar 25, 2013 | Electrical Supplies
I put half a small lemon down the garbage disposal. The disposal kept working fine with the water running, but then it violently threw out water and food particles. I stopped the disposal immediately, the...
Sounds like a clog at or beyond the P trap of the sinks. With water coming back into the sinks, it has to be part of the drain line that is common to both sinks. If you try and unclog the sink, work on the side that does NOT have the garbage disposal in it. A small hand snake for sinks might do the job. You could also try a plunger on either side, but when you do, put a wet rag over the other drain so you are not just pushing air back and forth. Work on one side with the plunger while holding the wet towel down tight over the other drain. Sounds like a clog that was there prior to you putting the lemon in the GD.
Oct 02, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
After I installed my Badger 5 my dishwasher would not drain. Is there a plug in the dishwasher port on the side of the disposal and how do I remove it?
There is often a plug in the ISE as many people use them without have a dishwasher connected to them. Quite often it is just a thin plastic membrane that can be knocked out with a screwdriver. There should also be a note to this effect in your installation instructions for the ISE.
Sep 14, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Here is an interesting problem. We have a Badger 5 1/2 Hp Garbage disposal hooked up on left side of double sink. The Disposer runs, spins, but will NOT drain.. at all. Left sink with the insinkerator will...
If this connects into a tee between the sinks, usually if the tee is in the middle of sinks, then often there is a divider in the tee to keep water from backing up the other drain. Remove the tee and inspect to be sure it isn't cloggged. Also put a bucket under the outlet. Try running it this way, if you get good flow you know the disposal is working
Aug 18, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My dishwasher backed up into my kitchen sink , it was about 30 minutes into a 2 hour wash cycle--i drained the diswasher, but 1 inch stayed in it till this morning, the sink drained on its on
It sounds like an issue with the sink drain rather than the dishwasher. Many dishwashers are connected to a double sink, one bay of which contains a garbage disposal. If yours is connected in that configuration, run the disposal to clear any food debris that may still be present while running the HOT water into the disposal.
If you have no disposal or if the dishwasher is connected to the other non-disposal bay, check the sink drain again for proper drainage.
The easiest way to do this is to put a plug in the drain (both sides, one at a time), then fill the sink about half way with luke warm water. Then reach in and pull the plug from each side, watching to see how each side drains, but especially the side with the dishwasher connected. If it's slow draining, focus your efforts on clearing the drain on that particlular side of the sink. Try a plunger first before resorting to other methods to clear the sink. If you plunge the dishwasher side, get underneath the sink and pinch off the discharge line from the dishwasher if possible. A pair of vise grips works well, but don't overtighten them.
Some dishwashers have a soft disposal that can eject enough ground up particles into a sink to cause plugging up over time, especially if the dishwasher empties into the disposal side.
Jan 20, 2010 | Whirlpool 24 in. GU980SCG Built-in...
My sink is backing up on bothe sides
Your drain line is clogged, beyond the sinks. You might be able to use a plunger to clear it. Seal off one the drains and use the plunger in the other. After you get it cleared, run pure hot water for a few minutes to melt the junk out of the line. When using the disposer, use cold water only, NEVER hot. If this doesn't get your drain flowing, you will have to snake the drain--to the main drain.
Oct 04, 2009 | Home
Water draining backinto dishwasher from garbage disposal
You have a clog where the drain pipe leaves the garbage disposal that isn't draining fast enough or not at all. Or it could be a clog in the dishwasher drain hose where it connects onto the disposal.
Apr 07, 2009 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
Clogged sink after using garbage disposal
You have a clogged trap. Try a plunger, draino or disconnect the trap and clean it
Mar 15, 2009 | Home
GE 24 in. Profile PDW7800 Built-in Dishwasher Logo
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
