Question about Whirlpool Washing Machines
My whirlpool cabrio washer shows LF code
I have changed the water supply hoses for brand new ones, I have checked the screens, i have verified i am getting good flow from the source, and i have checked to make sure my drain pipe isnt down the standpipe too far. I dont know what else it could be! Please please help! Another thing...it only happens during the rinse cycle.
    Sergeant:
  • 291 Answers
Verify inlet water valve is functioning correctly by selecting each temp while machine is running. Usually COLD temps will run just
ever-so-slightly faster than HOT temp and WARM temp will run faster than both temps separately. Rinse cycle is usually COLD water so i'd suspect the COLD side is malfunctioning. Hope this helps. If not let me know.
Posted on Jan 23, 2013
  • 2 more comments
  • GBlevins Jan 30, 2013
    Thanks for the help, sorry for the late reply. It appears to be only happening on cold water rinses... Not warm water rinse. How would I go about fixing this?
  • B.H. Countryman Jan 30, 2013
    You will have to change out the inlet water valve. If you have trouble finding one give me the full model number that is on the washer (usually found around inside of the door lip) and i can give you some options. It's an easy DIY fix.
  • GBlevins Jan 31, 2013
    I found the model #.
    WTW6600SG1
    I really appreciate the help with this!
  • B.H. Countryman Feb 02, 2013
    I'm sorry it took so long to respond. Here is one source. These guys are really good about returns and help too: http://www.appliancepartspros.com/whirlp... You can get them here though for much cheaper, but returns are a hassle and the help is iffy:http://www.ebay.com/sch/i.html?_trksid=p...
  • 76 Answers
SOURCE: Maytag washer PAV2300 water over flow
tidalwave If the water continues to flow even when the washer timer and the power to the washer are off then you are right and the water inlet valve has to be replaced. If it does it only when the washer is on then it could be different problems. In that case the first thing you have to check is the water level switch. This is the device which controls the water level. Remove the power first.Open the control panel and you will see the switch on the left side. There is the clear plastic hose connected to the switch. Make sure the hose is not loose. This is one of the most common cause of overflow. If it got loose, drain out all water from the washer before you reconnect the hose. If this is not the issue then you have to check the continuity across the water level switch therminals. When there is no water you should measure the continuity across therminals 11 and 12 (gray and orange wires). Whet the tub has filled up with water you should measure the continuity across therminals 11 and 14 (gray and light blue wires). If the continuity is wrong replace the water level switch. If you are going to do it, make sure there is no water in the tub before you will remove the clear plastic hose from the old switch. Good luck. Gendos. post back...
Posted on Jul 08, 2007
IFIXALL
  • 868 Answers
SOURCE: Kenmore Oasis HE 2708..LF error code
Replace the water valve
Posted on May 26, 2008
SearsTechToo
  • 261 Answers
SOURCE: whirlpool/cabrio washer reads error LF and will not fill machine with water.
The serial number has a two letter designation, the first is where it was assembled and the second is the year. A long fill error can be several items, we all need to know first, how full with water, is your supply low on pressure or do you have a drain hose inserted far enough to cause a siphon condition? You should hear a gurgle splash as it drains.
Posted on Sep 13, 2008
  • 39 Answers
SOURCE: Whirlpool Cabrio washer is leaking water
The problem happens when your installer throws away the drain hose u-bend, and stuffs the hose as far as it will go down the drain pipe. When this happens the end of the hose can get pushed under water, which causes the washer to siphon out the wash water when it fills. This results in an LF "Long Fill" error.
The solution is to get your installer to come back and install the washer properly.
Posted on Jun 23, 2009
TheMobilian
  • 8220 Answers
SOURCE: Water will not drain during the rinse cycle
A lot of those front load type washers have problems resulting from overuse of detergent. You should remove the panel and clean ot the sludge and lint inside. Service Manualb8c024f.jpg
Posted on May 07, 2010
What does the LF code mean?
Long Fill
LF flashes when the water level does not change for a period of time after the valves are turned on OR water has disengaged the basket but control does not detect a water level change.
  • Is water supply connected and turned on?
  • Are hose screens plugged?
  • Is water entering the tub? If so check pressure hose connection to machine/motor control.
  • See TEST #2 in manual
Jun 20, 2014 | Whirlpool WTW5600XW 3.6 cu. ft. Cabrio Top...
What is the LF Code my washer puts out
Hi Sherry,
The code definition for LF is a LONG Fill (F30). What does that mean is the next question? Here goes.
a. The fill hose may have a pinch or fold between the connections on the pressure in .
b. Are the hose screens plugged at the connections.
c. Is the water siphoning out of the drain hose ?
d. Is the water pressure at peak, check valve, filters before washer.
Now if your savvy hungry. Here is a learning curve link
Washing Machine Diagnostic Test Error Codes Cabrio Bravo Kenmore Oasis .
Okay. The next link is for the manual for your favorite machine. Manuals and Troubleshooting Whirlpool Whirlpool Cabrio Washer Fault Codes . I tried this and you need registration.
I decided to go one step further and track down a printable and savable resource for you. Yes, all, the fault codes and what they mean.
I did pretty good from memory but that link leads you to a printout you can keep right by your washer. Most of the occurrences are easy to fix without a technician. Hope this makes your day. Better. Fare. Well.
Jun 20, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool LF Error code
LF = Long Fill
Oct 19, 2012 | Whirlpool WTW6400SW Cabrio Washer
Im receiving the LF code what does this mean??
Check that the drain hose and water inlet hose are properly installed, and undo any kinks or clear any clogs if the display error reads "LF" indicating that the load is taking too long to fill, or "Ld" indicating that the washer is taking to long to drain. If the code reads "HC," the hot water hose is installed in the spot for the cold water hose and vice versa.
Also, check this information from Whirlpool DataBase: Display shows LF
Hope helps (remember to rate and comment this answer).
Sep 13, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
My washer deplayes LF and when that shows the machine unlocks and water in still in tub water does not fall down
Thanks for using FixYa. Error LF means long fill, which flashes when the water level won’t change for a period of time after the valves are turned on or the water has disengaged the basket but control does not detect a water level change. TO resolve this issue check if the water supply is turned on and the hose screens are not plugged or kinked. If the water is not entering the machine then check the water valve, also check the pressure hose connection to the machine/motor control. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 28, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
I have a cabrio top loader washer and I'm getting a LF error message
Hi
Thanks
Rylee
Aug 23, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
What does LF means? and what should I do
See the following Whirlpool Service Manual for their Cabrio washer which is basically the same as the Kenmore Oasis.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
6-1
DIAGNOSTICS & TROUBLESHOOTING
DISPLAY FAULT / ERROR CODES
DISPLAY
(Saved Code) EXPLANATION AND RECOMMENDED PROCEDURE
(F30)
Long Fill
• See TEST #2.
Nov 13, 2009 | Kenmore Oasis HE 27082 Top Load Washer
I GET A LF CODE ON MY WASHER WHAT DOES IT MEAN
Good Luck!
Feb 24, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool cabrio
LF means long fill, so if your hoses arnt blocked and you are getting good flow, try looking at your drain pipe, it should only go about 6 inches into the actual drain and zip tie it there. any further it could syphon the water out of your machine.
Apr 16, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
LF Code
under control console
Jan 12, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing Machines Logo
210 people viewed this question
Dan Webster
Dan Webster
Sal De
