The temperature not going up to target tempature
    Genius:
  • 1,669 Answers
Thermostat is not tracking correctly or the thermometer measuring it is not calibrated.
Posted on Jan 23, 2013
How do set temperature target. Its set at 68 now and cannot change it. We just moved in and have no instructions
To set the temperature and by pass the program feature press "HOLD" This feature is alternate action each time you press it changes from on or off, off to on.
This will make your 3M-22 act like a non-progammable thermostat. It will hold the target temperature you set indefinitely, until you turn HOLD off. Take care using the HOLD function as the program is now bypassed. To set a hold target temperature, press HOLD and use the +/- buttons to select your hold temperature. The HOLD icon will display on the HOME screen indicating you have changed the Target Temperature. The system will HOLD this temperature until you return to the manual screen. To turn off hold press HOLD again. HOLD is also canceled when you set the mode to OFF.
http://www.radiothermostat.com/filtrete/guides/3M-22-Operation-10may10.pdf
These things are like the old VHS tapes to program.
Hope this has helped?
Jan 12, 2016 | 3M Filtrete 7-day Digital Programmable...
Tempature keeps dropping down to 59 will not hold it temp at 101
If your spa will not maintain the temperature it is set at, the most common problem is going to be the temp sensor.
Once you replace the temp sensor you should find your temperature regulated as it normally is.
Rod
US Parts Center
Mar 16, 2014 | Home
My dryer is taking to long to dry. What tempature should it be.
Check your exhust tubing make sure its not clogged. The temperature should go as high as 220 F.
Sep 26, 2011 | Dryers
Oven temp not correct
One thing you should know about a gas oven is that they do not keep a constant tempature like an electric oven does. So going by a tempature gauge in the oven can fool you. The way a gas oven works is by "average" tempature. In other words if you take the highest and lowest tempature readings and average them out you will get the actual tempature. For example let's say that you set the oven to 350. Well first it will take about 10 to 15 minutes for the oven to properly pre-heat. Once it is preheated you can listen to the gas burner and watch a tempature gauge(flook meter is best). When the gas burner shuts off the oven tempature will continue to rise. When the oven tempature stops rising then you will take that reading. Then wait for the oven burner to come back on again and watch the tempature gauge. When the tempature gets to it's lowest point and stops then take that reading. Do this several times and then take all the tempature readings and add them together then divide that number by the number of readings you took and that will give you the actual tempature. Within 5 degrees is great but anything over 10 degrees can affect your cooking. This will give you an idea if your oven is out of calibration or not.
There is a calibration procedure. The instuctions are located in the owners manual and can be found here http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-85131.PDF
Just go to the "Thermostat Adjustment" section for the proper calibration procedure.
Jul 04, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
How do I set the tempature when I am in the setup screen, in my guide to building my computer they to set the tempature between 30'C to 50'C but I can't find the place to set it I have a Asus P6T...
Hi!
On ASUS P6T motherboard you can't really specify the exact target temperaturs for the CPU, but - by enabling the Q-Fan feature you'll be able to choose from 3 different options for the CPU Fan Profile (Standard/Silent/Turbo), thus controlling the CPU/system's tempratures (Turbo will produce the lowest temp. possible).
For more information, take a look at the manual (choose "Others" in the OS selection screen - then open the Manuals category to download the manual), on page "3-34".
Best regards,
Pelu.
Apr 17, 2010 | ASUS Computers & Internet
Oven does not maintain a consistent temperature
Is this oven gas or electric? If it is gas then it can be normal to see 30 to 50 degrees difference in tempature. The tempature in a gas oven works on the average tempature. For example: The oven tempature may rise all the way up to 370 degrees. Then the burner will shut off. And then the tempature can drop all the way to 330 degrees. Then take 330 and add that to 370 then divide that number by two and the average tempature will be 350. If your oven is electric then the tempature should be much more consistant but can have a 10 to 15 degree variance. Also the standard oven tempature guage that you put in the oven or even the temp guage built into the oven are not very accurate. We us a Fluke meter with a thermocouple to calibrate an oven. So to check your oven for proper tempature regulation you will first need to let the oven pre-heat for about 15 minutes. Then place the thermocouple in the center of the oven. If the oven is electric the take a temp reading every 5 minutes and average them out. If the oven is gas then you will need to take a temp reading when the tempature reaches it's highest and lowest points. Take at least 5 consectutive readings and average them out. You should get an average within 10 degrees of set temp(350 degrees). If it is off by 35 degrees or less you can usually caluibrate the thermostat back to proper temp. This procedure can be different for each range model. If it is more than 35 degrees off or you are getting irratic readings then the thermostat or thermostat components might need to be replaced.
Mar 16, 2010 | Kitchen Ranges
Tempature gauge does not work and the
In 1992 the sending unit should be fairly easy to find it should on the intake manifold near the thermostat housing. If you disconnect the wire going to the sender, it should be just one wire and it just pushes on the sender. Once you have it disconnected take a small jumper wire and connect the temperature gauge wire to ground (or the negative terminal of the battery). Now turn the key on, the gauge should go all the way to hot, if so the sender is bad. If the gauge doesn't move you have dash problems. Good Luck!
Dec 22, 2009 | 1992 Lincoln Mark VII
Tempature gauge quiet working emission test said it was engine tempature control and i need to know where its locared
The temperature sensor in located at the thermostat housing under the throttle body. You'll see two wires going in to the sensor, make sure the wires are not damaged and still connected. It's rear for the sensor to fail but it's an easy fix to replace it, just disconnect the wire harness and unscrew the sensor with a deep socket and replace with the new sensor in the reveres process. Good luck and hope this helps.
Jul 01, 2009 | 2000 Chevrolet Venture
Heating & Cooling Logo
41 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
