Question about Olympus SP-720UZ Black Digital Camera Digital Cameras
White line on viewing screen
When turning camera on, approximately mid screen the is a white line that appears in view
    Genius:
  • 1,019 Answers
If the line is also on your photos it is a bad censor assembly, if the line is just on the LCD than the LCD is faulty. Either way you are looking at a trip to the repair shop.
Posted on Jan 25, 2013
SOURCE: No picture on lcd screen
I have the same problem but sadly no solution.
As my camera is still under warranty I took it back to Jessops.  The camera is now with Olympus for repair.  The technician in Jessops hazarded a guess that the problem is a broken processor sitting behind the lens and as such the problem is "really bad".
Here's hoping you are still under warranty.
Posted on Oct 31, 2007
SOURCE: Lines
same problem with my canon a85 , fault ccd !
Posted on Jan 05, 2008
Agent Allan
  • 480 Answers
SOURCE: lines appear on photo's.
Hey Tia Cindy,
If the lines are vertical that is often a result of taking pictures of very bright subjects. This is aberration is called vertical streaking. If the lines are horizontal lines there is probably something wrong with your sensor and you should have the camera looked at by an authorized service technician such as bringing it to a Geek Squad® precinct in a Best Buy™ store, and they will send it out to have it looked at. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Posted on Jun 03, 2008
  • 919 Answers
SOURCE: write protect message appears on screen
Sounds as if the memory card may be corrupted. In order to remove the write protect, make sure you have downloaded and saved all of the images from the memory card to your computer and then having the card in the camera you will need to run the format option and this will permanently remove the write protect as well as all of the images from the card.
The card should be able to be used again after the write protect is removed.
Posted on Dec 15, 2008
  • 11967 Answers
SOURCE: Our Olympus 7010 has gotten the lens stuck out,
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Oct 16, 2010
Testimonial: "Fix#7 worked. Thanks so much!"
White Screen. When I turn my camera on, it has power but, the display is white and you cannot see anything through the view finder.
hi,
did you check the picture through the view finder ? if it is clear, then there may be snag in the monitor, normally the connecting cable to the motherboard become break, if so should replace it.
if the picture is visible when you turn the monitor to either side, then you can confirm the fault of the cable.
Feb 26, 2016 | Canon Elura 100 Mini DV Digital Camcorder
There are white lines in monitor of my nikon s4300...help??
I'm afraid only a technician can repair this. Perhaps some parts must be replaced.
If the camera still makes good pictures, perhaps you better learn to live with the lines. Check is the white lines appear on an image you view on your computer. If so, the sensor or processor is damaged. Then you better start looking for a new camera, because that will be cheaper than to repair you S4300
Mar 20, 2014 | Nikon Coolpix 4300 Digital Camera
Olympus VG 120 has a white line across the miidle of the viewing screen
This line appears when you take pics in the screenviewer? Also in the pc monitor when you transfer the image?
If just occurs in the screen camera, sound like a problem with the LCD screenviewer; if you have the same problem in the pc monitor view, could be a problem with thew CCD Image Sensor. The CCD Image Sensor isnt a job that you can do it, I suggest visit your techinician service or apply if has underwarranty.
Hope this helps.
Your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Oct 24, 2011 | Olympus Software VG-120 Digital Camera
View screen is white (blank) with internal cracks
Look fo the switch that has two setting. one of them will say LCD and the other Migt EVF if you have a view through your view finder this is your problem.
Jun 28, 2009 | Samsung L200 Digital Camera
The viewing screen on the back is blank white.
Somkewhere after submitting the problem, I read a blog that instructed to press all five of the small buttons in the circle on the back while turning on the power. I took me twice and regained the viewfinder. They also had written that it may take a few times.
Mar 27, 2009 | Sony Cyber-shot DSC-W35 Digital Camera
LCD viewing monitor has "optimize image" screen on it
Press up/down on the multiselector to cycle through different views of the image.
Feb 11, 2009 | Nikon D80 Digital Camera with 18-135mm...
Only a whilte screen appears when i turn on my camera(fe210)
lcd screen may be broken... or batteries not making good contact
Nov 25, 2008 | Olympus FE-210 Digital Camera
Black LCD and Viewfinder
I have the similar problem as above...Canon 5D
When camera is turned on the viewfinder is black. All other functions appear to be working correctly. I can view pictures on the card. I take a picture and it views on the screen and the spec's come up on the botton of the view finder but the viewfinder is 90 black with a bit of blur. Is this the censor or a mirror...?
Is this fixable and at what approximate cost? Would it be cheaper to replace?
Jul 31, 2008 | Canon PowerShot S2 IS Digital Camera
Kodak dx6490 digicam--
most likely a broken / faulty screen. may be the screen ribon cable but unlikely
cheapest option is to get a replacement from a broken camera (ebay or similar) and swap it out yourself.
there are a couple of "tricks" do getting this camera open drop me a line if you decide to proceed...
best of luck
Feb 08, 2008 | Kodak EasyShare DX6490 Digital Camera
Black and white lines in view finder
Screen or main board failure. If it is still under warranty you may have a chance bit if over a year or so old - not worth considering for repair- though you could try. take a look through the file here http://www.fixya.com/support/p423-nikon_coolpix_5600_digital_camera/solutions
May 11, 2007 | Nikon Coolpix 5600 Digital Camera
Olympus SP-720UZ Black Digital Camera Digital Cameras Logo
138 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
