Question about Sharp ELECTRONICS PGF212XL PROJECTOR PGF212XL 2400 Projector Lamp
On my sharp pg f212xl projector when i turn it on i hear a click and the start up sound then i hear another click about 5 seconds later it shuts down and the power led blinks red
Ive tried takeing out the lamp and putting it back in (same lamp) and unplugging it and plugging it back in
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 23 Answers
SORRY - it needs a new lamp. It is a protection for the projector so the bulb doesn't explode.
I purchase hitachi projectors with 3 year bulb warrenties now for our school as cheaper in long term
good luck
Posted on Jan 30, 2013
5 Suggested Answers
dhiman
  • 115 Answers
SOURCE: XG-C50 Problem
Hello
Replace the fly-eye lens of projector.
Viren
Posted on Jan 21, 2008
  • 9 Answers
SOURCE: projector turns on then shuts off after a few seconds
Sent projector to V3 Systems & Services Pte Ltd 64522679
1st independant Projector Service Centre (SINGAPORE)
Chip & Component level service on board level electronics
Posted on Dec 04, 2008
SOURCE: PG-C45X projector wont power on
To solve this problem, simultaneously press the "Input", "Enter", and "Undo" buttons. While holding these buttons, press "On". When the project turns on, you should see "LAMP 100%". This indicates that you have successfully reset the lamp life timer.
Posted on Jun 06, 2009
gopakumarg43
  • 75320 Answers
SOURCE: possible lamp problem for sharp pg-m10s
Hello
Check the heat sensor fitted with the lamp assembly. If this sensor does not work properly, or its control circuit has some trouble with it, it will always give a high temperature signal to main system control, will finally shut it down. OK.
Posted on Nov 19, 2011
Hooking up projector to laptop with only HDMI port
The PG-F320W has a DVI-I port between the VGA/Component input and the VGA output. You will need an HDMI to DVI cable or a HDMI to DVI adapter and either an HDMI or a DVI cable. If you use the audio input of the projector, you will also need the audio cable between the computer and the projector. (Make sure to disable the HDMI as the audio playback device. In Windows, go to the Hardware and Sound Control Panel. Then go down to Sound and Manage Audio Devices. Click on the Playback tab and check your output device. Click on Start for Windows 7 and earlier, Windows Key + X for Windows 8. Then select Control Panel.)
Monoprice.com has good prices for most cables. The HDMI to DVI cables are here: http://www.monoprice.com/Category?c_id=102&cp_id=10231 .
The manual for the PG-F320W is available here: http://www.sharp-world.com/products/data_projector/pgf320w/pdf/PGF320W_ex1_en.pdf . See page 21 for the DVI cable connection information. See page 61 for video resolutions that the projector can handle.
I hope this helps.
Dec 13, 2013 | Sharp PG-F320W Projector
How do I unlock the buttons on the projector
Hold down Enter button for 5 seconds it will unlock
Aug 09, 2010 | Sharp Notevision PG-B10S Multimedia...
Unlock Sharp XR-10X-L Notevision Proj. says keylock function on
According to pg. 45 in the owner's manual, you turn Keylock function ON by holding down the ENTER key on the projector for about 5 seconds while the projector is being turned on.
To take the Keylock off-- Hold down the ENTER key on the projector for about 5 seconds. If the projector is in standby mode, you can release the keylock by holding down ENTER and STANDBY/ON keys simultaneously for about 5 seconds.
Apr 27, 2010 | Sharp XR-11XC DLP Projector
How do i unlock buttons on Sharp projector
Hold down 5 seconds standby button and its unlock
Feb 11, 2010 | Sharp Notevision PG-A10S Multimedia...
Shutting down in the middle of presentations
it's overheating from excessive dust or lack of air flow. blow the dust out of it with canned air and make sure all of the vents are free from obstructions.
Feb 02, 2010 | Sharp PGF312X DLP Projector
Sharp PG-M20X digital projector runs 2-5 minutes then shuts off
the Fan has the problem , I had the same of yours. I noticed some particle was inserted in the center of the fan and removed it , worked perfectly. If old one produce little particles.
Good luck.
Dec 03, 2009 | Sharp Notevision PG-M20X Multimedia...
I got a free sharp notevision PG-m20x. I plug it
if you don't hear a high-pitched whir, the colorwheel needs replacing. if you do hear it, the lamp may need replacing. if the lamp is new, there is a power supply problem.
Sep 04, 2009 | Sharp Notevision PG-M20X Multimedia...
Projector shut down after replacing the bulb and wont turn on now
are any of the leds on the top of the projector lit? if so, which ones? red or green?
Apr 09, 2009 | Sharp Notevision PG-B10S Multimedia...
XG-C50 Problem
Hello
Viren
Nov 09, 2006 | Sharp (BQCXGC50X1) Projector Lamp for...
Sharp ELECTRONICS PGF212XL PROJECTOR  PGF212XL 2400 Projector Lamp Logo
105 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
