Question about Garden
Craftsman leaf blower 358.797550 - Garden
boscia
  • 163 Answers
SOURCE: gas blower craftsman leaf older modle
check the fuek lines for hole and leaks, check the fuel filter and clean if necessary. remove the carbuerator and inspect the gasket; it should be soft and flexible, if it seems hard or brittle replace it. clean the carb with carb cleaner sray (available at any local auto parts store) and compressed air. make sure you get inside the small fuel rail holes. check the primer bulb for pin holes and seating/sealed properly. if that doesn't work have the carb repaired at a service center or replaced.
Posted on Nov 30, 2008
  • 211 Answers
SOURCE: craftsman leaf blower
Hi
Check the fuel lines,fuel filter and clean the fuel tank.Disassembly the carb and clean it carefully.Diafragm type carb has a fuelpump,pay attention to it ,has to be tighten not folded.When the engine gets warm ,the fuelpump cannot keep the right proportion of fuel and the air/fuel mixture is changing.It has to be changed.
regards savumihai71
Posted on Dec 05, 2008
SOURCE: craftsman leaf blower/vacuum
There is a round grille on the bottom of the unit. Insert a flat blade screwdriver into the latch to release it and reveal the vacuum opening. You should have a two-piece intake pipe that will attach to the opening.
The collection bag attaches to the smaller outlet where the blower pipe used to be (unscrew the wing nut to release the blower pipe). The bag clips onto the hooks at the base of the opening.
Posted on Apr 24, 2009
SOURCE: craftsman leaf blower, primer bulb will not return, won't start
primer bulb on weedeater will not return to normal or **** gas into it. new primer bulb. lines to tank have been repalce and can blow through them but primer bulb will not push air into tank
Posted on Aug 21, 2009
rwvanlue
  • 486 Answers
SOURCE: My craftsman leaf blower will not start.
Basics to check:
1) Spark plug - brown or dark brown - OK
- aluminum or silver - piston/cylinder scored
a) is it carbon or fuel fouled
b) is there spark
2) Compression - 125 to 150 psi
3) Muffler remove for inspection
a) exhaust screen clean or plugged
b) inspect cylinder wall/piston as the flywheel is slowly rotated
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
5) replace gaskets/diaphragms
b) use a spray carb cleaner to clean jets, holes, and body of carb
Posted on Nov 11, 2009
Where can i buy carbon brushes for my craftsman leaf blower 358 799 400
Parts for Craftsman equipment can be obtained at you local Sears store.
Jul 30, 2014 | Dewalt Dw4902 1-inch By 1/4-inch High...
I have a 316.794980 craftsman leaf blower with no spark from the plug
If the plug is getting no spark then you need to check the ignition coil it is probably no good. If you go to searspartsdirect.com and enter your model number it will show a diagram of your leaf blower and you can go from there. Hope this helps.
Jul 16, 2014 | Craftsman Garden
Leaf blower is hard starting
check your filters clean,,if not that clean carb out
Nov 14, 2012 | Craftsman Garden
I need the spark plug gap for a Craftsman Leaf Blower M/N: 358.794741 please.
First, I would like to give you a copy of your online owner's manual:
http://www.managemylife.com/mmh/owner_manuals/15531/CRAFTSMAN-Blower-Gas-L0803240?brand_name_search=+358.794741+
The gap is NOT mentioned in the maintenance section. The normal setting for a machine of this type is a gap of .030"
May 21, 2011 | Craftsman Garden
I'm looking for a replacement bag for my craftsman model 358798370 blower/vac. The zipper is shot and there is a hole in it. Any ideas ?
http://www.searspartsdirect.com/partsdirect/part-number/Craftsman-Parts/Leaf-blower-Parts/530402533/0071/358/Model-358798370/0247/1503110?keySuffixId=NA&productTypeId=x&searchModelNumber=358798370&subCompDesc=Replacement%20parts&brandDesc=CRAFTSMAN&modelDesc=BLOWER&blt=11
Oct 31, 2010 | Craftsman 4 Cycle Blower/Vac
Hi. My craftsmal leaf blower runs OK for 3-5 then dies????
Could be a blocked vent on your fuel tank - is there a vacuum in the fuel tank immediately after it stalls?
Oct 25, 2009 | Craftsman Garden
Need bolts for carborator for gas leaf blower model #358
Hello. One way I found to get Craftsman parts is to order them online at the Craftsman website.
CYA, Gator241
Feb 06, 2009 | Craftsman 4 Cycle Blower/Vac
String caught in fan of Craftsman 79474 garden leaf blower
That srew is most likely a Torx style size T 25 or a T 27
Nov 13, 2008 | Craftsman 4 Cycle Blower/Vac
Garden Logo
73 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
