Sudenlink remote not working for cable box
The remote will turn the TV on and off but will not work for any cable buttons on the cable box. We pushed the cable button, changed the batteries, and even went to Suddenlink and exchanged the remote. The new remote is not working the cable box either.
  • rydenkd
    rydenkd Jan 25, 2013
    Thank you for all of the suggestions. The codes did not have to be reset as the remote worked for everything except the cable. We ended up turning everything off and unplugging it: the cable box, etc, waiting a few minutes then putting it back together. I'm not sure why we didn't try this initially (since this is the same process we go through whenever the internet goes out) but it worked!
  • 20 Answers
Hi rydenkd- My name is Shannon and I am with Suddenlink. Please visit our self-help site to troubleshoot and reprogram your remote here: http://help.suddenlink.com/Television/Pages/RemoteControls.aspx. If you still run into difficulty, please feel free to contact me directly at shannon-AT-suddenlink-DOT-com. Thanks!
Posted on Jan 23, 2013
4 Suggested Answers
SOURCE: remote control
I had the same problem.  The problem is strange and seems to be with the receiver in the TV and not the remote control.  The reason I say this is that when this first happened my Samsung brand DVD could actually control the TV.  This then also failed, but still works fine with the DVD player.
Anyway there is an even more bizarre fix to all this......
- Remove the batteries from your TV remote. - Press and hold the red (ON/OFF) button for at least 1 min. - Replace the batteries and hey presto!!
I know seems far fetched but I found it on the Samsung website and it does work.
Posted on Mar 30, 2009
dauphine
  • 207 Answers
SOURCE: Magnavox TV all in one remote code
http://www.urc.philips.com/
Posted on Apr 29, 2008
SOURCE: The Sony TV remote doesn't work (with good batteries).
NSE urc22b-12 please pin code forTV SONY model KV-A2921D
Posted on Sep 28, 2009
Mitsubishi wd-73738 turns itself back on
It sound like the remote is powering off the cable box but not the TV. The remote control may need to be reprogrammed to the TV. When you press power it may only power off the Cable box. At that point, try pressing the TV button on your remote and then Power. If it does not power off the tV after pressing the tV button, the remote may need to be reprogrammed to the tv. Cable companies usually have the codes needed to program their remotes to the TVs.
Jul 09, 2016 | Mitsubishi WD-73738 73" 3D Ready DLP HDTV...
How to program my decibel electronics jumbo universal remote to my comcast cable box
I pushed code search different blink appeared pressed tv press code then use on buttons. On all the code
Dec 20, 2012 | Televison & Video
Neither of my remotes (1 came with the television when I bought it and the other is a remote for my cable box that is programmed for the TV too) are working on my 47LG50 television But the remotes have...
Tries take both remotes controls pushes all the funsctions butons one by one on the front of a turn on Digital Camera,see if u will able to see all the INFER RED signal white light will flashing on the Digital Camera viewing screen.To make sure both the remotes are working and all the buttons are have INFER RED light signal out.Tries pushes all the tv manual buttons on the tv side too see if it is funsctioning too.If all these work testing work,than take some rubbing alchahol put on a rag clean the INFER RED sensors signals on the tv an the cable box by the tv power light LED indications lights.Tries these steps,make sure tv manual control tv side panel work and both remotes works and clean both INFER RED sensors on cable box and tv make it work better.Unplug the cable box for an hour for it to reboot and updating it softwares.Replug the cable box and now tries the tv remote or cable remote again,should functions now.
Aug 20, 2011 | LG 47LG50 47 in. LCD HDTV
Mitsubishi CS-31205 TV Never had a remote for this great TV, but, accidentally pushed a button on my Comcast Cable remote and the TV is now in "Mute" mode. Not the Comcast box 'Mute' . Have...
You are supposed to be able to switch the Comcast Remote to TV mode and switch Mute on that remote to change back to standard volume. If that doesn't work try volume up on the TV. Otherwise if neither of those work then check Remotes.com for a replacement TV Remote.
Mar 09, 2011 | Televison & Video
DVI Alert, your HDTV does not support HDCP. what does this mean? Please use YPrPb component connection to watch
Ok so, I was having the same exact problem but I got mine to work.
Make sure you have your HDMI cable is connected from the TV and cable box....
1)Turn off your tv and reboot your cable box (my cable box was rebooted by pushing the following buttons AT THE SAME TIME: "info," "vol ," and "vol-").
2)Once your cable box reboots completely, power it and the TV on...
3)Push your INPUT button on the actual TV REMOTE. Give it a couple of seconds and then use your CABLE BOX REMOTE to begin switching the channels. Your HD channels will be in the 600's if you have the same cable company as I do.
Hope this helps...it worked for me
NOTE: Your COAXIAL should only be plugged in from the cable outlet on the wall to the cable box. Your HDMI cable will be the one to plug FROM the CABLE BOX to the TV
Aug 08, 2010 | LG 42LC2D 42 in. LCD HDTV
Tv wont turn on with the remote or the power button
Hi
There are a lot of generic remotes available. Target has them for $10.00. That should help that problem, now with the button stuck in that's a different. Someone will have to remove the power cord, open the TV back and eyeball the on/off switch. If the button has come off the pad then just push it back in. If the pad or circuit board are broken then disconnect them from the mother board and use the generic remote to turn the TV on/off.
Mar 13, 2010 | ViewSonic N3735W 37 in. LCD TV
The cable guy programmed the cable remote to turn on/off the TV. We used it to turn the TV to stand-by. Then pushed the power button on the TV to turn the power off. Haven't been able to turn the TV on...
First use the original remote control that came with your tv, or just manually turn it on at the tv itself to bes sure it is working. If it works you should call the tech support for the cable company to program their remote control to a different code - or put it back to to factory state and just use two remotes.
Sep 12, 2009 | Panasonic TC-32LX50 32 in. HD-Ready LCD...
Have a new Phillips 42" lcd tv. my cable box remote has been working intermittently. However the white light near the remote sensor on the TV blinks whenever I use the cable remote. after changing bat
your TV and, your cable box both "see" a series of invisible (infared) flashes of light like morse code these flases tell them what to do.one answer is to: buy a universal remote so that you can program a button for each device then when you want to control the cable box just push the "cable" button and, then volume etc. to turn your tv off push "tv" then "off" the service man was right but he should have explained this to you
also your cable remote may be programable to work with your tv like a universal remote check with your cable co.
May 22, 2009 | Televison & Video
Big button remote rcr 4258
does not have all the codes for every product,
Please give me the model # for the cable box -scientific Atlanta and the model # for Magnavox T.V.
also goto www.replacementremotes.com (336)969-1842
They will find you REPLACEMENT remote control CODES, not remote control
Apr 12, 2008 | RCA Universal Remote Control
Olevia 242T television
The code you want is 11610. Buy a remote that can accept this code.
Dec 01, 2007 | Televison & Video
Televison & Video Logo
308 people viewed this question
Top Televison & Video Experts
Electro Med Services...
