SOURCE: getting a 59.c0 error on hp clj 3505
Is the transfer unit installed correctly?Check and refit the transfer unit.
SOURCE: my printer clj 2840 displayed error code 59.c0
This mean a main motor error occurred. X description: 0
= Motor error 1 = Motor start up error 2 = Motor rotation error
1. Turn the printer off, and then turn the printer
on. 2. Check and reseat the fuser and toner cartridge to make sure
they are not hindering gear movement in the drive train. 3. Check
the main motor’s cable to ensure that it is seated properly. 4. If
the error persists, replace the main motor.
SOURCE: hp clj 3500 with a 59.a0 code have replaced motor
Which motor did you replace?
This is a Drum motor (M3) rotation error
RM1-0733-000CN
Good Luck
SOURCE: 59.c0 error in hp clj 3505 printer
For those users who are having a problem with the printer motor, this C level problem is referred to as 'developing disengaging motor rotation error'. Most likely, this problem points to an issue with the function of the DC controller: either it has failed or it has affected the developing disengaging assembly. The solution is quite simple and the user may fix the error in a matter of few steps.
The first step is to reconnect the J16 connectors that are used for the developing disengaging motor to the J1100 connectors that are used for the DC controller PCB (that is the printer circuit board of the DC controller). After connecting these two connectors to each other, the user must replace the developing disengaging drive assembly directly.
The final step is to replace the DC controller PCB, after which the printer is to be recalibrated. for more information....
http://www.fixya.com/support/t503092-59_c0_error_hp_color_laserjet_5550
SOURCE: HP colorlaserjet 9500 printer giving me an error
This error is caused by a rotation error on the ITB (transfer belt). If turning the printer off and on again does not resolve the 59.00 or 59.A0 error, remove and reinstall the image
From the HP Service manual
transfer cleaner.
Post back if this does not resolve the error.
transfer cleaner.
