Question about Rheem 42VR50-40F 50 Gallon Natural Gas Water Heater
Installation manual for Rheem 42VR50-40F 50 Gallon Natural Gas Water Heater
  • 2692 Answers
SOURCE: dripping from drain spout
If you are refering to the "Dripping coming from the preasure tempature valve,Then just turn off the valve where the water goes into the heater and open the P/T valve with a bucket below it draining only emought water to get below the level where it reaches.     Normally the drain valves are plastic with a Male hosebib attached.  Attach a  garden hose to the rain and run it out to a point lower that the vaslve in order for gravity to drain the tank.The valve opens counter clock wise. If the valve is stuck or does not drain,and you have a foor drain handy,remove the whole valve and replace it with a boiler drain valve.  If The tank is located below the drain level then you will have to either pump or carry the drain water to the higher level.     Replace the P/T valve  and reinstall the associated associated piping. I would use tefelon tape on the P/T pipe theads.    You may have to open a hot water faucet in order for the air to replace the water in the tank ,in order to drain.
Posted on Jan 31, 2009
  • 297 Answers
SOURCE: Rheem 50 gallon gas water heater less than one
it could also be the dip tube. this is a tube that is installed at the time the unit is made.it is a plastic tube that is on the cold intake side of the hot water heater.it may have fallen inside the unit or may not be in the unit at all check to see if there is a plastic tube this will help the heater stay hotter for a longer period of time. good luck with your project.
Posted on Sep 29, 2009
  • 454 Answers
SOURCE: I have a Rheem 50 gal. natural gas water heater
The most common reason a pilot light will not stay lit is a bad thermocouple. How old is the water heater? If the pilot light will light, but then go out when you release the safety button, that is a sure sign the thermocouple is bad. You can buy a replacement thermocouple at your local home improvement store. There is a small chance that the control valve has gone bad, but that is highly unlikely.
Posted on Feb 23, 2010
vincob
  • 718 Answers
SOURCE: I have a Model 41V50 Rheem water heater (50 gal.
You don't need to find the same exact model to replace your water heater, any 50 gallon water heater will do unless you have a brand specification that you like to stick with.
Posted on Jul 25, 2010
  • 9 Answers
SOURCE: rheem power vent motor doesn't shut off
There could be blockage in your water heaters venting on the outside of the home. It sound like the high limit switch has been tripped. Try unplugging the tank and plugging it back in. this will reset the tank. if the problem persists you will want to call your provider for service.
Posted on Jul 29, 2010
Have 75 gallon gas water heater. Can I run 90 PVC off top power vent without vertical PVC first? Have Richmond unit.
1) I believe you can immediately elbow the PVC pipe.
There is a limit for how many elbows can be used between blower and termination, and limit is determined by diameter of PVC pipe.
2) Copy following link for venting resources and typical Rheem and Richmond power vent manuals, and diameter-elbow pdf from Bradford White.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#venting
3) Richmond is Rheem. Product manual will show specifications for venting.
Product warranty is voided if installation does not follow specifications shown in manual.
Feb 20, 2013 | Rheem Richmond 75 Gal Natural Gas 6 Year...
Where can i get a 21dv50 water heater to buy
21dv50 is discontinued. This is ordinary tank-type 50 gallon gas water heater.
Amazon sells 50 gallon 22V50F1 Rheem water heater for $420 with free shipping ... but who carries the warranty?
Frankly you can get in-store returns, and buy same quality gas water heater at local box store since Rheem makes GE water heaters at home Depot.
Other brands are equally good, as AO Smith makes Kenmore water heaters at Sears and Whirlpool at Lowes.
I prefer the AO Smith because maintenance is easier.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Sep 17, 2012 | Rheem 40 Gallon FVR NATGAS Low WATER...
Rheem pronto tankless water heater just barely warm model # 74pvn-1. This is in a house we are just purchasing. Also it looks like it may be attatched to another tank water heater , Help please
Before calling service technician, open following link for Rheem troubleshooting resources.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Sometimes people attach tankless to tank-type heater to preheat incoming cold water.
Additional tanks are also used to store solar heat, and some installations have tank-type because tankless is unreliable. Service technician can sort out the function correctly.
http://waterheatertimer.org/Tempering-tank.html
Owner should read tankless manual thoroughly, especially troubleshoot and maintenance sections. Tankless require yearly maintenance.
Since tankless are expensive to repair and replace, you might be able to fire up the tank-type water heater and provide hot water without much cost.
You can also install tank-type gas water heater yourself. Lowes sells 40 gallon for $317.00, and then you offer 10% less.
http://waterheatertimer/How-to-install-gas-water-heater.html
Apr 19, 2011 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
If my 50 gallon water heater is leaking can i replace it with a smaller water heater?
There should be no problem replacing a 50 gallon heater with a smaller size heater as long as the codes for your city/town allow it. You may also need to pull a permit for the installation, check with your municipality. Some codes state that a home with X square feet or whatever measurement they want to go by, will need at least a 50 gallon hot water heater. Obviously all installation instructions and codes apply to any new hot water heater installation.
Sep 10, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
I have a Model 41V50 Rheem water heater (50 gal. natural gas) and needs to be replaced. However, I can't find this model at any of the local stores. Has this been discontinued? If so, what can I get for a...
Jul 24, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
Rheem 42VR50-40F 50 Gallon Natural Gas Water Heater Logo
101 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
