Question about GE Wsxh208a1ww Front Load Washer Washing Machine Motor Control Unit Wh12x10154
Ge washing machine will not drain
Shock was broken, i replaced both shock and now machine will not drain
Drain by lowering main drain hose below pump into shallow bucket, remove front lower panel , take large hose off back of pump clean out hose, may have to take 2 screws out of pump mount to look in pump mine was being stopped by a nail,the$6.75 in change was still in the hose
Posted on Jan 23, 2013
SOURCE: GE WASHER FRONT LOADING
There was a revision to the shocks which you'll see when you get the new ones. Squeeze the two retaining barbs in with a pair of pliers then twist and push rearward. On the right one you have the air dome in the way - it helps to have a buddy pull from the back while you release the barbs.
Posted on Dec 28, 2007
SOURCE: GE SpaceMaker washing machine does not stop filling.
try replacing your water selenoid coming in. remember it isnt a mechanical timer it is a computerized timer, so if the selenoid isnt the problem, it might be the computerized timer. computers are very finicky, pain in the a- -!
Posted on Mar 27, 2009
  • 3230 Answers
SOURCE: G.E. washing machine will not drain completely
It won't drain
If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems:
If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
good luck.....
Posted on Mar 28, 2009
SOURCE: GE profile washing machine won't agitate it spins out, drains,
Pull the agitator out and check the drive collar splines.If you have the model I think you have just pull straight up on the agitator. Once removed you will see the drive collar with a 7/16 head bolt,remove it and pull off the collar.First before pulling it off spin it if splines are stripped it will spin freely.
Posted on Apr 15, 2009
tbirdfan1
  • 3051 Answers
SOURCE: ge washer wbse3120b2ww does not fill water and go to the final sp
hELLO THERE
well it is looking like you have a water controle solinoid valve that is malfunctioning and needs to be replaces i would contact your nearest dealer to see what the part is going to cost and have it replaced and if you have a warranty with the machine see if you can use it .
best of luckmike
Posted on Jul 31, 2009
Washer tries and fails repeatedly to enter final spin
Depending on the model number, if a shock has broken the tub might have a broken inner spin basket support broken also. That can throw the spin basket off balance not allowing it to get up to high speed spin.
Jul 17, 2014 | Kenmore Washing Machines
GE model number WWA7070VBLHA machine will not
first,check for any obstructions in the tub to pump then from the pump to the house drain,including and kinked hoses,if the washer senses any back pressure from these it won't drain or spin,also check the pump inside to make sure there are no impellers broken or missing on the pump or debris inside the pump
Apr 01, 2010 | Washing Machines
A broken shock, how to change?
They have little plastic tabs that need to be pushed in when removing. There is a video of replacing these on a similar model at www.appliancehelponline.com/servicemanual.html
Mar 23, 2010 | GE WSXH208A Front Load Washer
Loud banging noise durning washing machine spin cycles.
First plug off the wall. Open the machine from behind to examine if any shock-absorbers(known as dampers) or springs have come off or broken. Your dealer could help with spares. But you could do the job yourself.
For spares:
RepairClinic.com (which is good)
espares.co.uk
AppliancePartsPros.com
Mar 02, 2009 | GE WJSE3110A Top Load Washer
Shock absorbers are broken
just buy the new shocks(should by pair)I know they had 2 way one they have pin anoter kind they have clip lock to the bottom of the sheet metal(push the clip lock on both side of the shock and turn c/cw.good luck
Sep 25, 2008 | GE WSXH208A Front Load Washer
Dec 28, 2007 | GE WPXH214A Front Load Washer
GE Wsxh208a1ww Front Load Washer Washing Machine Motor Control Unit Wh12x10154 Logo
89 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
