Question about Moen & One Handle Tub & Shower Faucet
No water pressure in tub/shower at all and tub will not drain
  • 102 Answers
SOURCE: low water flow in Shower
Definitely try reversing the cartridge.
Posted on Mar 11, 2009
  • 49 Answers
SOURCE: Moen shower/tub faucet
hi... yes that's a very common issue with moen "cartridges" -- it's very simple to fix..... grasp the handle and give it a gentle tug upwards when the water is on... if it retracts again, pull the handle out again and tug again but this time a bit harder. Not sure what causes this on new cartridges but it will fix your issue.
Posted on Sep 03, 2009
  • 119 Answers
SOURCE: & One Handle Tub & Shower Faucet : i have a moen shower faucet and i get not hot wate...
these valves can be adjusted by removing the handle and adjusting the white gear that regulates the hot and cold that come out, try going more to one way if it gets colder then go the other way.
Posted on May 19, 2010
packrat1948
  • 528 Answers
SOURCE: Tub faucet pressure is good. The shower head is
You need to remove the shower head and clean the fitter screen.
Posted on Jan 30, 2011
packrat1948
  • 528 Answers
SOURCE: My Moen Tub and Shower
Take the handle back off and rotate the stem one half turn clockwise and put the handle back on.
You'll be good to go!
Posted on Mar 05, 2011
K-1357 kohler whirlpool tub there is leaking only when the tub is filled and drained. when taking showers there are no leaks 3yrs old
Overflow? Seal around drain may be good enough for shower, but leaks with a little more pressure from the filled tub. Filled tub may flex the tub and drain components. What about the overflow. I bet some water is going over, but it isn't used for showers. Double check. Paper towels tied in stratigic locations always help me find a leak. Leak makes the towel soak up water nearby. It's most wet at the point of leak.
Mar 08, 2015 | Kohler Home
M delta 174939-ss-i shower has no pressure just a trickle of water comes out. I have full pressure at tub and sink in bathroom, just not in shower which a stand alone shower.
Hello Mark
is the water still coming out the bottom when you pull up the lever to make the shower come on ? if it is then the tub valve is bad . if little or no water come out of the bottom then the head is going to be clogged and you have have buildup inside the filter /screen which could be located in the end of the hose at the head or inside the head unit itself. .
Nov 05, 2013 | Delta 174939-SS-I Carlisle Monitor 17...
When lever on tub spout is pulled up for shower use some hot water still comes out of the tub spout...reducing water pressure and temperature of water coming out of the shower head... Tub spout does NOT...
2 things can be happing here depending on the age of the tub spout. If the spout is more than 5 years old, you may need to replace it. if not that old then you may have a screen filter blockage in the shower head itself. remove the shower head from the shower neck and see if there is anything in the filter. while you have the head removed, try the tub spout again and see if problem continues. this should guide you in the next step to either replace the tub spout or just clean the shower head screen filter. Hope this helps.
Dec 29, 2010 | Cifial 295.604.625.SO Polished Chrome...
When i'm filling the tub with water, the water back feeds up to the shower head and sprays out. I changed the spout and also moved the shower knob to make sure it wasn't stuck in the up position for the...
You will have water coming out of the shower head when you have really good water pressure. There might be more water volume coming out through the valve then what the tub spout can handle and in turn sends the water up to your shower head. When you fill your tub try turning the water only half way on not at full pressure, does this keep the water from coming out of the shower head? Most likely your valve has a 3/4" supply line while your shower head and tub have only a 1/2" supply line. Sounds like you have more volume to the valve than what the tub spout can handle. You might consider one of two things: 1) you can put a water regulator on the main supply line going into the house to lower your pressure, or 2) change out the supply line to the tub spout, increasing it from 1/2" to 3/4". Let me know whats going on.
Dec 03, 2010 | Delta Home
Water steams out of shower head when tub faucet is on
check the tub faucet the pull lever maybe slightly faulty causing back pressure in line and pushing water up to shower head --u may have debris in tub line causing partial blockage -or u have alot of water pressure coming in and it is to much for the lines to handle and it is pushing up to shower head
Feb 26, 2010 | Delta & Leland Lavatory Faucet
Shower/Tub Diverter Value Low Water Pressure
I had the same problem. I discovered that an O ring was missing (or I lost it without noticing) from a new diverter that I installed. Just got an O ring that fits on the threaded part of the collar where it meets the pipe. Worked fine. Amazing how a little plastic piece could make such a difference.
Jan 25, 2010 | Eljer Arlington Non-Jetted Acrylic Bath...
I have a large whirlpool tub in MB on 1st floor. When letting water out of tub it is coming up in a large walk-in shower. The shower is draining fine...need answer! thanks
sounds like there may be some blockage in pipes. try to run a long snake through both drains or run all fixtures in bathroom and try plunging vigorously in tub and shower while running water. if nothing still, it may be possible that your underground plumbing is back graded or incorrect fittings and plumbing installation.
Jun 27, 2009 | Brasstech ''P'' Trap Kit - 3013
Moen & One Handle Tub & Shower Faucet  Logo
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
