I have a desktop computer mother board asus a8n32 sli deluxe i connect the ethernet to computer i cannot get ethernet to turn on could some one help with this is issue
  • 3,606 Answers
Hello the homepage is here:
http://support.asus.com/download.aspx?SLanguage=en&m=A8N32-SLI%20Deluxe&p=1&s=21&os=17&hashedid=qTm2JotIWNbpEVrX
Try to renew the lan-driver
But first select your windows system.
Open the lan folder, and click on global for download.
The file needs to be unziped, before you install the driver.
Please uninstall the old one first.
Did your internet connection work, before the problem occur ???
Try to check your internet connection, on another pc.
Is the router or modem set on ??
Try also this: open start = select run = type cmd press enter = type
ipconfig/ release press enter, and wait for the pc to work,
next type ipconfig/ renew and press enter.
You have now renewed your ip adress.
At the back of the pc, where you connect the lan cable, does the diodes lid ??? here is a amber and a green one.
You could also have a virus, or some kind of malware, so your internet is blocked.
Remove the virus with this program:
http://www.malwarebytes.org/products/malwarebytes_free/
Hope this will help you
Posted on Jan 23, 2013
5 Suggested Answers
Vish2
  • 74 Answers
SOURCE: new build computer wont turn on (ASUS A8N32-SLI Deluxe Socket 939)
The ATX power supply needs to have pin16(PS_On#) to be connected to COM for it to work. When you press the power switch on the front panel of the computer, you are essentially making this connection. Check that the cable from the power supply to the motherboard is making good connection. You can verify operation of the power supply by shorting Pin16 to pin17 on the powersupply output, with a paper clip. Pin16 is usually a green wire and 17 is black. Hope this helps. -Vish
Posted on May 04, 2007
SOURCE: On board ethernet driver conflict with windows XP
go to the bios settings & there you can disable the onboard LAN ....
so by this you will be able to boot from your hard drive ....
you can go to the bios settings by pressing F2 (or delete key in some PC s ) at the time of the booting (before the OS loads)...
there in bios settings just search for the LAN device & disable it ...
that s all your problem will be solved ....
any doubts reply me
i am always here to assist you
thank you
bye
rate my solution as per your satisfaction
Posted on Jul 05, 2008
  • 135 Answers
SOURCE: motherboard drivers
http://support.asus.com/download/download.aspx?SLanguage=en-us&model=A8N32-SLI%20Deluxe
find drivers here
Posted on Jan 18, 2009
SOURCE: ACPI\PNPB006 for A8N32-SLI DELUXE Windows-7
disable MIDI and GAME port in BIOS:
Power up PC, Press DELETE to go in BIOS
Go to Onboard Device Configuration
Posted on Oct 10, 2010
My old mother board a 939 socket took a dump i have gtx 285 evga video cards and x-fi fatality sound card im looking for a good bundle for this to go in to would like to stick with a asus board and...
Socket 939 Motherboards are pretty rare. Basically, if you find any socket 939 motherboard, the parts you have now should all fit precisely since there are only a few socket 939 motherboards right now on the market.
Here is one i found.
Mar 07, 2011 | ASUS A8N32-SLI Deluxe Motherboard
"A8n32-sli deluxe" SATA support disapeared
call or visit ASUS support forums, you may need to RMA this board.
Aug 09, 2009 | AMD ASUS A8N32-SLI Deluxe Socket 939...
2nd sata connected and xp won't boot
It seems you have not made the second SATA the slave of first SATA. You'll have to fix the jumper pin in the designated slot to make the second SATA the slave. a1d66e3.jpg
Jul 07, 2009 | ASUS A8N32-SLI Deluxe Motherboard
Cant connect to web with ethernet cable
Well what setup do you have, single computer? Make sure your network adapter works, is the key..run cat 5 cable from computer to modem and modem to wall outlet. If possible try your network adapter on another computer.
Feb 19, 2009 | ASUS A8N32-SLI Deluxe Motherboard
A8n32sli deluxe bios recovery error
Put the bios on a USB jump drive, or a burn a cd. Or make a disk.
Jan 23, 2009 | ASUS A8N32-SLI Deluxe Motherboard
Fan not working on a8n-sli delux
Hi wilson756168,
Here is the link to buy a new replacement chipset fan:
http://estore.asus.com/shop/category.asp?catid=131
You'll need to become a member & sign into Asus to order a new chipset fan or you can call Asus directly. I know there are four black pins with tiny springs on the back side of the board under the fan. Its been so long since I changed one of these. It may be best to wait until the new one comes in before removing the bad one. Another option would be to call Asus tech at 1-812-282-2787 IL M-F 8-5:00PM EST and ask for "How to remove fan" from a tech.
Or you can buy a better chipset fan that will last longer & cool far greater than Asus fan.
(Best option).
http://www.newegg.com/Product/Product.aspx?Item=N82E16835425007
Good luck wilson!
Mike
Nov 24, 2008 | ASUS A8N32-SLI Deluxe Motherboard
A8N32-SLI Deluxe - Can not Load 'ASUS UPDATE' fro CD
It's not you. Asus's program from the CD doesn't function as you might except. You'll need to download, ASUS Update V7.06.02 Install Program for Windows 2000/XP/2003 & 64bit Windows XP/2003 within Bios Utilities. And flash your Bios from a floppy. Than download the Bios version you want. Having trouble getting the file to unzip? Download again but this time choose a different site. Like (Global) instead.
Luck!
please vote...
Feb 18, 2008 | AMD ASUS A8N32-SLI Deluxe Socket 939...
New build computer wont turn on (ASUS A8N32-SLI Deluxe Socket 939)
May 04, 2007 | ASUS A8N32-SLI Deluxe Motherboard
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
