My pc wont continue booting because of usb overload
My desk pc s6op[s booting because of this problem. at the start there are occasions when the pc won't shutdown completely
  • 27,725 Answers
What makes you think its usb overload ?
Check your computer's power cable and the power cables to any devices connected to the computer. Make sure all cables are firmly plugged into electrical outlets and into the computer and other devices. If you have an extra power cable for your computer, swap it in to see if your computer's power cable is the problem. Remove your computer's battery, if it is a laptop, and connect the computer to a electrical outlet to see if it will start up. Sometimes a discharged battery will prevent a laptop from powering up. If your laptop still won't power up, remove the power cable, replace the battery and try to run the computer off battery power. Unplug your computer and plug a lamp or radio into the same electrical outlet and see if that device works.
If the lamp or radio doesn't work, the outlet is the problem. Unplug your computer and open your computer's case, if it is a desktop system. Look for loose cables, cards and connections and attach them firmly. Blow out any dust with a can of compressed air. Also, check your computer's memory chips to make sure they are all plugged in and seated properly. Close the case once you are done and plug in the computer. Disconnect any USB devices connected to your computer and try to power up the system. Sometimes a USB device not connected properly will stop a computer system from powering on. Disconnect any new devices recently added to your system. Sometimes new devices will conflict with other hardware within your computer and cause an overload on your computer's power supply. Disconnect any other devices connected to your computer such as the keyboard, mouse, monitor, printer or scanner and plug your computer into a electrical outlet by itself. Check to see if the computer works. If does work, shut it down and connect just one device, such as the monitor. Turn on the computer and monitor and see if everything works. Continue connecting devices until you find the one that is stopping your entire system from powering up. Hope it helps.
b>
Posted on Jan 23, 2013
4 Suggested Answers
maxcarson
  • 7627 Answers
SOURCE: My accer desk top won't boot up and an alarm is sounding
Alarm? Beep? Pull the AC plug, plug in , try again. Reseat the Memory Mods, replace CMOS battery. Need more info to give a informed solution. You didn'y supply your Model of Acer or OS? Take a look at Acer Support: http://support.acer.com/us/en/default.aspx
Posted on Dec 26, 2012
  • 121 Answers
SOURCE: windows 7 won't start up
Log on via save mode and backdate your restore to an earlier date before issues date. All will be fine.
Posted on Feb 07, 2012
mntchef_man
SOURCE: Computer won't boot up
Sounds like the fan isn't working and caused the hard drive to over heat, easiest way to fix is to get a new computer
Posted on Jun 25, 2012
Boot sequence USB
pick f1 to change bios to set to usb permanently.
press f12 to select usb boot on one-off occasion. make sure a usb has not been left in when powered off.
Jan 02, 2014 | IBM ThinkCentre Computers & Internet
Mk1 wont boot (HD or CD)
1) to be sure not to worsen things, make an exact copy of your faulty drive from your other machine (for example with Paragon Hard Disk Manager or any other tool freely available for testing).
2) try booting the other machine from the faulty drive (or its copy) in safe mode ; if it's booting, this means the MB is there ; does windows start ? if it does the problem comes from a bad contact of the enclosure of the DD (connector or cable).
3) if it's not booting find a tool to rebuild the MB, from the other machine.
Oct 02, 2013 | Panasonic Toughbook CF-29 Notebook
USB draws too much power. When I plug my Canon MP490 2.0 printer cable USB into my computer, a notice pops up stating: "Because a USB device was drawing too much power from your computer, one or more of...
in to the PC or into a hub, hubs are bad, they are lower power.
is this desk top, what is it?
ok , its 400mA max
so unplug all USB device and for sure CELL chargers.
there are only 2 possibles
PC has USB overload, too many devices.
or the PC is bad.
did you try all PC USB ports? 1 by one, all empty to start?
Sep 04, 2013 | Canon MP490 InkJet Printer
Spins but makes a beeping sound and wont register.
Well, It sounds like there is something lodged in your Hardware drive...The beeping is probably a warning signal to tell you that it is not properly booting up...You should go to a Computer Repairman...
Jul 11, 2013 | Seagate FreeAgent GoFlex Desk 1TB USB 3.0...
My aspireone notebook wont start up
do you have a flash drive connected to your notebook when you start it up. With notebooks this will stop it from continuing to the windows screen as it's trying to boot to the flash drive. Take any usb ports out and this should help. Good luck.
Aug 28, 2012 | Acer Aspire One PC Notebook
Wont display the desk top
Try rebooting, tap F8 to get into the multi-boot options. Scroll down and choose "Last Known Good Configuration" windows should boot up normally. If you have made any hardware changes or if windows perfromed a corrupt update, that will require some additional help.
Jan 12, 2010 | ASUS Eee PC 701SD
Labtop wont start up
check if u installed any new device recently. unplug all external cards like PCMCIA, USB drives, Memory cards and any USB device and try it again. if it continues, go to your bios settings and check your boot settings, make sure it boots from hard drive and not CD/DVD drive. if you have done any setting to the bios, revert it and try to start again. if it continues, check your keypads and buttons and make sure you don't have a sticky key or button that is pressed down. Cheers!
May 23, 2009 | Dell Inspiron 1525 Notebook
Compaq Persario SR2013WM starts booting,then quits fan on high
Seems like a motherboard or memory issue. Try removing the memory and re-seating it. If that doesn't work then try replacing the memory as it is the easiest and cheapest.
Mar 28, 2009 | Computers & Internet
Over rang message on monitor
restart ur pc in safe mode
and make resolution to lower settings it will solve your problem
first restart ur pc
press F8 key continuously
it will shows windows boot option from their select start windows in safe mode
after booting up pc
right click on desk top
go to setting
make resolution to 800X 600 and and colour quality to 4 bit or lower
then apply
save it
and restart pc and it will show your desktop normaly
just in case if it wont work
do the same in VGA mode start ur pc press F8 and from booting menu
select Start windows in VGA mode
then do the same as safe mode
and restart your pc
Nov 25, 2008 | Computers & Internet
Acer Monitor boots up w/computer then "no signal"
you must have disconnected it while the pc was running.damage can occur while doing this as can a keyboard (they are not like USB devices that can be plugged and unplugged while "hot".)
Jul 20, 2008 | Acer AL1916W 19" LCD Monitor
Open Questions:
Computers & Internet Logo
David Payne
David Payne
