Question about Logitech Quickcam Chat Webcam
My webcam image not going out ...
On a recent call my webcam was not sending my image out.....I could see the caller, but he could not see me. Using a Microsoft 3000 webcam. Also, I was getting my voice feeding back to me....
any suggestions?
many thanks in advance
sam
  • 1 more comment
  • sampilo Jan 27, 2009
    can you please repeat...came through unclear....I have selected it in settings.....not sure what you mean by having to tell messenger to use it..........This is a skype call.
    many thanks
  • sanasms Feb 09, 2009
    yes i am having same problem i can talk and and see the person im taking and if i invite her on my cam they can accept but in my screen totaly black and not showing my image.
    hope you can help me this prob urgent
    thanking you.
  • dewitvisser Feb 13, 2009
    I have the same problem with my webcam - can see others but they cannot see me.
    De Wit
My webcam image not going out. Message says
"Skype can't access webcam. Close down all video
use." The last call was fine both ways. What do I
do? Have Logitec cam and Windows 4.0. Am
plugged in--no consistency here. Help!
Posted on Feb 13, 2009
  • 38 Answers
For the voice coming back to u then u have your mic volume up to high
for the web cam have u selected it in the settings
as you have to tell messenger to use it
Posted on Jan 27, 2009
My webcam iball c8.0 is showing blurr images and is fully blurrr
Webcams are useful in both personal and business functions, from video chatting to video conference calls. When your webcam displays strange colors, it is usually due to a problem that is easily fixed even without advanced technical abilities. By trying at-home solutions before sending the computer or camera in for service, you can save time and money.
Lighting
Lighting is a common cause of strange webcam colors. When your webcam does not have enough light, it compensates by adjusting settings internally. The adjustments can result in color shifts that are not true to life. Bright, diffuse lighting reduces the workload on your webcam and allows it to display colors as they are. The light source should be behind the computer and pointed at your face to reduce shadowing and provide an even light. Avoid light sources behind you, as they can cause extreme contrast between your face and the light. b> Webcam Settings b> Most webcams come equipped with customization settings that allow you to adjust the display. Changing the settings while watching a preview webcam image can help you fix odd colors on the display. The location of the video settings varies, but is often located in the Preferences, Settings, Configure or Video menus. Adjust the tint, contrast and brightness settings until the image shifts to a normal color scheme. Webcam Drivers b> Webcam drivers allow the camera to function properly. When your drivers are corrupt or out of date, they can affect even the most basic display abilities. Webcam manufacturers publish the most recent driver downloads on their websites, usually on the individual product page, along with instructions for installation. To allow your computer to communicate with the webcam and use the drivers, run a software update to install any recent versions. b> Special Effects b> Some webcams come with built-in special effects that allow you to customize the appearance of the video stream. If an effect was enabled during the last session, it may stay on when the camera is turned on again. Turning the effects off will usually resolve the problem. The location of video effect settings varies by webcam model and manufacturer. Logitech Video Effects are located using the mask button in the QuickCam menu. On a Mac, effects for the built-in iSight webcam can be changed in the Effects 1 and 2 menus in the Photo Booth application. Hope this helps.
Jan 16, 2013 | Computers & Internet
Lifecam vx3000 fails to show caller on screen
Hey,
Displaying the Caller is not related to your computer, if the other person sees you and you can see yourself then the problem is not on your computer its most likely on the other persons computer.
Thanks and good luck.
Ekse
May 03, 2009 | Microsoft LifeCam VX-3000 Web Camera
Can't see caller
Let me know what messenger you folks are using and I'll send you a fix for your problrm. Bud
Feb 14, 2009 | Logitech Webcam
Can't see me during night time even there's is light
Several factors determine onscreen size of a video image produced by a Webcam. The actual Webcam hardware may be limited to a maximum resolution. The percentage of your screen filled by a Webcam image will be a factor based on your desktop resolution and the maximum resolution of the Webcam image. A third factor impacting image size is available bandwidth Webcam software may also play a role in determining image size, but in most cases the software is only limited by the Webcam output. There are several ways to optimize your results to make sure you send a Webcam image viewable at the highest resolution acceptable to relatives on the other end, while also optimizing your system to maximize available screen real estate with inbound images from relatives.
Webcam hardware is often a big limiting factor in determining maximum image size. Most Webcams on the market today output a maximum 640x480 image, which easily fills a television screen. Any of the Webcams currently available from Logitech, Creative, Apple, D-Link or the numerous niche companies marketing Webcams will support 640x480, although some produce better results than others. If you have a Digital Video camera capable of doubling as a Webcam, you may get a 720x480 maximum image size. Apple's iSight camera and some of the higher end Logitech cameras using CCD instead of CMOS image sensors produce excellent images at 640x480 in well-lit rooms.
Knowing 640x480 is the maximum image size, don't expect incoming video to fill your screen if you have your resolution at 1024x768. The graphic below is shows the relative portion of a 1024x768 screen filled by a 640x480 image at 50% of actual size. If you want the incoming video to fill your screen, reset the resolution of your monitor to 640x480 to properly accommodate the incoming video feed. This assumes your relatives are capable of sending 640x480 video from their end. If their sending limitation is 320x240, the best you can hope for is a video filling 50% of your 640x480 screen.
Nov 23, 2008 | Logitech QuickCam Express Web Camera
Quickcam Pro 5000 vidiw problem
Well the thing is with Digital Camera If there is lots going on (on the computer) your other program might interfer
1st end all processes that might have anything to do with the camera or that may be using any of its features, I would retart your computer as well
If you still have any issue uninstall and reinstall the drivers for the camera.
Good Luck
- John -
Dec 20, 2007 | Logitech QuickCam Pro 5000 Webcam
Cam images
hi it is not possible to send or recieve images using webcam,only you can video chat with your webcam
yahoo messenger definitely allows webcam chat .
the user with whom you are chatting must have webcam if you wanna see that person on your screen........!
Nov 21, 2007 | Logitech QuickCam Messenger Web Camera
Setting up Pentax Optio 50 to be webcam
When I was using a video camera as a web cam using Netmeeting, I found out a few things which may help. Once the connection is made, the settings from the other end play a part in the reproduction at your end. I.E. the image you are seeing at your end once connected to someone is actually their image, not yours. So what is really wrong is that their image is not appearing on your screan. Also, the size that they have selected controls the size of your displayed image etc. Have you tried connecting to other people or only one. The problem may be at the other end.
Aug 30, 2005 | Pentax Optio 50 Digital Camera
Logitech Quickcam Chat Webcam Logo
163 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
