Question about XBlue Networks X16 4- bundle CH Catalog Category: Telecommunications / Corded Phones
Fix system password error
Can't reset password for system settings
Blue screen on envy 13 admin password prompt with system disabled - CAN YOU FIX HP ERROR CODE 64449838
I can only help with the system admin password (presumed windows). You will have to manufacture a "Password Reset Disk" on another PC or laptop (preferably running same OS - you will need your product key COA number). Instructions on MS website. Also - check your BIOS settings are OK when setting to boot on the password reset disk. That will be F1 or DEL probably on power up.Good Luck.
Dec 21, 2014 | HEWLETT-PACKARD Hewlett Packard...
Can't reset windows 7 logon password as error
try this :
  1. Download the Reset Windows Password utility onto an alternative computer. Unzip the download file, you'll get the ResetWindowsPwd.iso file. Burn the ISO file to CD using an CD burning software such as ISO2Disc orBurnCDCC.
  2. Set your Windows 7 laptop to boot from the Live CD. To boot from the CD-ROM drive, you may need to press a key such as F8 or F12 while your computer is starting up and set CD/DVD as the first boot device in BIOS.
  3. After the CD boots, you will have a mini operating system loaded into memory which will launch Reset Windows Password utility. It will not install anything to your hard drive.
  4. Click on the Reset Windows Local Admin/User Password option, the program will automatically detect the Windows SAM registry hive and local user accounts existing in your local computer.
  5. Choose the administrator account and click on Reset Password button, it will remove your forgotten Windows 7 administrator password in a short time.
Feb 17, 2013 | Computers & Internet
How to reset netgear wgr614 to factory default
You can reset your Netgear router to the factory settings from within the router manager. The reset procedure removes all user-configured settings and returns the router to the original factory settings. For this reason, only reset the router if you encounter problems that can't be solved with other methods.
Step 1: Check that your Netgear router is properly connected with your system or not. If it is OK, then press reset button on Netgear router for at least 10 seconds. The 'test' light should flash during this process.
Step 2: Now open browser and enter Netgear's IP address into the address bar. Generally, '192.168.0.1' is the Netgear router IP address but you can find specific IP address in Netgear router manual.
Step 3: Now enter your default username and password to log in to router.
Step 4: Click 'Erase' button under the 'Revert to Factory Default Settings'. This process will erase all your previous changes that have been made to the router and restore the configuration settings to factory setting. Don't interrupt the process until the process is finished.
Once the router's 'test' light has stopped blinking and the configuration page you are on has refreshed, the router has been reset.
Get instant Netgear router
support at http://www.vtechsquad.com/netgear-router-support/ to fix Netgear router/wireless router problem.
Jul 26, 2012 | NetGear WGR614 Wireless Router
After installing Ubuntu I logged out. Now is asks for a user name and passwork but I did't set any. I asked for it to automaticaly log on. How dos I fix it?
In Ubuntu 9.04 click on the main icon and select Restart.
- If Ubuntu is the only operating system on your computer you'll need to tap the ESC key as the system boots.
- If you have a
dual boot or multiple-boot system the menu should appear on its own.
- At the root level you'll get a boot menu. Select the one that says "recovery mode" and press Enter.
- Ubuntu continues to load until you reach the Recovery Menu.
- Arrow down to "
netroot
" which states Drop to root shell prompt with networking and press Enter.
- Now, at the root type "
password username
" (where username is the account whose password you want to change) and press Enter.
- You'll be prompted to
enter a new password
- You will not see the password or any evidence that you are typing.
- Retype the password. If both passwords match you'll have successfully reset your password.
- Press Enter to continue booting into Ubuntu.
hope it helps
May 30, 2012 | Computers & Internet
Can't connect to my edimax ar-7284wna router
theres a temporary solution... reset router and change the date on your computer to 1 febrauary 2010 and you will be able to login. you can set all your details and even if you change your date back to current it will not affect your settings however to log back into the router you need to set back your date to feb 2010..
Hope this works.
May 30, 2012 | Edimax Computers & Internet
I keep getting error code: 51330 when trying to connect wirelessly to the internet.
This was the information on error code 51330 on Nintendo.com
Error Code: 51330
Unable to connect to your wireless network
Likely cause: It appears that the password (also known as a WPA or WEP key) entered into the Wii console is not the same as what your wireless router is set to allow.
How to fix: Make sure the password is entered into the Wii exactly as it appears in your router's settings. Security keys are case sensitive.
Don't know how to find your router's password?
Look for a sticker on the bottom of your router. Many routers provided by Internet service providers have their default password located on a sticker on the bottom of the router.
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=51330&system=Wii&locale=en_US
Jul 20, 2011 | Nintendo Wii Console
Hi i I'm trying to connect my nintendo wii to the internet & I keep getting a error message Error Code 51331
(From Nintendo's Customer Service website: http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=51331&system=Wii&locale=en_US)
Error Code: 51331
Don't know how to find your router's password?Look for a sticker on the bottom of your router. Many routers provided by Internet service providers have their default password located on a sticker on the bottom of the router.
If you're not able to locate the password here, select the brand of your router below and we'll show you how to access your router's settings.
Jul 17, 2011 | Televison & Video
How do i reset my netgear wgr614v10 router to manufacturer default setting
Hi there!
Take a paper clip, and insert it into the little reset hole in the back of the router... hold for at least 20 seconds.
username and password: the defaults are admin and password..
Hope this helps
levibit
Dec 08, 2010 | NetGear WGR614 Wireless Router
Windows password lost
As far as I know there a are a lot of ways to solve your problem and the easiest one of them is to use program designed to see to such problem!
And I have tried many of them, according to my experience, I recommend you the password recovery bundle which not only can recovery your windows password but also other files' password.
And I google the address for you. it is http://www.recoverlostpassword.com/products/passwordrecovery.html
Wish you good luck.
Jan 15, 2010 | Dell XPS 625 DESKTOP GAMING MACHINE- Black...
Hot to reset the seting to default
Get instant online Netgear router
Get help for recover your lost wireless router password >>
May 12, 2009 | NetGear WGR614 54 Mbps Wireless Router -...
XBlue Networks X16 4- bundle CH Catalog Category: Telecommunications / Corded Phones Logo
52 people viewed this question
Top XBlue Networks Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a XBlue Networks Lands Phone Expert? Answer questions, earn points and help others
