Question about Nikon FM3A 35mm SLR Camera
Mirror lock up when firing in A mode.
Hi everyone. So I have this issue with my FM3A, the mirror locks up when the dial is in 'A' settings and the cranker seems to be stuck. It is working fine in other modes though. Hope someone can give some information/tips on how to fix this. Thank you!
    Top Expert:
  • Nikon Master
  • 14,161 Answers
Posted on Jul 18, 2016
4 Suggested Answers
  • 11 Answers
SOURCE: Mirror Locked in Up Position
When you say you put in a new roll of film, did the camera advance the film with the mirror locked up? Have you tried triggering the shutter few times to release the mirror? If that doesn't work, open the back of the camera. Turn the film take up spool in one direction...that should release the mirror down. Turn it also in the opposite direction. If that doesn't work, reach inside the lens mount opening and pull the mirror (very very gently) down. Don't force it down if it doesn't want to go. Sometimes that releases the mechanism that freezes from sitting idle for too long. It is always a good idea to take the camera out and triger few frames every couple of months to keep things lubricated. Let me know if that fixes it. AJ.
Posted on Sep 21, 2007
  • 302 Answers
SOURCE: Nikon F100 does not advance film to start of roll,
Jim, it really sounds like one of threethings. Either will require a repair shop.
1. the film sensor is not recognizing film in the film chamber, or film across the back, therefore not telling the advance motor to advance film...
2. The film advance motor itself needs replaced.
3. The rear door latch switch needs replaced.
Since everything else seems to do OK, I doubt the main computer board is bad.
Posted on Feb 03, 2010
  • 102366 Answers
SOURCE: mirror locked up on Nikon F75
Try pressing and releasing the shutter button. If that doesn't do anything, then turn the camera off and on and press and release the shutter button. If that still doesn't do anything, then turn the camera off, remove and reinsert the batteries (or a fresh set, if readily available), turn the camera on, and press and release the shutter button.
I ran across a Nikon N80 last week which hadn't been used for many moons. I tried the shutter and the mirror promptly locked up. It took about half a dozen tries, but the mirror eventually shook loose or whatever, and the camera now works perfectly.
If the above procedure doesn't do it, then you may have to take it in to a good camera shop for a CLA (clean-lubricate-adjust), the camera equivalent of an automobile tune-up.
Posted on Feb 05, 2010
Mirror lock up
Turn it off the green rectangle setting and see if it still does this (for example, turn the mode dial to P instead). If it stops doing that, then the flash up shaft in the top cover is bent. If it still does, then either the phase switch on the bottom of the mirror box needs to be cleaned, the shaft the phase switch gear is on is broken (common) or the shutter has a problem.
Mar 28, 2014 | Canon EOS-50E 35mm SLR Camera
How can I take photos whenever the mirror lock up is effect
You can't take photos when mirror is in lock up mode. That is used to clean the sensor(dangerous to do if not properly equipped!). Turn off power to camera to snap mirror back up and then you can switch to manual mode to shoot long exposures. Hope this helps!!
Aug 24, 2013 | Nikon D3100 Digital Camera
How do i remove the mirror on the hp laserjet 1200
Not required to remove mirror to avoid abnormal sound. The mirror is a part in Laser scanner assembly to reflect the image on OPC drum in various angles depends on model. In your series 1200 having single mirrored scanner assembly mounted on top area. To remove this you need to remove right,left back & top covers.. The laser scanner protect with four screws & two connectors. Remove all take out the unit. For removing the bonnet single screw protection remove this screw, take out cover. Inside you can observe a motor with four faced reflector. While motor got the energy it will rotate, if motor lubes are dried up it will make noise, remove motor head gently,(to remove take out entire motor unit with PCB which protects three screws, you cab observe black 'U' shaped plastic lock unlock it & pull motor up, apply lube to rotor & refix it back, ref see the drawing, you want to clean the mirror? ear bud you can clean surface of the mirror gently..
But it is no so easy, bare hands you cannot handle the mirrors, If mirror disturbed its factory fitted angle its very difficulty to back its own position. Removing the motor also difficulty,motor head carrying 4D reflector, while removing any scratches, or finger prints will damage the quality of prints some times scanner error appears.. 9_5_2012_11_07_49_am.gif
Sep 04, 2012 | HP Office Equipment & Supplies
Canon t3i will not fire
Have you got the camera set for mirror lock up. Check and disable if appropriate. When mirror lock is selected the first press of the shutter button moves the mirror up the second press fires the shutter
Mar 23, 2017 | Canon EOS 600D Rebel T3i Digital Camera
Similar electrical issues with driver's side door controls. Power locks, power window, and power mirror on driver's side are not functioning. I can manually unlock the door, but the buttons on...
CHECK FUSES FOR POWER WINDOW,CHECK FUSE FOR POWER MIRROR AND CHECK FUSE FOR POWER DOOR LOCK.IF FUSE OKAY DOOR CONTROL MODULE FAULTY ITSELF.
Sep 11, 2011 | 2004 Saab 9-3
Hi when I use the creative settings I push the shutter realese button the camera clicks but does not tak the picture until I realesa the button and press it again. Is ths a setting I need to change or is...
No fault of the camera it's has been programed in custom function #9 for mirror lock up. In mirror kock up mode first click of the shutter button locks up the mirror the second takes the shot and lowers the mirror. Mirror lock up is most often used while tripod mounted for extreme close ups or macro photography and also where a large telephoto lens is used. Mirror lock up is for reducing camera vibration during exposure. You can go into your custom function menu scroll to #9 and turn this off and all will return to normal.
Dec 22, 2010 | Canon EOS Rebel XSi Digital Camera
Nikon camera D300 mirror up/down shutter permanently up
Please check whether the mode dial is on 'Mup' or 'Lv'. If it is, then the camera is on mirror lock-up position (Mup) or LiveView mode (Lv). Mup is mirror lock-up and Lv is LiveView. It could be in Lv mode if you can see the image on the LCD, but not through the viewfinder. If it is on Mup mode, both the viewfinder and the LCD will be blank. If any of these is selected, pressing down the mode dial lock, rotate the dial to 'S' mode.
Jul 29, 2010 | Nikon D300 Body Only Digital Camera
Nikon D300 mirror sticks
Please check whether the mode dial is on 'Mup' or 'Lv'. If it is, then the camera is on mirror lock-up position (Mup) or LiveView mode (Lv). If any of these is selected, press the mode dial lock and rotate the dial to 'S' mode.
May 19, 2010 | Nikon D300 Body Only Digital Camera
Mamiya 645 Super mirror locked in open position
My mirror somehow got stuck open too, I removed the power winder and grasped the pins in the middle of the silver wheel underneath used to wind the camera. Turn this clockwise until it stops and shutter is completely closed. Test fire camera after. If it doesn't work make sure you wound it all the way.
Nov 25, 2008 | Mamiya 210219 for 645 Pro/Pro TL/Super...
D70 mirror lock up
I'm looking for the source of this same problem. I was able to get my d70 unstuck by:
1. Set to full manual mode.
2. In the menus set mirror lock up to yes and then press shutter release.
3. Turn camera off and then back on
Hope this helps you!
Nov 26, 2007 | Nikon Cameras
Nikon FM3A 35mm SLR Camera Logo
56 people viewed this question
Top Nikon Photography Experts
Ric Donato
Bart Pulverman
Are you a Nikon Photography Expert? Answer questions, earn points and help others
