Question about Electrical Supplies
We can't figure out how to open door to change battery..and there are no instructions in the manuel..it's below zero here and I'm afraid the battery will die before I can get someone here
  • 27 Answers
Do you have a make/model that your dealing with?
Posted on Jan 23, 2013
Cub cadet 53bb5bbp750 zero turn won't start
check the safety switches
Apr 03, 2012 | Garden
Why won't my car start after the temperature drop
Either your battery is old do not carry charge from the alternator. Or the charge is leaked from your batter due to door or some light is open. Check basic doors and other stuff closed.
Jan 16, 2012 | 2002 Suzuki XL-7
How to change mainboard battery?
Most PC users don't think much about the CMOS battery until their computer shows signs of losing its BIOS settings on boot up. If you tend to upgrade rather than replace your PC, replacing the CMOS battery every couple of years makes sense.
Likewise, if you purchase a used PC, battery replacement is a good idea unless the PC is less than two years old. It's just one more preventive step you can take to prevent troubles in the future.
If you have never replaced a CMOS battery before, you can find step-by-step instructions below.
In most cases, frequent CMOS errors are a sign of a dead battery. The CMOS battery maintains your settings while your PC is powered off. You can easily replace the battery yourself.
Instructions:
  1. Boot your PC and enter its setup mode.
  2. Write down all of the settings from the various BIOS menus. Click this link to learn more about this procedure.
  3. Power off your PC.
  4. Open the case of your computer
    cmosreplace_1.jpg cmosreplace_2.jpg Figures 1-2. Undoing the screws on your PC case. cmosreplace_3.jpg Figure 3. Opening the case of your PC.
  5. Locate the battery on the motherboard.
    cmosreplace_4.jpg Figure 4. Battery location on the motherboard. The layouts of the components differ on different motherboards, so you'll have to consult your motherboard user manual for specifications about the battery and its location.
    This is a close-up view of the battery on the motherboard.
    cmosreplace_5.jpg Figure 5. Typical CMOS battery. The most common type of batteries used in modern PCs is coin-shaped lithium/manganese-dioxide battery that looks like a large watch battery.
  6. Obtain a replacement battery from a local or online computer parts dealer.
  7. Remove the old battery.
    cmosreplace_6.jpg Figure 6. Removing the old battery.
  8. Replace it with the new one, as shown on the picture below.
    cmosreplace_7.jpg Figure 7. Replacing the battery.
  9. Document the date of replacement for future reference.
  10. Replace the case and power on the PC.
  11. Enter the setup mode of your PC.
  12. Reenter the settings you have written down from the various setup menus.
Tips:
  1. Don't forget to observe proper anti-static precautions when working inside the case of your PC.
  2. If you can't see your battery right away, try removing expansion cards or unplugging cables. The majority of newer motherboards use lithium batteries that look like large watch batteries.
If the battery is already dead and you receive messages saying "CMOS checksum error", skip Step 1 and Step 2.
Sep 03, 2011 | Fujitsu Siemens JETSON POWER (J815-E2F) PC...
Need instruction manuel for mega bloks pirates of the caribbean black pearl
Hi - you can get instructions for Mega Bloks sets from the Mega Bloks wiki - Blok City.
If you follow the link below and then go to the bottom of the page you'll find the instructions for this set.
http://www.blokcity.com/wiki/index.php?title=1069_Flagship_Battlers_Black_Pearl
Jul 27, 2011 | Mega Bloks Pirates of the Caribbean Black...
Start over with money
Here is a link to the PDF Instruction Manual. I have also copied the instructions for resting the amount to zero:
To Reset Account To Zero:
Turn on the ATM Safe by inserting your ATM card into the slot and entering your PIN code.
• Press and hold the 1, 2, and 3 keys (Fig 8).
• The display will read, "Reset to zero?"
• Release the 1, 2, and 3 keys and then press the "e" key.
If the electronic functions of ATM Safe stops working, open the battery door
(see instructions "To Install Batteries") and locate the RESET button above the batteries.
Press once to reset. Note: Account balance will not reset to zero.
Jan 25, 2011 | Wild Planet Room Gear Atm Safe Bank
When i turn the knob without entering the combo, the door opens. When I enter code, the door doesnt open. The passage knob is in the correct position.
"If your lock is opening on every turn of the knob or lever, except upon entering a code, this may be a ZERO CODE. Before attempting to remove the lock from the door, refer to the troubleshooting procedures outlined at bottom of this document for a zero code symptom/solution
Solution: Follow the procedure for changing a combination except omit step 3 (do not enter
the existing combination)."
I excerpted the above from the full instructions on how to change the code. If you don't have them, got to this link:
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.aspx?id=13
and go across from L1000 to the last column, "Tips".
When you hover your mouse over PDF, two choices will appear; left click on the upper one, "Changing the code/..." to download it.
The download will be a PDF file format. If you are unable to open it, you will need to download and install Adobe Reader on your computer. There is a link (Get Adobe Reader) at the top right of the literature grid.
When you do get the download open, you will have the stepwise procedure and illustrations necessary-but don't forget to omit Step 3, if you believe that you have the ZERO code problem!
Good luck--and please provide feedback if this helps!
Jan 07, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
Nutool sf20 safe
I need an instruction Manual for a Nutool sf20 safe
Jul 15, 2009 | Computers & Internet
2000 outback trunk indicator light won't go out
Check the switch plunger. If it is broken and does not depress when the door is closed, it will continue to act like it's open. Replace the switch if broken or faulty.
Jan 25, 2009 | 2000 Subaru Outback
Instructions in Chinese. Sometimeds heats, sometimes doesn't
we would have to know the brand of it and hope to find the manuel on line
Dec 06, 2007 | LG LB1000ER Air Conditioner
Electrical Supplies Logo
56 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
