Question about Dryers
I have a Kenmore Elite model #11065942401 that just stopped working. I'm not no sounds or movement of any kind. The dryer had stopped so I opened the door to take out the clothes and I heard a pop. Now nothing on the dryer works. What could it be? I checked all my circuit breakers and found one tripped. Even after resetting it I'm still getting nothing from the dryer. Any suggestions?
    Genius:
  • Dryers Master
  • 1,669 Answers
Something like a fuse or circuit breaker blew in the drier. Hopefully that and not the main circuit board!
Posted on Jan 23, 2013
  • 2 more comments
  • James Jan 23, 2013
    I didn't think of that. Do you know where the fuse in the drier would be located?
  • Leigh Perlmutter
    Leigh Perlmutter Jan 23, 2013
    It is probably behind the main panel...be careful...turn off the breaker before you go in there!
  • James Jan 27, 2013
    I had to take a break from this project until I got a voltage tester. At least now I can zero in on a specific area.
  • James Feb 02, 2013
    I changed the thermal non resetting fuse and still nothing. Is there another fuse that I should look at?
  • 67 Answers
SOURCE: Tripping circuit breaker
if the dryer trips the breaker right away its a problem with the dryer if its after a while its the breaker. call an electrician to make sure the wires are secured tight to the breaker and the breaker is rated correctly. i can almost guarantee its the breaker.
Posted on Mar 21, 2007
dididsaythat
  • 291 Answers
SOURCE: dryer just quit
I would check to see if you have 220v to back of dryer where the cord mounts to dryer Check the door switch, , Take back off dryer There is a fuse in the back its white oblong 2 wires coming from it, left side on blower outlet ..be carefull hook the 2 wires togather and if it comes on the fuse is bad needs replacing same way with the door switch.
Posted on Aug 29, 2007
dinomb
  • 16 Answers
SOURCE: Maytag Electric Dryer Stopped Working
Check spring tab behind door switch-if it's bent/out of adjustment, circuit will act like door is always open.
To confirm this, open door, set dryer to active setting, and hold in door switch; if it comes on, then it's either the spring tab, or the switch is malfunctioning
Posted on Mar 30, 2008
SOURCE: Kenmore Elite Oasis Dryer 6705 not start
I take the timed approach with appliance problems. If they occur 10 years after purchase, I buy a new one. If five years, I call a repair service and measure the cost of repair against the purchase of a replacement. If one year or less after purchase, I pile the expensive, offending, useless lump of an example of the decline of American workmanship into the back of my pickup and push it out on the doorstep of the store where I purchased it.
I find this method to be the most cost-effective and least troubling. And costs me about the same as calling the repair service.
In fact, right now I'm loading up my Kenmore Elite Oasis 6705, purchased March 13, 2007, (note that the problem began one month AFTER the warranty ran out) in the back of my pickup and I will make at quick stop at Sears to push it off the back of my truck (I find if I don't stop, but keep the truck rolling it makes for a much louder and attention grabbing drop off) then find the nearest hardware store so I can purchase some strong nylon line to string across my backyard so I can dry my clothes. I also purchase a bit of extra line so that I have enough to string up any Sears or Kenmore representatives who might stop by to inquire about the appliance they found on their doorstep.
Posted on Apr 12, 2008
krazykenny
SOURCE: Kenmore 90 series model 110 60902990
There is a thermal fuse in the back of the dryer, its usually white plastic, usually with 2 lite blue wires going to it.its probally blown...you can check it with an ohm meter......but if it is blown make sure you check the vent hose to make sure it aint kinked off that usually causes them to blow. if it aint that, be sure to make sure the heating element aint shorted to the heater box.or the thermostats aint stuck....the thermal is a safety feature and something caused it to blow
Posted on Oct 24, 2008
How do you replace the heating element part #3387747
Remove the back panel and on the left you will find the element in a housing. Just take the one screw out that holds it and slide the element out. BE SURE TO UNPLUG THE DRYER FIRST.
Jul 13, 2014 | Kenmore Dryers
Kenmore Elite Oasis dryer model #110.67032600
It sounds like you may need to replace the timer.
Apr 20, 2014 | Dryers
Kenmore 110 65942401
sounds like it needs replaced? I assume by not working you have to turn it off manually? 9r does it even come on heres a link?.... http://www.repairclinic.com/vwo1/Kenmore-Dryer-Model-11065942401-ID-699123-Circuit-Board-Timer-Parts
Aug 19, 2013 | Dryers
My kenmore elite dryer model 110 63032102 won't turn on
Check the door switch. Push it by hand and you should hear it click. If no click is heard, replace the door switch with this part.
If the switch is OK, then the only other problem will be with the thermal fuse located on the rear of the machine. Here is a link to that part.
Oct 15, 2012 | Kenmore Elite HE4 Electric Dryer
I have a Kenmore Elite HE3 model 11094834200 it heats up for about 5 minutes and than stops heating. I replaced the thermistor thinking that was the problem but it wasn't. If I try re starting t
Number 34 is the sensor strips located on the rear bulkhead inside the dryer. Clean them thoroughly with Windex or 409. Dryer sheets build a wax buffer on them sensors that moisture cannot penetrate. If no wetness is detected the control shuts her down thinking them clothes is did. Either that or you forgot to reconnect the sensor wire when puttin her back together Kimosabe.
Jul 10, 2012 | Kenmore Elite HE4 Electric Dryer
Have a Kenmore elite electric dryer model 11062952100 that heats but stops midcycle on both timed and auto. It does start right back up. Does seem to take a little longer to dry clothes. Have checked the...
Check behind the dryer to make sure the tube running to the exit vent isn't clogged or blocked. Then go out side where the vent runs to and make sure it isn't clogged.
Aug 29, 2011 | Kenmore Elite Oasis 6808 Electric Dryer
Kenmore elite dryer model #110.63952102 start button wont stay on everything else works
I have the same problem with my Kenmore Elite dryer (model#110.74992300), and I replaced both the motor and heater relay and the problem solved. You can get the relay from www.mouser.com for $3 each. The model for the relay is T9AP1D52-48. You may want to open up the dryer to verify the relay model, it is printed on the relay.
Sep 20, 2008 | Kenmore Elite 20972
Dryers Logo
80 people viewed this question
Top Dryers Experts
