Question about Kenwood DDX-6019 Car DVD Player
Radio reception is weak
Ok i installed my ddx 6019 and my radio signal is weak. i can only pick up two stations and when i seek nothing is picked up at all. It was previously installed in my truck and worked great , but i unhooked it and put it back in and now it is not working the same. Could you tell me what wires i may have forgot to hook up?
    Genius:
  • 2,920 Answers
It sounds like you dont have the antannae wire all the way in the wires wouldnt have anything to do with reception but the cable for the antanae would if if it not making doog contact.
Posted on Jan 27, 2009
  • 10,594 Answers
Please reinstall antenna wire in player properly and make sure that wire is not broken.
    Brigadier General:
  • 5,158 Answers
The antennae
My bewalt radio picks up fm stations then will cut out or want pick up at all
That is a classic symptom of a weak boradcast signal, signal strength varies with location and atmospheric conditions, that is why you can sometimes pick the stations up and other times you can't. If you don't have an external antenna try and hook one up to boost the signal strength.
Mar 27, 2017 | Audio Players & Recorders
97 mitsubishi bad radio reception
It sounds like you are just in a weak reception area. If you feel this is not the case first try replacing the entire antenna assembly, it would be the primary cause of this type of problem.
Jun 22, 2012 | 1997 Mitsubishi Mirage
I just installed a new Sony XT-100HD HD Radio Tuner for my truck. I wanted it so i could pick up more stations and have them all sound clear. After I hooked everything up to see if it worked all I could...
It is always worth checking the aerial in any case of poor reception.
In the case of a standard mast-type aerial it is necessary for the mast to have very good continuity to the centre of the aerial plug, that the outer part of the aerial plug has good continuity to the aerial ground and thus to the vehicle bodywork and the two parts are electrically isolated from each other. A good independent radio ground connection also helps.
In the case of miniature aerials or those within a windscreen, a rear screen or rear quarter glass, the amount of signal available will be small and so an aerial preamplifier will be provided to boost the signal. The preamp might be part of the aerial or a separate unit fitted anywhere convenient. I once found one fixed to the front firewall behind the dashboard.
The preamp needs a good 12 volt supply and a ground as well as good connections to the aerial coaxial leads. The supply is usually obtained from the radio set so it is operative only when the radio is switched on. Sometimes a radio has a dedicated output but mostly the electric (automatic) aerial output must be used. If the preamp isn't working reception will typically be limited to a few powerful stations.
I hope this helps.
Oct 21, 2017 | Sony XT-100HD HD Radio Tuner
Dual xhd6425 Reception Problems
My XHD6425 seems to be very inconsistent... Sometimes I get okay reception, other times I get terrible reception (much worse than my original stock Ford radio). The reception problems are more noticeable on stations that are more than 30 miles away or so.
Perhaps oddest of all, I've sometimes had it bounce back and forth between two stations (like if you are driving and in the middle of nowhere, half way between two stations), even in areas where I know should be getting good reception on one station and had never heard of the other other station before.
If you've figured anything out, please let me know.
Jan 16, 2010 | Dual Electronics XHD6425 Car CD/ MP3...
Problem with my Radio Tuner!
YOU MAY HAVE A PROBLEM WITH THE ANTENNA. THERE ARE 4 ANTENNAS IN THE REAR WINDOW FOR BOTH AM AND FM SIGNALS. THERE IS AND UNIT CALLED A DIVERSITY BOX UNDER THE REAR HAT SHELF THE CONNECTS THEM ALL AND DECIDES WHAT ANTENNA IS GETTING THE BEST SIGNAL. THAT UNIT MAY BE FAULTY. BEST TO HAVE IT CHECKED BY SOMEONE WHO KNOWS THE SYSTEM OR TAKE IT TO A DEALER. MIGHT BE CHEAPER THAN BUYING A NEW AFTERMARKET RADIO.
Jun 18, 2009 | 1999 Audi A4
mine used to do the exact same thing. it probably has to do with the singla strength. i just tuned in manually, then i just got an aftermarket stereo, but it does the same thing. it doesnt pick up every single station there is, clear or not clear.
Not picking up Digital signal from box but can receive it analog
So many factors could be affecting your reception. Keep in mind that the digital signal is all or nothing, either you have a signal or you don't, with the regular signal you can pull in weak signals but you can't with digital. Your converter box when turned on will probably not pick up the standard signal. The distance from the digital signal and the direction the antenna is facing also will affect your signal.
Ok with that said you will have to clear the path between the broadcast signal and your antenna, I know this will be a chore but take your antanna out of the attic and put it outside as a test only, this dosnt mean you cant have it in the attic it will just be a signal test.
Once the antenna is moved, from the menu scan for channels and see what you get. Let me know and I can help further.
lone99star
Jan 09, 2009 | Emerson EWL20D6 Television
No radio reception
check with the dealer tell them what is going on but my guess is it is the antenna is the issue
Nov 29, 2008 | 2005 Chevrolet TrailBlazer
Kenwood DDX-6019 Car DVD Player Logo
49 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
