Question about Dishwashers
Portable to built-in dishwasher
Putting new cabinets in my daughter's home that she just bought. Dishwasher was part of the deal, but it is a portable model. I am wondering if there is a kit to change it to built-in?
  • Dishwashers Master
  • 2,330 Answers
I've not heard of one, but you might consider trading with someone on "Craig's List" or in a thrifty nickel shopper in your area, or if you have a handy man, have them remove the sheet metal cover and the top and wheels and perhaprs it can be used as a built-in.
I have fixed a few free standing models, and the are the same as a built it as far as the hook-ups are concerned, you'd just have to go to a hardware stroe and buy the hoses and pipes and stuff to connect it.
Be Blessed
Posted on Jan 23, 2013
catriver
  • 878 Answers
SOURCE: portable dishwasher
The first thing you might want to do is check the water pressure in the house. Ideal water pressure should be from 55psi to 75psi max. I have seen homes that had pressure around 125 psi which will cause pressure leaks in water heaters, softners, washer valves, r/o systems. Check to see that all, if any inlet screens are clear and free from any grit and sand. It's possible that your inlet water valve (wd10m0010) has become restricted. Other than that, the complete uncoupler hose assy. part number is wd24m0030. These parts are for the dishwasher model ending in gsc3400j00bb. They are the same for model number ending in 00ww. Good luck.
Posted on May 07, 2006
eagle338
  • 4889 Answers
SOURCE: Dishwasher will not spray water from arms
Check for utensils or pot handles that may be hanging below the bottom rack and interfering with motion of spray head.
Clean holes with toothpick.
Check temperature at hot water faucet with meat thermometer. If below 120°F (49°C), turn up thermostat on hot water heater.
Posted on Oct 19, 2007
  • 171 Answers
SOURCE: Dishwasher insulation for heat
Hi marseibold,
I'm Harvey the Master Plumber.
Your questoin is: You're wondering if you can further insulate your dishwasher for heat. You are redoing your kitchen, new appliances, cabinets, etc. and shortsightedly put the spice sliding pull-out cabinet next to the dishwasher. The spices get warm when you use the dishwasher. There is a bit of room between the cabinet and dishwasher. Any recommendations for further insulation?
Yes. I would get another insulation blanket off a d/w I'm disposing. Anyway, you need to get one and install it over the old one to decrease the heat transfer.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 14, 2008
SOURCE: pump not draining - Haier portable dishwasher
purchase new pump at www.partsquick.com/haier
about 33 shiped must be able to replace if they sell the pump i have the same problem looking for a diagram to replace pump
Posted on Jan 05, 2009
  • 10865 Answers
SOURCE: Kenmore portable dishwasher not draining
Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Belt One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it.
Motor If the motor isn't turning or working, the unit won't drain. First check to be sure you have power to the dishwasher. If not, see the section "It doesn't work at all." If the motor hums but doesn't turn, it may need to be replaced.
Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week, you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors can't be serviced.
Posted on May 28, 2009
I have a Whirlpool Gold built-in dishwasher. Right after I turn it on, and it has finished sensing it makes a loud groaning noise. It started doing this shortly after my daughter broke a glass when...
Hello, michelle
I was trying to help you out here. I was going back to some customers that asked questions in the past and it appeared that no one answered them, so I thought I would take some of my personal time to see if I can help. Here is a link to about everything you want to know about your dishwasher, from repair to trouble shooting it,pictures, video's. Just scroll around and you will see tons of information to almost any question you might have on your dishwasher. If you go to this link and click around, I am sure you will find out so much about your dishwasher, you will know more that the company that made it. Here Is the link for you to click on>>
http://home.howstuffworks.com/dishwasher.htm
Please if this helped you at all, if you can find the time to rate my help and some kind words written would be appreciated for my free help , I would appreciate it. Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks,Mike
http://beta.fixya.com/users/mc1bean
Oct 07, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
My dishwasher DU1050 is stuck on Lock and I've
Hi! cccole
Dishwasher may be in bind. remove kick plate and make sure adjusters are not putting case in a twist, or pressing unit to tight to top of cabinets.
InMrFixIt.
Jun 19, 2011 | Whirlpool 24 in. DU1050SS Built-in...
I have a baumatic bdw13 dishwashers that is not washing correctly it is reachong correct temperature but not cleaning dishes correctly i have checked filters & put finish rinse aids through & still...
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Apr 25, 2011 | Baumatic 23 in. BDW13 Built-in Dishwasher
How to install new door spring on portable dishwasher
Things You'll Need:
  • Owner's manual
  • Screwdriver
  • Replacement spring (optional)
  1. Turn off the power to your Kenmore dishwasher before attempting any repairs. If you have a portable Kenmore dishwasher, you can just unplug the power cord from the wall. Built-in dishwashers are hard-wired into the cabinet, so you will have to turn off the breaker switch at the home's circuit breaker box to cut the power.
  2. 2 Remove the screws that hold the kickplate onto the lower front of the Kenmore dishwasher. Take the kickplate off to access the door springs.
  3. Check the door springs to make sure they have not come loose from the door support or the adjustment holes on the dishwasher. Re-attach any ends that have slipped off their connections.
  4. Replace the springs if they are connected at both ends but still do not have enough tension to support the weight of the door. Once a Kenmore dishwasher door spring is stretched out, it cannot be restored to its original condition. Unhook one end of the old spring from the adjustment hole. Unhook the other end from the door support and discard the spring. Insert one end of the replacement spring into the adjustment hole and the other end into the hook on the door support.
  5. Open and close the door a few times to make sure the spring is now working properly. The door should not bounce up and down or sag on the hinges when it is in the open position.
  6. Restore power to your Kenmore dishwasher by plugging it back in or turning on the switch at the home's circuit breaker panel.
Dec 21, 2010 | Maytag Dishwashers
I have a Fisher and Paykel drawer dishwasher and I'm wondering if there's a way to put a panel on it to make it look like and integrated dishwasher. It would need some way of the panel moving to start the...
hmmmm...the first thing that comes to mind is to check out ApplianceArt.com. they have alot of panel options. I'm not sure if they have the integrated ones you are looking for but they have cheap options for everything else.
Nov 19, 2010 | Fisher and Paykel 24 in. DD603H W Built-in...
The inside of the dishwasher used to sparkle & clean the dishes very good, now the dishes look dirty & inside looks dull with a white film. I have tried cleaning filters & taking arms offs to...
heatman101
Sep 23, 2010 | Bosch 23 in. SHU33A Built-In Dishwasher
Dishwasher makes a loud, low pitched humming sound & is leaving a gritty residue on dishes when the washing cycle is completed
heatman101
Mar 03, 2010 | Maytag 24 in. MDB5651A Built-in Dishwasher
KitchenAid 24 in. KUDI02IRBS Stainless Steel Built-in Dishwasher
sorry stclairn,if its new & you have a waranty let them deal with it(why through good money after bad)hope this helps.thanx for using fix-ya.
Nov 16, 2008 | KitchenAid 24 in. KUDI02IRBS Stainless...
Asko D1796F1 builtin...lights are on but no one is home
Our Asko D1796 dishwasher has the lights on the panel working as usual but you can't select a cycle and it won't turn on. We unplugged the pipe. If we turn it off and wait for 12+ hours we have gotten it to work twice.
Mar 02, 2008 | Asko D1796FI Built-in Dishwasher
Dishwashers Logo
60 people viewed this question
Top Dishwashers Experts
Owen Barnes
