Question about InFocus Proxima UltraLight SV1 Multimedia Projector
Proxima Ultralight SV1- Blurry, Out of Focus
I need help either finding a local repair place or seeing if I can repair myself. The screen is displaye as blurry, out of focus and small, specks of colored dots on the screen- what is the best solution?
tinamarie49
  • 34 Answers
SOURCE: Proxima Ultralight Projector 350x
The filters probably need cleaning. Also check and make sure none of the vents are being blocked.
Posted on Dec 05, 2007
SOURCE: InFocus Proxima UltraLight LS1 LCD Projector
needs a new bulb
Posted on Dec 21, 2007
SOURCE: drivers available
You can download all the information you need from:
http://www.askproxima.com/service/m3/m3.asp
Jason
LCMA Insurance
http://www.lcmainsurance.com
Posted on Jan 12, 2008
  • 17 Answers
There could be several reasons for this problem.
1. New lamp needed.
2. New lamp did not fix? Could be mirror tunnel behind the color wheel than can collapse causing "dim" light source or dark lines.
3. All items "greyed" out caused when the unit does not sense a source input, ie computer or tv tuner. After connecting to a source, you should be able to go and adjust contrast and/or brightness settings
Posted on Feb 19, 2008
  • 285 Answers
SOURCE: It won't stay on.
I think you'll need to buy a new bulb,
Posted on May 16, 2009
My Proxima Ultralight SV1 projector no longer projects what's on my Dell laptop computer screen. It's been working normally until this week. It still projects "searching" but seems...
Press Fn key and F8 key to turn On external monitor output in laptop so projector will get video output of laptop.
Hope this will help.
Thanks.
Aug 03, 2011 | InFocus Proxima UltraLight SV1 Plus...
Do you know where I can get a replacement remote for the Proxima Ultra Lite LX-1 projector?
The projector is kinda old but your best bet would be ebay or call projector doctor. I know from time to time they have some old remotes.
Apr 19, 2010 | InFocus Proxima UltraLight SV1 Multimedia...
Is this projector capable of displaying video and dvd images?
yes, but it's an older model and cannot handle hd and only composite video.
Jan 04, 2010 | InFocus Proxima UltraLight SV1 Plus...
Our Proxima Ultalight SV1 was displaying yellow on the screen for a while then while using it it made a slight pop then smoke started to pour out of all the vents.
the yellowing was the fried light filter on the blue lcd panel (due to excessive heat and dust). the lamp probably blew for the same reasons. unfortunately, you can no longer get parts for this model.
Oct 19, 2009 | InFocus Proxima UltraLight SV1 Multimedia...
Hi. I am considering purchasing a used Proxima
I wouldn't buy it do to the fact that parts for this projector are rare.
Sep 25, 2009 | InFocus Proxima UltraLight SV1 Multimedia...
I have a proxima s540 ultra lite data
From what you describe, it sounds like a fan isn't working. When you turn on a projector, it will go through a quick self test--checking that everything is operating correctly. Some of the fans send out a signal to the main board telling it that they are running. If no signal is received, the board senses this and auto-shut down occurs to protect the unit from heat damage. The errant fan could be spinning but the computer pulse might not be being generated. It will require a tech to find this out.
Aug 31, 2009 | InFocus Proxima UltraLight SV1 Multimedia...
I am getting a red spot on my screen. Is this a
no, it is the light filter (polarizer). it is caused by excessive heat and dust buildup. blow out projector with canned air to prevent further discoloration, but the filter needs replacing.
Aug 04, 2009 | InFocus Proxima UltraLight SV1 Multimedia...
Color Balance
reset the settings to factory default. then make sure that it's set up for computer and not composite. if no change, one of the light filters is fried due to excessive dust and heat.
Jun 26, 2009 | InFocus Proxima UltraLight SV1 Plus...
Have an old proxima, adjusted the focus and still the display is a little fuzz Is it new bulb time?
Phoned the Infocus people and they said, the len was out of place. Len repair in this case would be costly. Could buy a newer projection unit for the price of the repair with great amount of lumens than the current proxima unit. Yet if anyone, knows of a cheap fix, please post it.
May 07, 2009 | InFocus Proxima UltraLight LS1 Multimedia...
Need to replace proxima x350 fans
there are no part number because there are no parts available. but if you are getting an overheating message, move the sensor for the front fan or remove it altogether (cut it off, jumper the wires, and tape them up well. and make sure they are away from the fan).
Dec 15, 2008 | InFocus Proxima UltraLight X350 Multimedia...
InFocus Proxima UltraLight SV1 Multimedia Projector Logo
75 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
